Old Sep 09, 2012, 08:38 AM
moparmyway is offline
Find More Posts by moparmyway
Why the dirt on the wings?
moparmyway's Avatar
New York
Joined Jan 2009
Our temps are cooling off, maybe want to extend WOT bursts and feel motor temp after a little 5-6 second run.
moparmyway is offline Find More Posts by moparmyway
Old Sep 09, 2012, 11:18 AM
moparmyway's Avatar
New York
Joined Jan 2009
Originally Posted by brolley View Post
Here's a graph of my last flight.
Mega 16/40/1.5sc
6S 4500 nano tech 45-90C
CC Ice 100
APC 6.5 x 6 pylon prop
I was thinking of running my 16-45-F5Dec on 8 cells in my 40" Demon, then realized that the motor would be better in a very high cell count for an EDF application !!
If you ever decide to purchase another Mighty MEGA, please remember to pm me with some details. Getting a F5D or a 1 turn really makes it sweet and Rite !!
Old Sep 09, 2012, 12:42 PM
Techmeister is offline
Find More Posts by Techmeister
United States, NY, New York
Joined May 2012
Hey all,
I have a power question.
I have a ZII with the O.S. 1200kv motor and castle ice 75amp. I am planning to get two 3300mah 25c - 40c Turnigy Nanotechs. Can my ESC handle the amps that the batteries output?
Techmeister is offline Find More Posts by Techmeister
Old Sep 09, 2012, 01:21 PM
e2346437 is offline
Find More Posts by e2346437
Crash Test Dummy
e2346437's Avatar
United States, ME, Mapleton
Joined May 2005
Originally Posted by Techmeister View Post
Hey all,
You don't mention how many cells you intend to use, but there is a chart here that indicates that motor only draws 50 amps maximum.
Eric
e2346437 is offline Find More Posts by e2346437
Old Sep 09, 2012, 03:28 PM
brolley is offline
Find More Posts by brolley
brolley's Avatar
United States, PA, Center Valley
Joined Dec 2008
What kills a motor? The number of amps going through it or the heat produced by those amps.
Reason is with my new scoop, the motor seems to be staying pretty cool and I am wondering if it could handle a few more amps?
brolley is offline Find More Posts by brolley
Old Sep 09, 2012, 10:02 PM
brosius85 is offline
Find More Posts by brosius85
never mind the boll⁣⁣⁣ocks
brosius85's Avatar
Australia, NSW
Joined Dec 2010
im gonna say its the watts that kill it not the amps
with a wire cutter for foam you set the heat by watts per inch of wire not amps or volts...
anyone else wanna chime in?
brosius85 is offline Find More Posts by brosius85
Old Sep 09, 2012, 10:22 PM
steveobhave is offline
Find More Posts by steveobhave
Kiwi in Australia
steveobhave's Avatar
Australia, NSW, Carlingford
Joined Mar 2012
Watts = Volts x Amps
You're technically correct as it's the 'work' that the electrical system is doing but it's thanks to large voltage and high current.
steveobhave is offline Find More Posts by steveobhave
Old Sep 09, 2012, 10:27 PM
klique is offline
Find More Posts by klique
Mum is the word!
Joined Jun 2003
Watt's and amps are both a measure of current flow , so saying it is 1 of the other doesn't make sense
klique is offline Find More Posts by klique
Old Sep 09, 2012, 10:42 PM
Kiwi in Australia
Joined Mar 2012
Well Watts are a measure of the total 'work' that the system is doing - amps are a component of that 'work' as are volts.
1 Watt is the amount of work done when 1Amp of current flows through wire to equalise 1Volt of Potential Difference.
Old Sep 09, 2012, 11:38 PM
klique is offline
Mum is the word!
Joined Jun 2003
Yes and it al boils down to current flow wich is amps , and watts,lol
Run 200 amps through somthing rated for 50 and it will burn, run 3000 watts through a 300 watt motor and it will burn , now if you want me to convert that 3000 watts to amps for you than we can,lol.
It all goes hand in hand.
My Last job FYI of 24 year was being an electrical contractor and electrician.
Old Sep 10, 2012, 12:00 AM
Kiwi in Australia
Joined Mar 2012
Good'O - I did electrical engineering at varsity and also my B level electrician certification so I guess we both know what we're on about
Old Sep 10, 2012, 05:52 AM
Peter M is offline
Find More Posts by Peter M
Peter M's Avatar
Newcastle, New South Wales, Australia
Joined Sep 2007
Can I have a go at trying to answer Brad's question a little more specifically?
