Old Jan 19, 2012, 05:52 PM
moparmyway is offline
Find More Posts by moparmyway
Why the dirt on the wings?
moparmyway's Avatar
New York
Joined Jan 2009
Originally Posted by murdnunoc View Post
johnny,
what plane is it for this time?
Hotliner?
Pylon racer?
3d with a gearbox?
Helicopter?
Drag race car?
try 8x8 on 6s.
r.o.f.l.m.a.o. !!!!
moparmyway is offline Find More Posts by moparmyway
Old Jan 20, 2012, 02:28 PM
jackosmeister is online now
Find More Posts by jackosmeister
DroneWorlds - TEAM NEW ZEALAND
jackosmeister's Avatar
Auckland NZ
Joined Aug 2007
IYF30 on crack power system?
Stiletto - 195mph (2 min 6 sec)
jackosmeister is online now Find More Posts by jackosmeister
Old Jan 20, 2012, 02:38 PM
murdnunoc is offline
Find More Posts by murdnunoc
Victim of C.D.O.
murdnunoc's Avatar
United States, TX, Lubbock
Joined Oct 2007
Poor iyf 30...
It's got no crack now.
Was that the Velocity setup?
How fast ya get on that setup, Jacko?
(the Stiletto in this video)
murdnunoc is offline Find More Posts by murdnunoc
Old Jan 20, 2012, 05:41 PM
mike-heli is offline
Find More Posts by mike-heli
United States, FL, Middleburg
Joined Jul 2010
HELP HELP0 HELP HELP
My .48 or 50 inch ritewing is around four years old bought used in hobby store so i didnt build and there is or was no signs of damage i installed my own electronics
ok so ill try to explain as good as I can. ok so I moved cg to 7 3/4 and took it out added some up to the elevators and dialed ailerons down more and checked cg. did glide test looked good , so threw in air and it rolled right,and so I went left and then it rolled left and I went leftand so on and on--- so basically I was chasing the roll movement so I landed. took most of elevator up trim out and adjusted thrust of motor and tried again and this time when I threw it was straight and true went a little above 1/4 throttle and she was looking really good, tiped right then left felt good so I gave her some more throttle and she was still looking good and that’s when it happened it went into death spiral I went left, right, right , left, right and she was in un- controable spin to the earth bammmmmmmmmmm and I said ok enough for tonight so any help or ideas would be helpful
BL32 Ducted Fan Motor, 2150Kv
Key Features
6-pole design
Ideal for 80mm EDF Units
Includes mounting hardware
Purpose-built for the E-flite® Delta-V® 32 80mm EDF unit
Up to 1,400 continuous input watts or 1,665 maximum burst
High-quality construction with ball bearings and hardened steel shaft
70-80 amp esc
2-7.4 4000mah 40c lipos
cg right now 7 3/4
no weight added
little up-thrust in motor
mike-heli is offline Find More Posts by mike-heli
Old Jan 20, 2012, 06:39 PM
brosius85 is offline
Find More Posts by brosius85
never mind the boll⁣⁣⁣ocks
brosius85's Avatar
Australia, NSW
Joined Dec 2010
radio lock out? what receiver?
servos dead? any signs of damage not from the crash? linkages all secure? horns still attached?
any breakages on landing?
pictures???????? we need some more mate, could be anything.
brosius85 is offline Find More Posts by brosius85
Old Jan 20, 2012, 07:16 PM
Auckland NZ
Joined Aug 2007
Poor iyf 30...
16/40/1 on 5S 2200 with a 4.2x5.5 ~2200W, 4.75x4.75 was pulling 48krpm, prop was going supersonic (and sucked... )
That airframes been retired, was a bit of a pig too fly at twice the speed it was designed too. Best dopler I got was 195, but it wouldve hit over 200mph just got no proof!, it was a pig to keep straight and level, as well as baby it through the turns to keep it in one peice...
New airframe ordered
I just figured, if its possible to fit 6S 1800 into an IYF30, 5S 2000 would fit!
Old Jan 20, 2012, 07:35 PM
Victim of C.D.O.
murdnunoc's Avatar
Joined Oct 2007
Oh...
Thought you ripped out the 30's power system and stuck it in the Stiletto.
16/40/1 is too big a motor for a 30" wing.
I can't think of anyone who would try that...
Just silly...
