Old Jan 07, 2008, 11:03 PM
reefboy is offline
Find More Posts by reefboy
Luke 12:7
reefboy's Avatar
USA, CA, Sunnyvale
Joined Nov 2006
Impeccable build wingman!
Can't wait to hear about your maiden.
reefboy is offline Find More Posts by reefboy
Old Jan 08, 2008, 12:44 AM
ziggx is offline
Find More Posts by ziggx
certified insomniac
ziggx's Avatar
Durban SouthAfrica
Joined Feb 2007
Waiting for the rite wings to arrive
I have ordered rite wing
Looking through your build threads I see that you guys always top hing
but lately on my wings I have been bottom hinging. I find that I can use the lowest hole on my moving surface horns so my exit point is much lower and futher back so less chance of getting flex on the push rods. I can then also get full servo throws. Maybe the back spar will get in the way. But I know that it is not alway recommed on some airfoils. What do you guys recommend?
Cheers
Dion
ziggx is offline Find More Posts by ziggx
Old Jan 08, 2008, 12:55 AM
klique is offline
Find More Posts by klique
Mum is the word!
Joined Jun 2003
Dion i have ben doing some bottom hinging,it works great.
Your wings are on the way buddy. Get ahold of me when they arive.
I had to slice off the 60 wing tips so you will have to attach them with some spray glue befor you spar them.Otherwise it would have cost 400.00USD to ship them. TO SA
Ck
Cheers
Dion
klique is offline Find More Posts by klique
Old Jan 09, 2008, 07:04 AM
aaron07 is offline
Find More Posts by aaron07
Joined Nov 2007
I am currently building a TL50 and I have just realised that my motor mount is 2mm left off centre.
Should I re-drill holes for the motor mount?
I am not sure what I should do.......
aaron07 is offline Find More Posts by aaron07
Old Jan 09, 2008, 07:57 AM
Atom1025 is offline
Find More Posts by Atom1025
Fly me to the moon...
Atom1025's Avatar
Sacramento
Joined Jun 2005
I wouldn't stress off it, I doubt it will cause any noticeable problems. Drilling the holes is a quick fix so why not. But again I doubt a couple mm will be an issue.
Atom1025 is offline Find More Posts by Atom1025
Old Jan 09, 2008, 08:48 AM
TaSaJaRa is offline
Find More Posts by TaSaJaRa
More props are better than One
TaSaJaRa's Avatar
United States, AL
Joined Nov 2004
Originally Posted by Wingman65
Just about finished with my Demon Very happy with how it is coming out, not sure if I like the coloring scheme but I know I will be able to see it. Can't wait to fly it, It's my first A123 powered airplane so it will be a learning experience. Here are a couple of pics of the top. Tried to do something different.
I like it the Plane looks GREAT...
TaSaJaRa is offline Find More Posts by TaSaJaRa
Old Jan 09, 2008, 01:45 PM
glenbees is offline
Find More Posts by glenbees
Leeds/Bradford Leeds, Great Britain (UK)
Joined Jun 2003
well i got my demon 40 today , going to use mega 16/15/3 with a 3s 4000 pack. my first question is my batt pack , rated at 12c constant and 15c bursts going to be okay, thankyou for any comments
glenbees is offline Find More Posts by glenbees
Old Jan 09, 2008, 05:45 PM
Atom1025 is offline
Atom1025's Avatar
Sacramento
Joined Jun 2005
Yeah the pack will be at its limits if depending on the prop choice.
Amps will be around 35 with a 5x5,42ish with a 5.5x4.5, 40ish with a 6x3 and nearly 50amps on a 6x4
Adam
Old Jan 09, 2008, 06:34 PM
msmith is offline
Find More Posts by msmith
Use whatcha got!
msmith's Avatar
Metairie, LA
Joined Sep 2000
A123 folks... I had setup a buy for a 10cell pack and planned on making two 5S packs until I remembered that I've only got 4S capabilities with my cellpro...
