Old Jan 03, 2008, 06:22 PM
Atom1025 is offline
Find More Posts by Atom1025
Fly me to the moon...
Atom1025's Avatar
Sacramento
Joined Jun 2005
Mounts are not done yet. should be soon!
A slice with the MD would be a beautiful pairing! That will be one light yet insanely powered bird!
Stay tuned for more mount info.
Atom1025 is offline Find More Posts by Atom1025
Old Jan 03, 2008, 06:27 PM
Wingman65 is offline
Find More Posts by Wingman65
Build, Fly, Crash..Repeat
Wingman65's Avatar
St. Peters, Mo. USA
Joined Mar 2005
Thanks Atom. Any place besides Go Brushless for Microdan or is that it?
Wingman65 is offline Find More Posts by Wingman65
Old Jan 03, 2008, 06:55 PM
Atom1025 is offline
Atom1025's Avatar
Sacramento
Joined Jun 2005
Theres others but Gobrushless is Home of the Micro Dan, not sure if its Dans sit but he has a lot to do with it. http://e-foamies.com/store/catalog/ is one site and there is others. If its a lowere price you are in search of there isn't one. the cheapest is 54.99.
Adam
Old Jan 03, 2008, 07:00 PM
Wingman65's Avatar
St. Peters, Mo. USA
Joined Mar 2005
Thnx, Looks like a sweet, lightweight motor and havn't heard any neg press on it it. That new mount would make it perfect for wing app.
Old Jan 04, 2008, 06:01 AM
Micro Dan is offline
Find More Posts by Micro Dan
www.gobrushless.com
North Carolina
Joined Jan 2005
Adam
gobrushless.com and MicroDAN are both owned and operated by me and the rest of the crew.
finishing up the mounts they should ship next week.
Dan
Micro Dan is offline Find More Posts by Micro Dan
Old Jan 04, 2008, 09:29 AM
Diggs is offline
Find More Posts by Diggs
Not your average DiggsyBear
Diggs's Avatar
Raleigh, NC
Joined Dec 2006
Which MicroDan motor are you guys using or considering for this project?
Diggs
Diggs is offline Find More Posts by Diggs
Old Jan 04, 2008, 01:23 PM
PaulVi is offline
Find More Posts by PaulVi
resU deretsigeR
PaulVi's Avatar
Dublin Ca
Joined Aug 2004
Speed Motor
http://www.gobrushless.com/shop/inde...&ref=MD2505-SP
The MicroDAN 2505 "Speed Series" enables parkflyer jets to achieve speeds over 100 mph by producing over 16 oz. of thrust at less than 25 amps on 3s lithium polymer packs. These are also the motor of choice for hydrofoam flying boats on 2s lithium polymer packs.
Need insane speed? Use a 4s lithium polymer pack and hold on while it turns your 4" prop at over 30,000 RPMs!
Features include dual color anodized alum. endbell with massive cooling holes, separate anidized alum. motor mount with dual set screws, hardened steel shaft with retaining clip, and an integrated prop saver using the supplied anodized alum. screws and o-ring.
Specifications:
Stator Width: 25mm
Stator Height: 5mm
Stator Poles: 12
Magnet Poles: 14
Weight: 34 grams
Recommended Props: GWS 8x4 HD (2s), ZAGI 5.1x4.9 (3s), or APC 4.25x4.24 (4s)
Recommended Batteries: 900 - 2000 mAH
or
Custom Motor
http://www.gobrushless.com/shop/inde...=MD2505-C-2535
The MicroDAN 2505 "Custom Series" are custom wound to suit certain requirements.This motor is a slightly lower Kv then the standard SPEED motor.
This motor is a 2535Kv version built for the APC 5x5 & 6x5.5 prop running on 4s Lipo.
18 Turns, 23AWG, DLRK, Delta, 14 magnet poles
Performance Data:
No Load 25350 RPM, 10V, 1.67A,
APC 6x5.5, 19800 RPM, 12.21V, 39A, 32oz thrust.
APC 5x5, 24400 RPM, 13V, 28A, 19oz thrust.
