Old Jul 17, 2011, 10:09 AM
murdnunoc is offline
Find More Posts by murdnunoc
Victim of C.D.O.
murdnunoc's Avatar
United States, TX, Lubbock
Joined Oct 2007
First Person "PLOOP"?!
I gotta see this!
murdnunoc is offline Find More Posts by murdnunoc
Old Jul 17, 2011, 02:18 PM
D.B. Hooper is offline
Find More Posts by D.B. Hooper
Flirtin With Disaster !!
D.B. Hooper's Avatar
United States, OR, Mt Angel
I gotta see this!
Me too! Underwater video cool!
Got my 28/40/2500kv rocket motor from CK mounted in my Speedwing DartXL. Will run it on 3s and 4s. Before this I had the Mega 16/15/3 in it on 3s using a 6x4 sport prop. 24500rpm's. It was over 100mph.
In the photo here I have two 45C Hyperion 2s 2600mAh in series for 4s
any prop suggestions other than the 6x4 sport? AUW is 2.5lbs.
D.B.
D.B. Hooper is offline Find More Posts by D.B. Hooper
Old Jul 17, 2011, 02:37 PM
GryphonRCU is offline
Find More Posts by GryphonRCU
GryphonRCU's Avatar
United States, CA, SF
Joined Mar 2008
D.B.,
Depends of what you want to do.
Your KV X Voltage is higher than before besides the motor being equivalent to a 16/20/X.
If you want similar Watts or speed, you should consider dropping down to 6X3 sport (its a heavy duty prop like Pylon)...for static and inflght tests.
If you want more speed start with same 6X4 sport.
That is a good motor. Historically I have recommended it numerous times.
I always felt sad for people buying the Eflight six series when they could have bought that motor.
Pylon 2.9" and 3.7" pitch props might make your verticals and acceleration more interesting...maybe more fun overall.
Have fun,
Gryphon
GryphonRCU is offline Find More Posts by GryphonRCU
Old Jul 17, 2011, 03:35 PM
Originally Posted by GryphonRCU View Post
D.B.,
Have fun,
Gryphon
Thanks for the info ! I want to haul some A$$
I'll get some ordered tonight. I think I've got most of my 6x4 sport props from Tower. I also need a few 4mm prop adapters, the one's that don't require reaming out the hole. Is it the E-flight adapters?
Old Jul 17, 2011, 04:32 PM
Wingman65 is offline
Find More Posts by Wingman65
Build, Fly, Crash..Repeat
Wingman65's Avatar
St. Peters, Mo. USA
Joined Mar 2005
Originally Posted by Atom1025 View Post
Hey Paul. Yeah lifes been interesting. Finally starting to feel the urge to build. I have a fatty demon staring at me.....
Have a couple front yard fliers going at the moment but that's all aside from an IYF sloper that never sees wind..
Lets get this party started. You guys start those Fatty Demons and Ill start my "Ol Skool" TL 40.
Tony
Wingman65 is offline Find More Posts by Wingman65
Old Jul 17, 2011, 04:38 PM
Wingman65's Avatar
St. Peters, Mo. USA
Joined Mar 2005
By the way Hey Adam, how ya been. I've been havin' "stupid fun" with my superfly, making hot glue repairs right now.
Tony
Old Jul 18, 2011, 01:14 AM
Victim of C.D.O.
murdnunoc's Avatar
Joined Oct 2007
Demon 50" maiden!
So my brand new Demon 50" took to the skies today. Been a long time on the building board, and I really freaked myself out preparing it for flight. But once I stepped up to the catapult and shot it airborne, everything just felt RITE.
It handles just like my D40. Just a little bit more beefy feeling in the air. But still nimble on the sticks and carves a turn like a champ.
Only hitch in the flight was a corner of the lam film popping up and buzzing at high speed. Never like buzzing planes, but good to find the cause is something minor.
First flight was on 8S 4000mah on the Rokett 3670-880kv motor, and an 8x6 Sport prop. It even had good speed on this "light" setup for the maiden.
I ran 8x7 and 8x8 prop after, and got up to 153mph level no-wind speed on 2500 watts. Not quite the efficiency we'd get on a 40, but this thing can take SOOO much more power!
