Old Aug 20, 2012, 01:24 PM
klique is offline
Find More Posts by klique
Mum is the word!
Joined Jun 2003
Sand off 95% of the spackle, do a layer of 3 m 90 on high, then use gloss paint if you can. The lam sticks well to the gloss , if you use flats, you will need a layer of 90 over the paint prior to lam.
klique is offline Find More Posts by klique
Old Aug 21, 2012, 08:23 PM
carlocivicsi is offline
Find More Posts by carlocivicsi
United States, FL, Miami
Joined Mar 2012
Clermont Fpv (short) with ZII- ritewing zypher. (1 min 45 sec)
my zII
carlocivicsi is offline Find More Posts by carlocivicsi
Old Aug 24, 2012, 08:52 PM
brolley is offline
Find More Posts by brolley
brolley's Avatar
United States, PA, Center Valley
Joined Dec 2008
New motor is in! Test flight soon.
Thanks Mopar!
brolley is offline Find More Posts by brolley
Old Aug 25, 2012, 05:38 AM
moparmyway is offline
Find More Posts by moparmyway
Why the dirt on the wings?
moparmyway's Avatar
New York
Joined Jan 2009
Thanks Mopar!
Great news !
What prop and cell count will you be starting out with ?
moparmyway is offline Find More Posts by moparmyway
Old Aug 25, 2012, 09:02 AM
brolley is offline
brolley's Avatar
Joined Dec 2008
6S , 6.5x5 to start. I'm gonna do a bench check to see how the amp draw changes in flight unloaded.
I also have 6.5x6 and 6.5x6.5 standing by.
Old Aug 25, 2012, 10:28 AM
moparmyway's Avatar
New York
Joined Jan 2009
You could just test it before you throw it up there.
Plug in battery
Give a no load @ full throttle without prop for 2 seconds
Put on prop and nail it for 2 seconds, then chuck it up in the air and fly
After landing, pull prop and no load for 2 seconds
All data will be in .csv file, you will easily see how the amps drop as you throw it and it picks up speed. You will see climbing, diving, straight and level, etc. I cant wait to see the .csv files !!
Old Aug 25, 2012, 06:08 PM
Peter M is offline
Find More Posts by Peter M
Peter M's Avatar
Newcastle, New South Wales, Australia
Joined Sep 2007
I hope you're using a 1.5SCE?
Peter M is offline Find More Posts by Peter M
Old Aug 25, 2012, 06:10 PM
brolley is offline
brolley's Avatar
Joined Dec 2008
1.5sc
Old Aug 25, 2012, 06:28 PM
Peter M is offline
Peter M's Avatar
Joined Sep 2007
Ah...... I would stick with the 6.5x5 and keep the 6 and 6.5 pitch blades in my flight box.
Don't ask me how I know.....
Old Aug 25, 2012, 09:58 PM
brolley is offline
brolley's Avatar
Joined Dec 2008
Peter, I could go 5S. Maybe that would be a better starting point.
Old Aug 26, 2012, 12:16 AM
Peter M is offline
Peter M's Avatar
Joined Sep 2007
Brad,
I'd still run 6 cells with the 6.5x5 but just keep your power on runs short until you are confident that your temperatures are OK.
What I would do is take off, do one 6 second run and land straight away then check your motor temperature. If OK, repeat with longer runs so that you gain confidence that you won't damage the motor.
What is safe for you might be different to mine because of differences in ambient temps, motor cooling (running a scoop?), length of WOT periods, battery voltage under load, length of cool down periods etc.
Don't stress, it'll be fun!
Old Aug 29, 2012, 07:17 PM
brolley is offline
brolley's Avatar
Joined Dec 2008
3 flights so far with Mega 16/40/1.5sc, 6S 4500, 6.5x5. Everything looks good. Might cautiously try 6.5x6 tomorrow . Will try to get video soon.
Old Aug 29, 2012, 09:25 PM
moparmyway's Avatar
New York
Joined Jan 2009
ICE file looks good, how were the motor temps ?
You do realize that you are at about 160 mph pitch speed with the 6.5x5 prop ?
Hows 155-160 mph feel in that wing ?
Expect about 10-15 more mph with the 6.5x6 ........ and only run that prop if the motor was nice when it landed with the 5 pitch prop !!
VIDEO !!!!!!!!
Old Aug 30, 2012, 05:18 AM
GryphonRCU is offline
Find More Posts by GryphonRCU
GryphonRCU's Avatar
United States, CA, SF
Joined Mar 2008
brolley,
6.5X6.0 not only starts with higher AMPs, it also unloads fewer % AMPs at max speed.
So with that in mind:
If you have 6.5X5.5 Pylon prop take the time to run it before 6.5X6.0
Spend more time gliding inbetween your full throttle runs so the motor has a chance to cool down more (after all it will be generating more heat due to larger prop than 6.5X5.0)
For first flights with higher load props, make fewer full throttle passes in order to gauge motor temp.
Incremental prop size increase, Fewer passes, More time gliding.....gradually change these things with subsequent flights.
Good luck,
Gryphon
GryphonRCU is offline Find More Posts by GryphonRCU
Old Aug 30, 2012, 08:58 AM
rlc2052 is offline
Find More Posts by rlc2052
Something Something RC
rlc2052's Avatar
United States, PA, Philadelphia
Joined Nov 2010
I have had too much time on my hands waiting for my motor. I think I have my paint scheme down. What do you guys think?
rlc2052 is offline Find More Posts by rlc2052
I got some Fan Fold what to build thread part II started by emoone!!! Don Sims Foamies (Kits) 188 Jan 23, 2010 09:28 PM
Build Log RiteWing 48-FT build thread theclaw Slope 46 Dec 09, 2007 09:53 AM
Mountain Models Tantrum Partial Build Thread.. Tram Parkflyers 142 Apr 03, 2004 11:41 PM
My Bobolink Build Thread (very Colibri like) Jim Poor Hand Launch 65 Dec 10, 2003 05:48 PM
Switchback re-build thread (or What the $#*& was that!) Biggles604 Parkflyers 17 Jun 23, 2003 10:34 PM
