Old Jan 10, 2008, 09:19 PM
Wingman65 is offline
Find More Posts by Wingman65
Build, Fly, Crash..Repeat
Wingman65's Avatar
St. Peters, Mo. USA
Joined Mar 2005
lol
Wingman65 is offline Find More Posts by Wingman65
Old Jan 11, 2008, 08:28 AM
glenbees is offline
Find More Posts by glenbees
Leeds/Bradford Leeds, Great Britain (UK)
Joined Jun 2003
demon 40 wings are joined together now i need to start and cut away electronics bay etc. what are the dimension for the trailing edge cut out after the motor mount for the prop . how far back from the trailing edge do you go before the motor mount is install, does it really matter
glenbees is offline Find More Posts by glenbees
Old Jan 11, 2008, 10:39 AM
kctrading is offline
Find More Posts by kctrading
kctrading's Avatar
Joined Mar 2005
Originally Posted by Wingman65
OH MY GOD!!! Just ran static test with whatt Meter. 17v, 43A, well over 600W Hope this Medusa can handle the power. Setup is
Medusa 28-40-2200
5.5x4.5 Apc prop
60 Lightflight ESC
Medusa 6v, 3a BEC
JR 6ul rx
5s A123 2300mah bat pack
First test, I had 6x4 sport prop and amps went up over 50 , changed to 5.5x4.5 and results were more reasonable. This sucker is gonna rock. Rite on...
Just remember it will unload in the air and amps will go down. Also the closer you come to matching the prop size in pitch (or go beyond it, over square) the less it will unload (ie 5.25x6.25) One of the best ways to test is with an (Eagle Tree) onboard system... hobbycity has the best prices on them...I'm going to get one soon myself!
Current Hobbycity.com prices (you need to be logged on for best prices)...
MicroPower V3 E-Logger $49.53
Watt's up meter: $37.46
Ken
kctrading is offline Find More Posts by kctrading
Old Jan 11, 2008, 06:22 PM
Wingman65's Avatar
St. Peters, Mo. USA
Joined Mar 2005
Thanks Ken, I live by the Watt meter but the data logger looks interesting.
Tony
Old Jan 11, 2008, 07:39 PM
Atom1025 is offline
Find More Posts by Atom1025
Fly me to the moon...
Atom1025's Avatar
Sacramento
Joined Jun 2005
It depends on the motor and batts you have in mind. Was there two main spar choices? Which one did you use? A general rule for me is to butt the rear end of the motor up to the spar.
If its a 6cell setup you want the motor further back.
Atom1025 is offline Find More Posts by Atom1025
Old Jan 11, 2008, 08:44 PM
klique is offline
Find More Posts by klique
Mum is the word!
Joined Jun 2003
A new vid
Hey guys hold on to your seat.
cross wind landings (3 min 48 sec)
klique is offline Find More Posts by klique
Old Jan 11, 2008, 11:02 PM
twilkers is offline
Find More Posts by twilkers
twilkers's Avatar
Livermore, CA
Joined Jan 2007
WOW, what a vid, very cool! this is the kind of stuff I'd prefer to see RC style; that is, with my feet on the ground!
twilkers is offline Find More Posts by twilkers
Old Jan 11, 2008, 11:27 PM
Tram is offline
Find More Posts by Tram
Fly it like you stole it..
Tram's Avatar
Florence, Al
Joined Oct 2000
Nice video klique..
The last 747 in that video was landing at Kai Tak in Hong Kong, they have since shut it down due to the horrible X-winds in there..
747 Crosswind Landing Hong Kong Kai Tak Airport (1998) (1 min 23 sec)
Tram is offline Find More Posts by Tram
Latest blog entry: Wow.. 3 years..
Old Jan 12, 2008, 02:19 AM
PaulVi is offline
Find More Posts by PaulVi
resU deretsigeR
PaulVi's Avatar
Dublin Ca
Joined Aug 2004
SF Bay Fleet week 2007
Baddddd..
PaulVi is offline Find More Posts by PaulVi
Old Jan 12, 2008, 02:50 AM
Tram is offline
Tram's Avatar
Florence, Al
Joined Oct 2000
I'm not sure but I'd say he's more like 25' off the bay..
