Espritmodel.com Heli Air
Old Dec 27, 2011, 09:11 PM
Victim of C.D.O.
murdnunoc's Avatar
Roanoke, Texas, USA
Joined Oct 2007
Peter, how thick is that plastic sheet you have over the battery bay?
Does it have similar compression resistance to 2mm Coro?
From what I've seen, when a foam-and-skin structure fails it is usually due to the top surface crumpling.
This is more crucial in the battery bay area, which is an entirely monocoque structure (all load is born by the skin)
Coro does have very good crumple resistance and stiffness for its weight. I'm sure a plastic sheet would, also, if it were at least 1mm thick.
Just my initial thoughts.
murdnunoc is offline Find More Posts by murdnunoc
Old Dec 27, 2011, 11:18 PM
Peter M's Avatar
Newcastle, New South Wales, Australia
Joined Sep 2007
Murdo,
I agree! The PVC sheet I've used for the bay covers is only about 0.5mm thick and even though it is stiff and will be glassed and taped each flight, it still wouldn't transmit compression forces as good as corflue. Consequently I've just employed a "Beyond the Parkflyer" Stryker technique.
Thank you for speaking up, I appreciate it!
Regards
Peter
Peter M is offline Find More Posts by Peter M
Old Dec 27, 2011, 11:30 PM
never mind the boll⁣⁣⁣ocks
brosius85's Avatar
Australia, NSW
Joined Dec 2010
next thing you will have a balsa trailing edge and ply winglets lol
jk
brosius85 is online now Find More Posts by brosius85
Old Dec 27, 2011, 11:32 PM
With great pwer comes great 3D
killsdeer4fun's Avatar
Globe, USA, Clemson, SC
Joined Jun 2010
And boost tabs?
killsdeer4fun is offline Find More Posts by killsdeer4fun
Old Dec 28, 2011, 01:57 PM
Victim of C.D.O.
murdnunoc's Avatar
Roanoke, Texas, USA
Joined Oct 2007
What's a boost tab?
Do I need one??
I just load 'em up with bigger motors till they give up and go fast!
Old Dec 28, 2011, 02:28 PM
Joined Jun 2010
Running joke over on Flying Giants.
Here is an explanation though
http://www.rcuniverse.com/forum/m_64.../tm.htm#642275
Its handy in full scale planes where you are the one supplying the work.
Old Dec 28, 2011, 02:45 PM
Peter M's Avatar
Joined Sep 2007
jk
You're not suggesting there is some sort of Darwinian evolution at play?????
PS: I'm sure CK will suggest its actually de-evolution!
Old Dec 28, 2011, 02:48 PM
Victim of C.D.O.
murdnunoc's Avatar
Roanoke, Texas, USA
Joined Oct 2007
uh...
oh...
Old Dec 28, 2011, 02:52 PM
Livin it UP when Im goin DOWN
Arcteryxxx's Avatar
Norway, Telemark, Skien
Joined Feb 2010
Originally Posted by Peter M View Post
You're not suggesting there is some sort of Darwinian evolution at play????!
Is this the kind of things the rc pilots in the Northern Territory do?
Arcteryxxx is offline Find More Posts by Arcteryxxx
Old Dec 28, 2011, 09:02 PM
brosius85's Avatar
Australia, NSW
Joined Dec 2010
noooooooooooooo!!! never!!!
Old Dec 29, 2011, 10:14 PM
Peter M's Avatar
Joined Sep 2007
I'm starting think about Gulf Ford GT40 colour schemes.......
Old Dec 29, 2011, 10:26 PM
Victim of C.D.O.
murdnunoc's Avatar
Roanoke, Texas, USA
Joined Oct 2007
Peter you've done a wonderful job in your layout to get everything farther forward than I've seen it on a Demon with such high power. Bet you won't need nose lead!
Did you use the front spar hole? This has been the limiting factor for how far forward I can get everything, but I've used the rear spar hole in my Demon builds. If you've squeezed everything in and still left the rear hole empty, that'll allow you to run a massive motor without being tail heavy!
Old Dec 29, 2011, 11:01 PM
Peter M's Avatar
Joined Sep 2007
Murdo,
Let's hope I haven't gone overboard and it ends up nose heavy!
I've used the front spar hole and have a longer custom made motor plate sitting on top of the spar. This will give me about a 4 to 5mm higher thrustline than standard and the possibility of better motor cooling ala Stryker.
I think it would be possible to leave out the centrally located spar altogether and rely on more geometrically effective surface sparring, but that's for someone else to try like you!
You've probably also noticed that I have the esc "back to front" for the purpose of giving me more space to make connections. Still going to be on the tight side though but should be workable.
Old Dec 30, 2011, 03:48 AM
Why the dirt on the wings?
moparmyway's Avatar
New York
Joined Jan 2009
Murdo,
If you did go overboard, I do have, and MEGA will build a heavier 36mm motor for ya !!
They make 22-80-xx motors that weigh well over 1 pound
That ought to help ya if its nose heavy !!
moparmyway is offline Find More Posts by moparmyway
Old Dec 30, 2011, 04:09 PM
Peter M's Avatar
Joined Sep 2007
Actually Mopar,
I've just mocked it up to check the CG and a 22-30 or 35 might just be viable.
Let me get it finished so I can see where that pesky CG is actually at before we get too carried away with easily attainable 220 mph pitch speeds. Maybe I am ready for my 3rd Demon build sooner than I thought .......
I got some Fan Fold what to build thread part II started by emoone!!! Don Sims Foamies (Kits) 188 Jan 23, 2010 08:28 PM
Build Log RiteWing 48-FT build thread theclaw Slope 46 Dec 09, 2007 08:53 AM
Mountain Models Tantrum Partial Build Thread.. Tram Parkflyers 142 Apr 03, 2004 10:41 PM
My Bobolink Build Thread (very Colibri like) Jim Poor Hand Launch 65 Dec 10, 2003 04:48 PM
Switchback re-build thread (or What the $#*& was that!) Biggles604 Parkflyers 17 Jun 23, 2003 09:34 PM
