Old Sep 10, 2012, 08:25 PM
GryphonRCU is offline
Find More Posts by GryphonRCU
GryphonRCU's Avatar
United States, CA, SF
Joined Mar 2008
brolley,
No way the 5mm shaft is bent.
I would not pull the motor to check that...just change the prop and run the motor.
I doubt you will see any wobble.
It takes a worse crash just to bend a 4mm shaft.
5mm has 56% more metal than a 4mm shaft.
Gryphon
GryphonRCU is offline Find More Posts by GryphonRCU
Old Sep 10, 2012, 08:42 PM
moparmyway is offline
Find More Posts by moparmyway
Why the dirt on the wings?
moparmyway's Avatar
New York
Joined Jan 2009
Originally Posted by brolley View Post
Now I know why Mopar asked me "are you sure you only want to go 150", this speed thing is addicting!
I think I see another motor in my future.
. Need to pull the motor and check the shaft, hopefully the combat shaft beats the oak.
Pics below after the crash and the scoop keepin my Mega alive!
If you do see another motor in your future, Please just yell out max cell count you want to run, there are some KILLER F5D motors available !!!
I agree with Gryphon, dont even check the shaft, its fine, the adapter might be a different story though.
NICE SCOOP !!!!!!!!!!!!
moparmyway is offline Find More Posts by moparmyway
brolley is online now
Find More Posts by brolley
brolley's Avatar
United States, PA, Center Valley
Joined Dec 2008
Brosius, that vid is awesuuuuum. Thanks for sharing. Nice job!
Yeah, I think my nano-techs are getting weak too.
brolley is online now Find More Posts by brolley
Old Sep 10, 2012, 09:17 PM
Techmeister is offline
Find More Posts by Techmeister
United States, NY, New York
Joined May 2012
Originally Posted by Techmeister View Post
Hey all,
I have a power question.
I have a ZII with the O.S. 1200kv motor and castle ice 75amp. I am planning to get two 3300mah 25c - 40c Turnigy Nanotechs. Can my ESC handle the amps that the batteries output?
4S; two packs in parallel.
Also, what prop range will work here?
Techmeister is offline Find More Posts by Techmeister
Old Sep 11, 2012, 01:06 AM
Peter M is offline
Find More Posts by Peter M
Peter M's Avatar
Newcastle, New South Wales, Australia
Joined Sep 2007
Brad,
Love how you have made the hatch on your Demon! Never seen a setup that accessible before.
Sorry to hear about your tree mishap but that near indestructability of these is a great asset. Although the nose on my first Demon is starting to look like W.C Field's it still does 150 ish!
As for your batteries, use you ICE logs to check what voltage per cell they're holding under load (straight and level unloaded will give good baseline). If it's around 3.5 volts per cell or better they're fine.
Regards
Peter
Peter M is offline Find More Posts by Peter M
Old Sep 11, 2012, 01:07 PM
Fstclyz is offline
Find More Posts by Fstclyz
BldrFlyr
Fstclyz's Avatar
Joined Jan 2012
Zephyr II LOS flight.
Zephyr II LOS field flight (6 min 24 sec)
Nice LOS flight with my Zii over Boulder after getting anything trimmed and testing the UHF.
Fstclyz is offline Find More Posts by Fstclyz
Old Sep 11, 2012, 01:38 PM
GryphonRCU's Avatar
Joined Mar 2008
10" to 11" prop size range for 1200KV motor.
Gryphon
Old Sep 11, 2012, 04:08 PM
brosius85 is offline
Find More Posts by brosius85
never mind the boll⁣⁣⁣ocks
brosius85's Avatar
Australia, NSW
Joined Dec 2010
for 1500 - 2000w
lol
brosius85 is offline Find More Posts by brosius85
Old Sep 11, 2012, 05:27 PM
Joined May 2012
Originally Posted by brosius85 View Post
for 1500 - 2000w
lol
What??
Old Sep 11, 2012, 07:29 PM
brolley's Avatar
Joined Dec 2008
Peter , my last graph showed 3.46V/cell.
Old Sep 11, 2012, 07:57 PM
brosius85's Avatar
Australia, NSW
Joined Dec 2010
What??
use a watt meter plz, depending on the c rating of your batts and true kv of the motor you could be running a lot of power or not much... best to check it yourself to see what power it actually pulls
different propellor brands alter power a fair bit too.
just be careful on new power setups, i have been surprised a few times by the watt meter.
if griff says its ok im sure it is for a starting point. i am typically over cautious :P
Old Sep 11, 2012, 08:54 PM
GryphonRCU's Avatar
Joined Mar 2008
(2) 4S in parallel makes a bigger 4S
(2) 4S in Series makes 8S
***1200KV with parallel 4S packs will swing 10"-11" props.
Gryphon
Old Sep 12, 2012, 05:15 AM
Peter M is offline
Peter M's Avatar
Joined Sep 2007
Hi Brad,
How discharged was the battery and how much load was on there on the motor (accelerating hard or level and unloaded?) when you made that calculation?
More importantly- Is it fun to fly?
Old Sep 12, 2012, 10:38 AM
BpPilot is offline
Find More Posts by BpPilot
Molon Labe
BpPilot's Avatar
United States, CA, San Luis Obispo
Joined Feb 2008
To the random reader, it probably sounds like we never have any fun actually flying these things. Always pushing the limits of our equipment, and always wanting a few more mph...
BpPilot is offline Find More Posts by BpPilot
Old Sep 12, 2012, 12:02 PM
klique is offline
Find More Posts by klique
Mum is the word!
Joined Jun 2003
I read every day and always know you are all having a blast Keep it up guys,,, I will hopefully eventually get some of these sport wing molded in EPP.
klique is offline Find More Posts by klique
I got some Fan Fold what to build thread part II started by emoone!!! Don Sims Foamies (Kits) 188 Jan 23, 2010 08:28 PM
Build Log RiteWing 48-FT build thread theclaw Slope 46 Dec 09, 2007 08:53 AM
Mountain Models Tantrum Partial Build Thread.. Tram Parkflyers 142 Apr 03, 2004 10:41 PM
My Bobolink Build Thread (very Colibri like) Jim Poor Hand Launch 65 Dec 10, 2003 04:48 PM
Switchback re-build thread (or What the $#*& was that!) Biggles604 Parkflyers 17 Jun 23, 2003 09:34 PM
