Old Jul 17, 2007, 01:23 PM
chuckand is offline
Find More Posts by chuckand
Aaaala Baaama
Joined Sep 2004
Originally Posted by Atom1025
I am building a slice at the moment as well and I have to say that this is one of the toughest builds I have encountered. The airfoil is so thin! I mean its a slim one! Towards the tips is really flimsy so I used flat carbon spars to stiffen them up.
Adam
Adam,
I've got a 9% Sportster in the works.... I am planning to add flat carbon to stiffen up the wing tips and was wondering how you and CK arrange them. Anyone got pics???
Chuck (In Aaaala Baaama)
chuckand is offline Find More Posts by chuckand
Old Jul 17, 2007, 06:50 PM
Atom1025 is offline
Find More Posts by Atom1025
Fly me to the moon...
Atom1025's Avatar
Sacramento
Joined Jun 2005
For my sportster 9% I am going with a lite setup using a Microdan outrunner so I am using no additional sparring other then the main spar.
Here is how I dide the slice. It really made a stiff wing but I think if you move them outboard more woulmake it much better.
I used carbon strip, 1mmx3mm stuff. Just made a slice with a razor and slid them in.
The first pic is where I place them the seconed is where I think they could be better placed.
Keep an eye on your leading edge! These thin wings get away from you really fast if your not paying attention.
Adam
Ps share pics and progress here!
Atom1025 is offline Find More Posts by Atom1025
Old Jul 17, 2007, 09:04 PM
klique is offline
Find More Posts by klique
Mum is the word!
Joined Jun 2003
Tl 60
This one is going to the big island inthe pacific.
I changed things up a bit ,it has 7 spars and has a ballast bay that will hold up to 48 oz of ballast.
I will give you some close ups once it is done.
ck
klique is offline Find More Posts by klique
Old Jul 17, 2007, 09:12 PM
joekoz is offline
Find More Posts by joekoz
Certified Riteaholic
joekoz's Avatar
San Marcos, CA.
Joined Oct 2003
Looks good. Different for you though Chris. Changing things up a bit are ya?
joekoz is offline Find More Posts by joekoz
Old Jul 17, 2007, 10:43 PM
Pilot Tim Nunn is offline
Find More Posts by Pilot Tim Nunn
Newport, NC
Joined Jun 2007
any one got any advice on a 40 lite build ,what should i use for servos using mega 16 15 3 turn on 2 1320 3c thp cc 35 ,dont know what prop to run,do i need to add more carbon,or is the kit enough
Pilot Tim Nunn is offline Find More Posts by Pilot Tim Nunn
Old Jul 17, 2007, 10:53 PM
klique is offline
Mum is the word!
Joined Jun 2003
Tim how did that 1107 2775 kv neu motor do?
Old Jul 17, 2007, 10:57 PM
Atom1025 is offline
Atom1025's Avatar
Sacramento
Joined Jun 2005
Slice
I have one being covered rite now, its a bit different then the other builds. Pay close attention to the leading edge and trailing edge to avoid warps, use flat carbon for the spars. You can fit just about any gear you could fit in the TL/Demon 40. The one I built has standard servos(exposed rods) and will easily fit a 20mm thick pack.
Keep the motor back farther on this one as the chord is smaller, this will give you room for electronics and batts.
Don't go for crazy speeds on this one! I don't think it'll handle 140mph speeds. Keep it tame like a Het3 on 3s all the way down to a 20mm motor.
No positives on the CG, yet I assume it'll be in the 7-7.5 range from discussions with Chris. Definitely gotta do some glide test before launching.
Glass is a bit different as well the shorter chord changes things up a bit. Its hard to explain but you'll see when you get to that point, really made me think how to lay it out. Normally you start parralell trailing edge, this time I started one piece horizontal to the wingtips, from tip to tip. But do as you see fit.
I know I keep saying tomorrow but I "should" be getting the slice build pics tonight!
Old Jul 17, 2007, 11:05 PM
Newport, NC
Joined Jun 2007
the neu motor has me scared she is ready to fly just need batts i ve dumb thumbed my tl 50 like 5 times still looks great not quite ready for a faster one yet,plan to maiden bobs tl50 this sat ck i rock the ccrcc fun fly last sat with my 50 smoked a viper 500,`
Old Jul 17, 2007, 11:46 PM
joekoz is offline
joekoz's Avatar
San Marcos, CA.
Joined Oct 2003
Mine does awesome. The TL has quite a kick from the Medusa that was on it.
Old Jul 18, 2007, 08:31 AM
chuckand is offline
Aaaala Baaama
Joined Sep 2004
Adam
Cool, and thanks! I'm going with an ARC 110, so it's a pretty lite build too. I'll consider stiffening the tips but may not worry it. High speed isn't the name of the game with this particular build...
I'll letch know how it goes when I get "rolling."
Chuck (in Aaaala Baaama)
Old Jul 21, 2007, 12:34 AM
Atom1025 is offline
Atom1025's Avatar
Sacramento
Joined Jun 2005
Slicin it!!!
So I am doing a custom built Slice for a fellow member here, Don't worry Chris is ok with it.
The guy wants to fit a 3300 Polyrc pack so the bay is as deep as possible. He'll be running a 3t on 3s and a 5.5x4.5 or 5x5.
Standard size futaba digitals.
I ran the clear golden rod tube through the wing for easy instalation/removal of the antenna.
The plane is completly finished just needs to be shipped out. I'll let him post the finished pics.
Adam
Old Jul 21, 2007, 12:58 AM
Charger is offline
Find More Posts by Charger
I B Chargin'
Charger's Avatar
Arizona
Joined Aug 2003
I am glad you posted great pics of the Slice build. That's how mine is going to be powered too........so I'm all over any info you or the lucky new owner has to offer. Really sounds like a fun plane, with good performance and pretty simple. Hope it tracks like its big brother, the fity
Charger is offline Find More Posts by Charger
Old Jul 24, 2007, 05:55 AM
Newport, NC
Joined Jun 2007
CK r u running a bec, opti, and batt for servos like the 50 thanks.
Old Jul 24, 2007, 01:00 PM
klique is offline
Mum is the word!
Joined Jun 2003
I run that stuff on all my wings.
ck
Old Jul 24, 2007, 01:52 PM
Newport, NC
Joined Jun 2007
has anybody sank the control rods on a 40 slice. ck or anyone what prop to run on the 40 demon with cc85 hv neu 1107 2775 kv motor on 5c and can i run it on 4c 5000 mah
I got some Fan Fold what to build thread part II started by emoone!!! Don Sims Foamies (Kits) 188 Jan 23, 2010 09:28 PM
Build Log RiteWing 48-FT build thread theclaw Slope 46 Dec 09, 2007 09:53 AM
Mountain Models Tantrum Partial Build Thread.. Tram Parkflyers 142 Apr 03, 2004 11:41 PM
My Bobolink Build Thread (very Colibri like) Jim Poor Hand Launch 65 Dec 10, 2003 05:48 PM
Switchback re-build thread (or What the $#*& was that!) Biggles604 Parkflyers 17 Jun 23, 2003 10:34 PM