My Ice 160HV Lite ESC is coming in this week, so that will allow me to run the 10-12S that should really make this thing scoot
I'll run a few more props on 8S. I'll even try a couple of the 8.75" Q500 pylon props to get a baseline that will help determine how prop diameter relates to speed on this new plane. Then the props will shrink and the revs will rise until I'm on 7" props at over 32K
Then we'll see how fast this thing can really move.
The plane is very dialed in already. I did some dive testing and it just barely begins to climb out of a power-off dive, so that tells me CG at 22% MAC (10.1") is rite on.
It needs a couple clicks of Up trim between cruising and full bore, so I'll tweak the motor mount up a little to tune the thrust angle. I tried to do the inverted 45 degree climb, but the maneuver is foreign to me and took a couple tries to not get wonky. Once I did get the maneuver flown, I forgot what I saw looking for in the tuning
Elevon differential to dial the roll axis will come next flights.
I can't WAIT to get this thing scooting around in cooler temperatures when I can run big power.
Demon 50 Maiden (6 min 18 sec)
Old Jul 18, 2011, 04:12 AM
brosius85 is offline
Find More Posts by brosius85
never mind the boll⁣⁣⁣ocks
brosius85's Avatar
Australia, NSW
Joined Dec 2010
great work murdo! glad to hear that familiar noise. great success on the maiden too. good show. cant wait for the moster powertrain to fire up
did you stick with "excalibur" ? ... you know that could lead to it being wedged so hard into a boulder no-one can pull it out exept the king right?
here is the vid of my zeph getting wet while im here.
not "swimming" but wet nonetheless.
skip to 3:40 if you just want the touchdown.
plane goes splash (4 min 28 sec)
brosius85 is offline Find More Posts by brosius85
Old Jul 18, 2011, 04:39 AM
Peter M is offline
Find More Posts by Peter M
Peter M's Avatar
Newcastle, New South Wales, Australia
Joined Sep 2007
Congratulations Murdo!
Can't wait for some cooler weather for you (which also conversely means some warmer finer flying weather for us!)
Like your colour scheme too!
Peter M is offline Find More Posts by Peter M
Old Jul 18, 2011, 04:59 AM
Peter M is offline
Peter M's Avatar
Joined Sep 2007
Ambrose, another great video, well worth the cost of a replacement receiver!
Inspired me to view your earlier Hat Head video again.
Old Jul 18, 2011, 08:40 AM
ASB32 is offline
Find More Posts by ASB32
hmph!
ASB32's Avatar
United States, UT, Logan
Joined Dec 2008
Should a put pink on there!
ASB32 is offline Find More Posts by ASB32
Old Jul 18, 2011, 09:45 AM
Victim of C.D.O.
murdnunoc's Avatar
Joined Oct 2007
:middle finger:
Old Jul 18, 2011, 06:43 PM
jackosmeister is online now
Find More Posts by jackosmeister
DroneWorlds - TEAM NEW ZEALAND
jackosmeister's Avatar
Auckland NZ
Joined Aug 2007
Nice vid brosius!
Where are you flying? Drove up the coast a few years ago, recognise that beach but cant place it
jackosmeister is online now Find More Posts by jackosmeister
Old Jul 18, 2011, 07:03 PM
GryphonRCU's Avatar
Joined Mar 2008
Murdo,
Congratulations on your maiden flight.
After you got on the throttle the manly power could be heard.
I'm sure your climbing rate was really nice with that 8" prop.
Any comments on the unloading as full speed was reached?
(in relationship to either static or going to full throttle at low flight speed).
brosius85,
Sorry about your mishap. I'm glad there was no additional damage.
Carry a can of dielectric spray....just incase.
Gryphon
Old Jul 18, 2011, 08:11 PM
Victim of C.D.O.
murdnunoc's Avatar
Joined Oct 2007
Tony
OK, my curiosity has overcome my desire to look informed.
What's a Fatty Demon??
The long chord ones?
I got some Fan Fold what to build thread part II started by emoone!!! Don Sims Foamies (Kits) 188 Jan 23, 2010 08:28 PM
Build Log RiteWing 48-FT build thread theclaw Slope 46 Dec 09, 2007 08:53 AM
Mountain Models Tantrum Partial Build Thread.. Tram Parkflyers 142 Apr 03, 2004 10:41 PM
My Bobolink Build Thread (very Colibri like) Jim Poor Hand Launch 65 Dec 10, 2003 04:48 PM
Switchback re-build thread (or What the $#*& was that!) Biggles604 Parkflyers 17 Jun 23, 2003 09:34 PM