Well, my wife said a box showed up today... Couple feet long, pretty stinkin' thin... I wonder if it's a TL50?
Old Jan 12, 2008, 09:51 AM
kctrading's Avatar
Joined Mar 2005
Anyone here going to the AMA Convention at Ont. CA Today? I'll be there at 10am to 4pm or so. I'll be wareing my black knight Dale Earnhardt T-shirt Hope to see some fellow RCG'ers there!
Ken
Old Jan 12, 2008, 11:01 AM
glenbees is offline
Joined Jun 2003
atom , using a mega 16/15/3 with 3s 3700 pack with the the one spar towards the back. i suppose with this set up i need to get the motor as far possibly .
Old Jan 12, 2008, 12:26 PM
Atom1025 is offline
Atom1025's Avatar
Sacramento
Joined Jun 2005
Sounds like your going lite, so yes, make sure the rear end of the motor is rite up on the spar. Push the servos as far forward as possible. A single layer of glass behind the cg and 2-3 layers ahead of the cg.
Old Jan 13, 2008, 01:25 PM
Wingman65's Avatar
St. Peters, Mo. USA
Joined Mar 2005
40" Demon maiden
Finally had a couple of days of good flying weather here in the heartland allowing me to maiden my new Demon. First, I went back over everything to make sure nothing was overlooked, high rate throws at 60% and low rates at 40%, neutral is flat from top of wing. Auw came in at 46.4oz , a little heavier than I had hoped but balanced at 7.5" without lead, though 3.5 oz of that weight is from a 6v hump pack used to power rx, since the A123's drop to nothing suddenly, a good rx power supply is important.
First flight was my tl50 to calm my nerves. The more I fly the 50 the better I like it, very smoothe and stable. After 8 mins of mixed flying, scrub off some speed and let glide back in. Finally getting the hang of putting it down where I want and not having to walk 50 yards to retrieve it Now, the moment of truth. There I stand, in the middle of a soccer complex, all by myself holding this bright new airplne in one hand, radio in the other, analyzing everything, is wind ok, no more excuses just throw the plane already. Throttle up, three steps and overhand throw...slight dip and up it goes, fast, very fast. Very steep climb from neutral control settings. I get it leveled out at about 50' and trim. needs a lot ot down elev to keep the nose down. Needs some thrust adjust. This thing is fast, cannot take my eye off it for a second as it covers a lot of ground and it sounds sweet. Controls are very touchy at speed, could be me or just need some tweaking but it goes where it is directed and vertical till I can barely see it. Now time to bring it down. I think Ritewings are harder to land than to launch, they go up easily but don't want to slow down enough to come in. Abut 4 laps around field scrubbing off speed, I leveled out and watched it descend and was a bit surprised as it was a very smoothe and stable approach and a nice sliding touchdown Life is good and the Demon is Rite.
A little fine tuning and this will be an awsome flying wing. Thanks Chris and all you RWA that have helped me cross over to the dark side.
Tony
Old Jan 13, 2008, 01:34 PM
PaulVi is offline
resU deretsigeR
PaulVi's Avatar
Dublin Ca
Joined Aug 2004
So i have been working on the FS48 tring to get it ready for AEF.. almost done but had to tink out the shipping with the stock fins, they are tall... so i cut half way through the coro so they will fold over then when i get to AZ i will slide a pice of carbon slide it down the flutes and then tape the cut side so it wont fold over..
I can now get it into a 2 inch high box...
I got some Fan Fold what to build thread part II started by emoone!!! Don Sims Foamies (Kits) 188 Jan 23, 2010 08:28 PM
Build Log RiteWing 48-FT build thread theclaw Slope 46 Dec 09, 2007 08:53 AM
Mountain Models Tantrum Partial Build Thread.. Tram Parkflyers 142 Apr 03, 2004 10:41 PM
My Bobolink Build Thread (very Colibri like) Jim Poor Hand Launch 65 Dec 10, 2003 04:48 PM
Switchback re-build thread (or What the $#*& was that!) Biggles604 Parkflyers 17 Jun 23, 2003 09:34 PM