Although my 30" DOES have a 28mm clamshell...
And the Mega 16/40/1 IS a 28mm motor...
Wonder if I can jam any more Lipo in my wing. Might need to do some mining of the battery bay.
Old Jan 20, 2012, 07:51 PM
Auckland NZ
Joined Aug 2007
16/40/1 is too big a motor for a speed 400 pylon too.. But it fits
Old Jan 20, 2012, 09:41 PM
Victim of C.D.O.
murdnunoc's Avatar
Joined Oct 2007
And if it doesn't fit, cut a bigger hole!!
Murdo,
The guy who puts Mega-branded soda cans on the back of his planes.
Old Jan 21, 2012, 12:22 AM
PaulVi is offline
Find More Posts by PaulVi
resU deretsigeR
PaulVi's Avatar
Dublin Ca
Joined Aug 2004
Originally Posted by BpPilot View Post
Not sure, ill have to try. I do know that it does roll under power but haven't tried in a glide. The reason im asking is that i recently cranked up my throws on a lightning 36 and it has been rolling out of loops.
dial it back down there is a point in a wings life that too much throw and too tight of a loop will invoke a high speed stall and the air going over the control surfaces becomes unbalenced and the wing will snap out of the loop.. if you want the higher roll rates increase aliron but not elevator throws and you will get a better flying wing...
the 36 inch lightning is more ceceptible to this due to the narrow balence and short wing span.
Also this is not justa ritewing problem but wings in genral..
PaulVi is offline Find More Posts by PaulVi
Old Jan 21, 2012, 04:19 AM
matwelli is offline
Find More Posts by matwelli
1400 watt RW Zephyr
matwelli's Avatar
Taranaki New Zealand
Joined Sep 2003
Got a photo? Guessing its a tl50
What are your throws, just sounds like too much deflection on your surfaces
Where did you get the cg point from, did you measure and check it with a cg calc ?
Key Features
6-pole design
70-80 amp esc
cg right now 7 3/4
no weight added
matwelli is offline Find More Posts by matwelli
Old Jan 21, 2012, 09:41 AM
Joined Jul 2010
matt
throws are about ummmmm a little more than half inch total throw on aiel, and 3/4 or a tad more on elevator. no damage to airframe or sparing. cg was giving to me by chris i believe the designer but this is what i foung but it could of been from crash. one jr ds3421 servo bad gear and at 7 3/4 back from tip of nose is a little nose heavy but at 7 1/2 it is wayyyy tail heav. so i moved cg aging to 7 1/2 and when rain lets off i will try again.
ok thnk austrialian asked lol radio lock out? what receiver? dx7 and full range with satelite spectrum recieverservos dead? any signs of damage not from the crash? linkages all secure? horns still attached? found one bad but possible from crash jr ds3421 all secure
any breakages on landing? possible servo
Old Jan 21, 2012, 01:46 PM
matwelli is offline
1400 watt RW Zephyr
matwelli's Avatar
Joined Sep 2003
matt
Don't forget to post some pics
What prop are you running
Old Jan 21, 2012, 03:52 PM
Joined Jul 2010
7x6 apc balanced prop
Old Jan 21, 2012, 06:22 PM
GryphonRCU is offline
Find More Posts by GryphonRCU
GryphonRCU's Avatar
United States, CA, SF
Joined Mar 2008
mike-heli,
Which prop in that picture? ......same APC 7X6 Sport?
That is a decent motor. Does not have great resistance numbers though. So careful how far you push it in future. It has similar size and weight to HET 2W-30, MEGA 16/30/X, NEU 1112 series.
It should make a good match up on 4S and 7" prop!!!
Gryphon
GryphonRCU is offline Find More Posts by GryphonRCU
I got some Fan Fold what to build thread part II started by emoone!!! Don Sims Foamies (Kits) 188 Jan 23, 2010 08:28 PM
Build Log RiteWing 48-FT build thread theclaw Slope 46 Dec 09, 2007 08:53 AM
Mountain Models Tantrum Partial Build Thread.. Tram Parkflyers 142 Apr 03, 2004 10:41 PM
My Bobolink Build Thread (very Colibri like) Jim Poor Hand Launch 65 Dec 10, 2003 04:48 PM
Switchback re-build thread (or What the $#*& was that!) Biggles604 Parkflyers 17 Jun 23, 2003 09:34 PM
