Old Jan 22, 2008, 12:27 AM
reefboy is offline
Find More Posts by reefboy
Luke 12:7
reefboy's Avatar
USA, CA, Sunnyvale
Joined Nov 2006
Nice job Terry! The video came out nicely. Thanks so much for sharing. Looks like a very fun setup.
I'm hoping to maiden my Mini-Demon sometime this week. I programmed my CC Phx-25 tonight. Need to solder the motor connector, linkages, design winglets and glue them on. I'm in the home stretch and am itching to maiden it!
-Scott
reefboy is offline Find More Posts by reefboy
Old Jan 22, 2008, 12:47 AM
Charger is offline
Find More Posts by Charger
I B Chargin'
Charger's Avatar
Arizona
Joined Aug 2003
-Scott
That's a remarkable little bird!! You're going to love it!!
Charger is offline Find More Posts by Charger
Old Jan 22, 2008, 01:23 AM
Atom1025 is offline
Find More Posts by Atom1025
Fly me to the moon...
Atom1025's Avatar
Sacramento
Joined Jun 2005
Terry that video was awesome, I think you showed how a great maiden should go, you went through all the checklist and I think others will find this valuable.
That wing was rippin! It sure yanked and banked like crazy! Now I must have my own!!!! Great catch!
Atom1025 is offline Find More Posts by Atom1025
Old Jan 22, 2008, 07:00 PM
Wingman65 is offline
Find More Posts by Wingman65
Build, Fly, Crash..Repeat
Wingman65's Avatar
St. Peters, Mo. USA
Joined Mar 2005
Very nice video Charger. It looked very snappy.
Tony
Wingman65 is offline Find More Posts by Wingman65
Old Jan 24, 2008, 07:25 PM
SU Jags is offline
Find More Posts by SU Jags
Rejisterd Youzer
SU Jags's Avatar
United States, GA, Austell
Joined Apr 2004
Fs 48
I finally have batteries for the FS48, where should I start for throws and CG?
SU Jags is offline Find More Posts by SU Jags
Old Jan 24, 2008, 07:42 PM
twilkers is offline
Find More Posts by twilkers
twilkers's Avatar
Livermore, CA
Joined Jan 2007
Great vid Terry! you are raising the ritewing bar with that catch at the end!
twilkers is offline Find More Posts by twilkers
Old Jan 24, 2008, 07:46 PM
twilkers is offline
twilkers's Avatar
Livermore, CA
Joined Jan 2007
I have only flown my FS48 twice. I had my CG about a 1/4" behind the leading edge at the wing root. felt sluggish to me but not sure if it was the CG or my servos. My throws were pretty big and referenced from Adam(Atom1025) at 3/8" up and down for elevator and ailerons (3/4" total deflection). I think Adam just used this deflection for elevator and half that for aileron. We both used 1.5" aileron stock.
Adam has many flights.
Old Jan 24, 2008, 08:23 PM
SU Jags is offline
Rejisterd Youzer
SU Jags's Avatar
Joined Apr 2004
So thats 1/4" behind the LE where the fuse meets the wing?
Old Jan 24, 2008, 10:42 PM
twilkers is offline
twilkers's Avatar
Livermore, CA
Joined Jan 2007
yep. even though I added 2" to the nose to help with balance, it still took me ~6oz of weight to achieve CG. I also went up on batt size to 3S 3700mah. auw 39oz. wish I would have added 6" now. I think PaulVi added 4" but I haven't heard his auw yet.
Old Jan 25, 2008, 07:02 AM
aaron07 is offline
Find More Posts by aaron07
Joined Nov 2007
Can someone help clear a few grey clouds with my electrics set-up?
Set-up is TL50, 4S2P2100evolites, Mega 16 15 4 , CC60esc, Bec, Opto-isolator, cap, receiver ar7000, efliernz lipo alarm.
1.) Where is the CG on a TL50
2.) Do I need a bec if I use a receiver pack.
3.) Do I need a cap on the receiver if I run a receiver pack
4.) Should I forget the receiver pack and stick with seperate bec, opto-isolator, cap. (I already have all the bits)
5.) If I use the external bec, do I have to take the red wire out of the esc>receiver plug?
aaron07 is offline Find More Posts by aaron07
Old Jan 25, 2008, 09:34 AM
ab8ug is offline
Find More Posts by ab8ug
West Michigan
Joined Nov 2006
I think I can correctly answer a few of your questions.
1: CG is 8" to 8.25" as a starting point.
2: No
5: Follow the directions for your bec.
ab8ug is offline Find More Posts by ab8ug
Old Jan 25, 2008, 10:21 AM
reefboy is offline
Luke 12:7
reefboy's Avatar
USA, CA, Sunnyvale
Joined Nov 2006
aaron07,
I use a BEC on my TL50 even though I'm using a 2s 300 mah lipo rx pack. If you are using a 2s Lipo pack than the are roughly 8.4 volts fully charged. I would think you would want to bring the voltage back down to 5 or 6v depending on the BEC you use.
I am using the 2s lipo, bec and opto isolator on the ESC. When you are going as fast as you are having that extra assurance is a nice thing.
-Scott
Old Jan 26, 2008, 12:58 AM
Charger is offline
I B Chargin'
Charger's Avatar
Arizona
Joined Aug 2003
Atom1025 built TL 50 W/ 5t mega 16/15....4s
Got to maiden the other plane Adam built for me. CK was there to give some visual advice and launch for a happy maiden. I have 2 4t TL 50's and a the very lite one ( very fun set up ), so I decided to go with a 5t on 4s w/ 7X5 prop, for a little torqier set up, cuz I luvz the TL fity'z. I had a wing with a 5s before, and for my style of flying, it's fun........not blazzing speed, but nice long runs with some grab. The colors are very visable......I can almost fly it at night. If 2s 2p batts are dedicated to a TL 50 and strapped together........you're good to go with velcro. I got's lots of set ups and I like to keep my batts separate, so I can use them elsewhere. I asked Adam if he could come up with a mechanical locking system instead of velcro..........and he came up with this pin system that REALLY WORKS well. The pins slide into a coro flute. Velcro works fine for about the first 100 flights, then I pich a batt and realize I have to replace the velcro.
Old Jan 26, 2008, 01:51 AM
Diggs is offline
Find More Posts by Diggs
Not your average DiggsyBear
Diggs's Avatar
Raleigh, NC
Joined Dec 2006
Damn man, That wing is a looker!! That might be the best looking 50 I have seen yet. It is almost as purty as my 60 Adam built my 60 and did a fine job. Looks as if he kicked out another masterpiece. Enjoy!
Glad to hear the maiden went well!
Diggs
Diggs is offline Find More Posts by Diggs
Old Jan 26, 2008, 09:06 AM
twilkers is offline
twilkers's Avatar
Livermore, CA
Joined Jan 2007
very cool looking 50, Terry. Adam sure did a good job with the color scheme.
what was the auw on this one? I have a set of 50 cores and my original thought was to just replace the older beater, but this could be cool too.
tim
I got some Fan Fold what to build thread part II started by emoone!!! Don Sims Foamies (Kits) 188 Jan 23, 2010 08:28 PM
Build Log RiteWing 48-FT build thread theclaw Slope 46 Dec 09, 2007 08:53 AM
Mountain Models Tantrum Partial Build Thread.. Tram Parkflyers 142 Apr 03, 2004 10:41 PM
My Bobolink Build Thread (very Colibri like) Jim Poor Hand Launch 65 Dec 10, 2003 04:48 PM
Switchback re-build thread (or What the $#*& was that!) Biggles604 Parkflyers 17 Jun 23, 2003 09:34 PM