Brad,
As you increase the load on your motor by increasing the size of your prop, the current draw of your motor increases.
Since the current draw increases at a greater rate than the voltage of your batteries drop due to this extra load, the power draw or wattage also increases too.
Since the motor's resistance remains largely static, the extra current draw creates extra heat. (The resistance actually increases but the rate of increase is relatively small but let's not make this too complicated!)
Also once you start to heavily load the motor you are also likely to be running it in a zone were it isn't as efficient in converting electrical energy into motion and this causes extra heat too. (This can be significant if you imagine a really efficient motor is only about 85-90% effective in converting its electrical input into motion. ie for a 1000 watt motor this could be at least 100 watts that is wasted in heat that we somehow have to get rid off otherwise it causes the motor temperature to rise rapidly.)
So anyway as you increase the load, the current draw would get to a point where the heat generated can't be dissipated fast enough into the surround air and the motor temperature rises dangerously to a point where it starts to cause the insulation on the windings to break down and eventually causes the windings to melt and oxidise.
So you are correct that extra cooling will allow you to run larger props, draw more current (and consequently more power) and allow your motor to survive by allowing it to dissipate more heat into the surrounding air and threfore moderate the increase in the motor's temperature
So good idea with installing the scoop to help prolong the life of the motor.
Oh, BTW, I'm a road worker if that makes any difference!
Peter M is offline Find More Posts by Peter M
Old Sep 10, 2012, 08:34 AM
brosius85's Avatar
Australia, NSW
Joined Dec 2010
finally got my D40 dialed in nicely and a video recorder for the FPV link.
there were a few horses in the adjoining paddocks so i was a bit reluctant to fly too low... horse owners can be aggressive people i have found :P
the poor old turnigy packs are dropping to 14.3 at what should be the 50% capacity mark and power goes from 1000w to 800w... im gonna need some better batts soon.
Ritewing D40 fpv (4 min 34 sec)
Old Sep 10, 2012, 08:41 AM
moparmyway's Avatar
New York
Joined Jan 2009
1. What kills a motor?
2. Reason is with my new scoop, the motor seems to be staying pretty cool and I am wondering if it could handle a few more amps?
1. Too much throttle !
Especially after Peter M's very informative post,
2. I would start to extend the WOT duration some ......... before going up to 6.5x6.5.
Shoot for 5-7 seconds of WOT, then land and get the temps !!
Old Sep 10, 2012, 06:02 PM
brolley is offline
brolley's Avatar
Joined Dec 2008
Thankyou Peter
My question was pretty vague but your answer nailed it.
So as long as my motor stays cool I can lengthen my WOT runs and possibly increase prop size if the temps stay in check? I'm sure I will start loosing motor efficiency as prop size increases. The batteries will probably sag more too equaling slower RPM.
Now I know why Mopar asked me "are you sure you only want to go 150", this speed thing is addicting!
I think I see another motor in my future.
Oh, almost forgot. Did some tree pruning today. I really wish I had a good video camera and someone willing to use it. Made an approach this morning right into the top of a big oak. When I realized I was behind it I tried to goose it and pull up.... too late, Prop shredded some branches and it fell about 30 feet.
Good news... plane is in good shape. Brought it home to look it over real good but looks like only the prop is broken and lost a winglet. Nose is a little crushed but not bad at all, still very flyable. Need to pull the motor and check the shaft, hopefully the combat shaft beats the oak.
Pics below after the crash and the scoop keepin my Mega alive!
I got some Fan Fold what to build thread part II started by emoone!!! Don Sims Foamies (Kits) 188 Jan 23, 2010 08:28 PM
Build Log RiteWing 48-FT build thread theclaw Slope 46 Dec 09, 2007 08:53 AM
Mountain Models Tantrum Partial Build Thread.. Tram Parkflyers 142 Apr 03, 2004 10:41 PM
My Bobolink Build Thread (very Colibri like) Jim Poor Hand Launch 65 Dec 10, 2003 04:48 PM
Switchback re-build thread (or What the $#*& was that!) Biggles604 Parkflyers 17 Jun 23, 2003 09:34 PM