PaulVi is offline Find More Posts by PaulVi
Old Jan 04, 2008, 07:28 PM
Wingman65's Avatar
St. Peters, Mo. USA
Joined Mar 2005
That is the motor I was looking at Paul, thanks. I also saw a thread where you had the new prototype mount that really got me thinking about this slice I have to build. Curse these damn Ritewings, I can't finish one before thinking about the next,
Old Jan 04, 2008, 08:37 PM
kctrading is offline
Find More Posts by kctrading
kctrading's Avatar
Joined Mar 2005
Originally Posted by Wingman65
Not sure how much the Monokote adds in weight, but if I keep it light I think I can get this Demon on 5s finished at or real close to 40oz AUW. That certainly makes 7s doable in the 45oz range.
Hey Wngman65, You're not going to use those push on terminals on the motor esc are you? I've had a couple 3.5mm fail with resistance from getting hot...I always solder all my connections now for max power.
Looks like you are doing a great job on the build...looking forward to see a video soon!
Ken
kctrading is offline Find More Posts by kctrading
Old Jan 04, 2008, 08:39 PM
kctrading's Avatar
Joined Mar 2005
Hey CK got the 40" Demon lite today with the motor...very, very high quality kit...I love the air foil and can see why it's so fast and tracks well!
I'll be reviewing the CD and see what I need to collect to start the build!
Ken
Old Jan 04, 2008, 08:44 PM
PaulVi is offline
resU deretsigeR
PaulVi's Avatar
Dublin Ca
Joined Aug 2004
Ken
Hey KC if you have problems finding the henry's down your way let me know the local home depot carries it..
kctrading's Avatar
Joined Mar 2005
Originally Posted by JustGoFly
Ken - 700 Watts is alot higher than the rating of the motor. We have 550's coming out that will run a 6x4 on 5S. That may be more your style.
I run my Demon on 5S on the 550 and full throttle the whole time the motor comes down cold. I upgraded 60 6x5.5 and still cold. 6S became very difficult to launch. I'll see if I can post some video.
Vinnie
Hey Vinnie, sorry I missed your post! I know I was way over proped on that motor. On 3S it was a lot more fun on the 500T bell with a 7x5 prop...got to love 40+ oz of thrust!
Yes, I would love to see that video
Ken
Old Jan 04, 2008, 08:46 PM
Wingman65's Avatar
St. Peters, Mo. USA
Joined Mar 2005
Hey Ken, thanx. I use the Mpi bullet connectors, I'm always changing my setups. I think they are O.k. for motor as it is not constant. I would not use them for batt. I followed your wild wing thread from beginning, mine finally broke in half and flapped to the ground last summer. You'll love the ritewing, if built right, it flies tight and loves speed.
Tony
Old Jan 04, 2008, 08:49 PM
Wingman65's Avatar
St. Peters, Mo. USA
Joined Mar 2005
Congrats Ken, that dvd will change how you build wings. Watch the flying dvd for inspiration
Tony
Old Jan 04, 2008, 11:27 PM
PaulVi is offline
resU deretsigeR
PaulVi's Avatar
Dublin Ca
Joined Aug 2004
Yo Dirtbag
So CK do you know what this is.....
I still have to get to RS to get the connectors unless you want to do the final wire to the motrs I can send the color chart for cable to stepper.. Or do you want to wait till i get the connectors.. RS only has 2 sets M/F and i need 4 one for each motor.
I got some Fan Fold what to build thread part II started by emoone!!! Don Sims Foamies (Kits) 188 Jan 23, 2010 08:28 PM
Build Log RiteWing 48-FT build thread theclaw Slope 46 Dec 09, 2007 08:53 AM
Mountain Models Tantrum Partial Build Thread.. Tram Parkflyers 142 Apr 03, 2004 10:41 PM
My Bobolink Build Thread (very Colibri like) Jim Poor Hand Launch 65 Dec 10, 2003 04:48 PM
Switchback re-build thread (or What the $#*& was that!) Biggles604 Parkflyers 17 Jun 23, 2003 09:34 PM
