Old Jan 06, 2008, 05:31 PM
PaulVi is offline
Find More Posts by PaulVi
resU deretsigeR
PaulVi's Avatar
Dublin Ca
Joined Aug 2004
MD in a 36 inch Demon
I finnaly got things worked out on the demon 36 i have the motor below in it and it is a sweet flting wing with this motor
Im running 2 2s 3300 20c packs in a 4s config I have a custom T mount that i built for the komodo motor
I used the Micro Dan EDF 8mm mount to go from the Tmount to the MD motor
and an apc 5.5 x 4.5 prop
Im guessing im in the high 90's with it.. maybe over 100 I will not be able to speed test it untill AEF i do not want to fly (crash) the wings im taking so i have a few to take
I will post some pics and some hard amp specks
Custom Motor
http://www.gobrushless.com/shop/ind...f=MD2505-C-2535
The MicroDAN 2505 "Custom Series" are custom wound to suit certain requirements.This motor is a slightly lower Kv then the standard SPEED motor.
This motor is a 2535Kv version built for the APC 5x5 & 6x5.5 prop running on 4s Lipo.
18 Turns, 23AWG, DLRK, Delta, 14 magnet poles
Performance Data:
No Load 25350 RPM, 10V, 1.67A,
APC 6x5.5, 19800 RPM, 12.21V, 39A, 32oz thrust.
APC 5x5, 24400 RPM, 13V, 28A, 19oz thrust.
PaulVi is offline Find More Posts by PaulVi
Old Jan 06, 2008, 06:04 PM
Atom1025 is offline
Find More Posts by Atom1025
Fly me to the moon...
Atom1025's Avatar
Sacramento
Joined Jun 2005
Whats the AUW of the bird and how did you find the vertical performance to be?
Atom1025 is offline Find More Posts by Atom1025
Old Jan 06, 2008, 06:14 PM
PaulVi is offline
resU deretsigeR
PaulVi's Avatar
Dublin Ca
Joined Aug 2004
AUW is 36.1 OZ and it is near vertical.. from flat if i just fly flat and level and turn the nose up it will climb at about a 80% climb till it is to small to see..
Inverted is flat and level so i guess i dont need to add any weight.. it took a tweek on the mount with a bit of down thrust then 2 clicks left and flew hands off
Old Jan 06, 2008, 06:15 PM
reefboy is offline
Find More Posts by reefboy
Luke 12:7
reefboy's Avatar
USA, CA, Sunnyvale
Joined Nov 2006
Thanks Adam!
Not sure if many people have thanked Adam for the time he has spent on documenting the Ritewing build process and trying to keep a fairly cetnralized thread. I wanted to say thanks. I know you have spent quite a bit of time documenting your own builds and I especially have found it very helpful!
I've been working on my Mini Demon over the last few weeks and reference this thread as I go. Thanks a bunch! Thanks to all the others that have documented your builds as well! Hopefully I'll be glassing one night soon.
Also, thanks to CK for making such outstanding products! Keep up the good work.
reefboy is offline Find More Posts by reefboy
Old Jan 06, 2008, 06:17 PM
PaulVi is offline
resU deretsigeR
PaulVi's Avatar
Dublin Ca
Joined Aug 2004
I noticed I did not mention heat.. It is cold as heck today but it still came down as cold as it went up so it is getting plenty of air flow.
Old Jan 06, 2008, 06:20 PM
Atom1025 is offline
Atom1025's Avatar
Sacramento
Joined Jun 2005
Great news Paul! Finances have been holding me back from experimenting with the MD myself. After much discussion with Methos I was confident that the MD would be a winner! That custom wind will be a winner on the bigger stuff.
Old Jan 06, 2008, 06:21 PM
PaulVi is offline
resU deretsigeR
PaulVi's Avatar
Dublin Ca
Joined Aug 2004
Ya the speed wind maybe on 3s and a light build the custom on a 40 or smaller 4s ship
Static tests i took just now
MD 2505 2535kv
static specs
12.83 vdc
35.6 amps
456 watts
23612 rpm
This was not on freash packs but rather after i had been out flying for 10 minutes.. so starting specs static would only be better..
Old Jan 06, 2008, 06:36 PM
methos is offline
Find More Posts by methos
methos's Avatar
Canada
Joined Jun 2006
Well on my 36" Sportster I've been running the MicroDan 2505 speed wind motor on an APC 5x5 prop on 4s for about 6 to 8 flights now and it's working awesome.