So... without spending money on another charger... I could go with two 4S packs and have 2 cells leftover for something small and fun, or...
I'm slowly but surely compiling parts for my 40" build but want to make sure I'm not shooting myself in the foot...
Any thoughts? suggestions? Is 4S A123 enough for a Het 4 or a Het 2w25? or a JGF 450?
thanks,
mike
msmith is offline Find More Posts by msmith
Old Jan 09, 2008, 06:59 PM
reefboy is offline
Luke 12:7
reefboy's Avatar
USA, CA, Sunnyvale
Joined Nov 2006
Mike,
I made the same mistake as you. I made an adapter to charge 2 cells first and then charged the remaining 3. Very doable but takes 2x as long to charge a pack. You also have to be diligent to make sure you have charged all 5 cells.
Once you fly with 5s it might raise the priority for purchasing a capable charger once you see how fun a 5s setup is.
-Scott
Old Jan 09, 2008, 07:53 PM
msmith is offline
Use whatcha got!
msmith's Avatar
Metairie, LA
Joined Sep 2000
Originally Posted by reefboy
...Once you fly with 5s it might raise the priority for purchasing a capable charger once you see how fun a 5s setup is...
Scott - I'm worried about that exact scenario...
I'm on the fence to buy the new 10S Cellpro, but I'm already shelling out a bill (roughly) for the dewalt pack... then the charger would be another $200 (roughly).
I'm not interested in some kludgey, experimental, buy a generator to power a switching lab quality power supply, solution...
I like my current 'plug and play' charging solution and am considering still going with the 4S packs for now and then upgrading everything down the road when the technology gets a bit cheaper...
So... anyone running 4S?? what motor/prop and how is the performance?
thx,
mike
Old Jan 09, 2008, 08:30 PM
PaulVi is offline
Find More Posts by PaulVi
resU deretsigeR
PaulVi's Avatar
Dublin Ca
Joined Aug 2004
you could always go 6s then you could charge both 3s packs at the same time...
PaulVi is offline Find More Posts by PaulVi
Old Jan 09, 2008, 11:58 PM
Wingman65 is offline
Find More Posts by Wingman65
Build, Fly, Crash..Repeat
Wingman65's Avatar
St. Peters, Mo. USA
Joined Mar 2005
Thanks Craig and welcome back
Wingman65 is offline Find More Posts by Wingman65
Old Jan 10, 2008, 08:26 PM
jstoll is offline
Find More Posts by jstoll
cant leave things stock
jstoll's Avatar
United States, KY, Lexington
Joined Feb 2007
hey there guys
here Im starting the TL54 I got from chris a little while ago
Im gona run it on 4S lipo 3300mah 25-40C maybe the ARC long can 2 turn or 1.5 or maybe even a slower motor with a bigger prop.... I dont know but Ill try to do a nice artistic covering job & if I have any technique to share I certainly will
Ive gotten really good at covering them just havent gotten too artistic yet
take care
JAK
jstoll is offline Find More Posts by jstoll
Old Jan 10, 2008, 09:14 PM
PaulVi is offline
resU deretsigeR
PaulVi's Avatar
Dublin Ca
Joined Aug 2004
Look it has a cross the heart bra strap...
I got some Fan Fold what to build thread part II started by emoone!!! Don Sims Foamies (Kits) 188 Jan 23, 2010 08:28 PM
Build Log RiteWing 48-FT build thread theclaw Slope 46 Dec 09, 2007 08:53 AM
Mountain Models Tantrum Partial Build Thread.. Tram Parkflyers 142 Apr 03, 2004 10:41 PM
My Bobolink Build Thread (very Colibri like) Jim Poor Hand Launch 65 Dec 10, 2003 04:48 PM
Switchback re-build thread (or What the $#*& was that!) Biggles604 Parkflyers 17 Jun 23, 2003 09:34 PM
