Old Aug 02, 2012, 09:02 PM
brosius85 is offline
Find More Posts by brosius85
never mind the boll⁣⁣⁣ocks
brosius85's Avatar
Australia, NSW
Joined Dec 2010
you look like there is no strength in the middle at all bro..... you need uninteruped strips of weave going straight across the top wingtip to wingtip top and bottom, or some extra beefy spars. there is zero strength the way it is now.
even on just lam builds you need the lam to not be cut through the middle as it bears the entire force of the plane through the middle
brosius85 is offline Find More Posts by brosius85
Old Aug 02, 2012, 09:38 PM
brolley is offline
Find More Posts by brolley
brolley's Avatar
United States, PA, Center Valley
Joined Dec 2008
Brosius,
If you look at this picture I'll explain what I have for spars. On the aft side of L/H and R/H battery hatches a glass rebar runs through the corflute from the root of the wing to the tip, this is mirrored on the bottom but with no corflute. At the aft end of my electronics bay is a 5mm CF spar running perpendicular to the centerline of the plane, it meets the glass rebar spars atthe ends. This is mirrored on the bottom. Also have the 5mm internal spar.
Hope this is enough!!!
The top 5mm spar is not yet installed in this pic.
brolley is offline Find More Posts by brolley
Old Aug 02, 2012, 10:19 PM
klique is offline
Find More Posts by klique
Mum is the word!
Joined Jun 2003
Cover with 5 mil lam, you dont need it crazy smooth, lam will go down nice
Originally Posted by brolley View Post
I'm sure smoother is better but how smooth is smooth enough. I put down one layer of filler over the entire wing and sanded. Its pretty smooth but I can still feel some imperfecftions. Should I go for another coat or leave it as is. Paint and lam is next.
What are the advantages/disadvantages of paint versus monocoat. What are you guys covering with?
klique is offline Find More Posts by klique
Old Aug 02, 2012, 11:23 PM
brosius85's Avatar
Australia, NSW
Joined Dec 2010
oh ok 2x 5mm carbon spars through the middle should be pretty good
mono is good for aesthetics but is nothing like lam for strength
Old Aug 06, 2012, 06:29 PM
rlc2052 is offline
Find More Posts by rlc2052
Something Something RC
rlc2052's Avatar
United States, PA, Philadelphia
Joined Nov 2010
Do I need to be concerned with air vents to cool my esc? The ritewing video does not show them. It seems like some people put them in and some go without.
4s or 5s 5000mah - ICE 100 w/ heatsink - Mega 16-25-2ec
Rob
rlc2052 is offline Find More Posts by rlc2052
Old Aug 06, 2012, 07:36 PM
brolley is offline
brolley's Avatar
Joined Dec 2008
CK
I think you sent me 5 mil and 10 mil lam. Should I do a layer of 10 from cg forward top & bottom then 5 over the whole wing?
Old Aug 06, 2012, 07:43 PM
brolley is offline
brolley's Avatar
Joined Dec 2008
rlc2052
If you're going to be pushing the limits of your ice100 with that power setup you should have provisions for cooling. Mine is going to be asking a lot from my ice100 so I am exposing the top of it. If you need some ideas click on any picture in this thread then at the bottom of the pic, click on pictures in thread. This will show you all the pictures posted in this thread.
Old Aug 07, 2012, 03:22 AM
Peter M is offline
Find More Posts by Peter M
Peter M's Avatar
Newcastle, New South Wales, Australia
Joined Sep 2007
Rob
rlc2052
If you're going to be pushing the limits of your ice100 with that power setup you should have provisions for cooling. Mine is going to be asking a lot from my ice100 so I am exposing the top of it. ....
Rob,
If your ICE isn't exposed you will need to run some scoops. Here is the results of some testing comparing the effect of some simple plastic spoon scoops on a similar set up to yours: http://www.rcgroups.com/forums/showp...postcount=9694
Cheers
Peter
Peter M is offline Find More Posts by Peter M
Old Aug 07, 2012, 03:26 AM
Peter M is offline
Peter M's Avatar
Joined Sep 2007
CK
Brad,
The thick stuff is intended to go underneath to be tougher when skidding along the ground and the light stuff goes on top. Since you'll be using a tow hook, the bottom of the wing laminate won't touch the ground anyway so you can do it either way!
Old Aug 07, 2012, 09:30 AM
klique is offline
Mum is the word!
Joined Jun 2003
5 mil first then do a 10 mil skid . The 10 is applied over the 5 d
Originally Posted by Peter M View Post
Brad,
Old Aug 07, 2012, 11:23 AM
rlc2052 is offline
rlc2052's Avatar
Joined Nov 2010
rlc2052
Thanks for the hint about "pictures in thread" this will save a lot of time
rlc2052 is offline
rlc2052's Avatar
Joined Nov 2010
Rob, If your ICE isn't exposed you will need to run some scoops. Here is the results of some testing comparing the effect of some simple plastic spoon scoops on a similar set up to yours: http://www.rcgroups.com/forums/showp...postcount=9694
Cheers Peter
Yeah... I think I will be adding some scoops.
Rob
Old Aug 11, 2012, 01:58 AM
brosius85's Avatar
Australia, NSW
Joined Dec 2010
finally got my D40 maidened what a blast! i have never flown anything like it.
it is about 70oz but it still stalls nice and smooth, launches easy enough, and it an absolute pleasure to fly.
can't wait to really dial it in.
Ritewing D40 maiden (3 min 41 sec)
Old Aug 11, 2012, 02:06 AM
Peter M is offline
Peter M's Avatar
Joined Sep 2007
Congratulations, your ear to ear grin says it all!
(Hand launched like a champ too!)
Old Aug 11, 2012, 02:14 AM
brosius85's Avatar
Australia, NSW
Joined Dec 2010
i was taught by the best
I got some Fan Fold what to build thread part II started by emoone!!! Don Sims Foamies (Kits) 188 Jan 23, 2010 08:28 PM
Build Log RiteWing 48-FT build thread theclaw Slope 46 Dec 09, 2007 08:53 AM
Mountain Models Tantrum Partial Build Thread.. Tram Parkflyers 142 Apr 03, 2004 10:41 PM
My Bobolink Build Thread (very Colibri like) Jim Poor Hand Launch 65 Dec 10, 2003 04:48 PM
Switchback re-build thread (or What the $#*& was that!) Biggles604 Parkflyers 17 Jun 23, 2003 09:34 PM