It's pulling 650 - 660 watts at 44 - 46amps I don't know exactly how to calculate the pitch speed, but I believe that it is in the 150mph range.
It's definitely pushing the Sportster past 120mph possibly as high as 130, but I'm not sure... I have no way to truly test it.
The vertical is unlimited... as in 90mph straight up
Ed
methos is offline Find More Posts by methos
Old Jan 06, 2008, 06:50 PM
PaulVi is offline
resU deretsigeR
PaulVi's Avatar
Dublin Ca
Joined Aug 2004
rpm x pitch (in inches) x 0.000947
in my case bench test on a almost dead pack
23610 x 4.5 x .000947 = 100.61
this is all static and drag and wind and every thing makes a diff. but i should be doing about 115 on the fully charged pack (estimate of rpm) and down to 100 on the used pack.
Using this we can say how fast we want to go what pitch prop we want to use and it will tell us the static rpm we need to get there in a perfect world.
Again so many variables play on this that your mileage will vary
(Mph / Pitch) / .000947
Pitch 5
MPH = 125
RPM = 26400
Pitch 4.5
MPH 125
RPM 29333
The diamiter of the prop only really plays in thrust as does the pitch and or the ability of a motor ot spin a prop at a particular RPM.
the speedster is a thinner foil so less drag.. and I think your KV is higher so the 29.5k rpm is possible so you might be right..
have a look here to play with the numbers
http://www.rcpro.org/rccalc/PitchSpeed.aspx
I still think with drag and my bumpy flying in something less than pitch speed..
Old Jan 07, 2008, 08:40 PM
Wingman65 is offline
Find More Posts by Wingman65
Build, Fly, Crash..Repeat
Wingman65's Avatar
St. Peters, Mo. USA
Joined Mar 2005
40" Demon bulid
Just about finished with my Demon Very happy with how it is coming out, not sure if I like the coloring scheme but I know I will be able to see it. Can't wait to fly it, It's my first A123 powered airplane so it will be a learning experience. Here are a couple of pics of the top. Tried to do something different.
Wingman65 is offline Find More Posts by Wingman65
Old Jan 07, 2008, 09:06 PM
Atom1025 is offline
Atom1025's Avatar
Sacramento
Joined Jun 2005
I think it looks fantastic! Shouldn't have any trouble spotting that one. Great job!
Old Jan 07, 2008, 09:44 PM
twilkers is offline
Find More Posts by twilkers
twilkers's Avatar
Livermore, CA
Joined Jan 2007
very cool color scheme! should be very visible. fantastic!
twilkers is offline Find More Posts by twilkers
Old Jan 07, 2008, 09:51 PM
klique is offline
Find More Posts by klique
Mum is the word!
Joined Jun 2003
Wing,You shure have the touch
It is very nice to see such good builders in here.
You are Rite in the zone buddy,When is The maidin?
Spring?LOL
ck
klique is offline Find More Posts by klique
Old Jan 07, 2008, 10:02 PM
Wingman65's Avatar
St. Peters, Mo. USA
Joined Mar 2005
Thanks guys, appreciate the kind words. Your probably right Chris, T-storm and tornado warnings tonight, very strange.
Old Jan 07, 2008, 10:57 PM
Wingman65's Avatar
St. Peters, Mo. USA
Joined Mar 2005
OH MY GOD!!! Just ran static test with whatt Meter. 17v, 43A, well over 600W Hope this Medusa can handle the power. Setup is
Medusa 28-40-2200
5.5x4.5 Apc prop
60 Lightflight ESC
Medusa 6v, 3a BEC
JR 6ul rx
5s A123 2300mah bat pack
First test, I had 6x4 sport prop and amps went up over 50 , changed to 5.5x4.5 and results were more reasonable. This sucker is gonna rock. Rite on...
I got some Fan Fold what to build thread part II started by emoone!!! Don Sims Foamies (Kits) 188 Jan 23, 2010 08:28 PM
Build Log RiteWing 48-FT build thread theclaw Slope 46 Dec 09, 2007 08:53 AM
Mountain Models Tantrum Partial Build Thread.. Tram Parkflyers 142 Apr 03, 2004 10:41 PM
My Bobolink Build Thread (very Colibri like) Jim Poor Hand Launch 65 Dec 10, 2003 04:48 PM
Switchback re-build thread (or What the $#*& was that!) Biggles604 Parkflyers 17 Jun 23, 2003 09:34 PM
