Thanks again Chris. #131 is up~
http://allthingsthatfly.com/ |
mw |
Really?!
I've had two 28x58 motors, one ARC and the other a Medusa, with bent shafts. Tried heating to the point I was worried about the magnets and then pressing/smacking till the shafts bent. No luck. A long 4 pole motor has a lot of gluing surface for the shaft-rotor core joint. Maybe the standard 480 size is just at the point where it can be done. I did wind up successfully scratch-building rotors for both motors, but it sure was a pain. |
So I finally took my night flier IYF44 out at nite. I had three flights on it during the day so I was comfortable to take it out at night.
I originally ran the 8040 and it could not handle the rpms of the microdan so I had to stay under half throttle. I swapped to a 7x5E, which was a big mistake. So I threw it up and started giggling like a schoolgirl. She looked beautiful!!! IMHO it was easier to see then any plane I have ever flown in the sunlight. Orientation was no issue even at great distance. I could not manage to pull back the left stick! I tried but it had great thrust and power so I was whipping it! I never intended this bird to move this fast........... bout two mins into the flight I take it up high, I put it into a spin to bring it back down, couple spins and I see the top and let off the roll to do a dive towards the camera, you can here prop winding out and picking up rpms........ Then that sound that you never forget, flit,flit,flit flit, FLAP!!!!! It was amazing, lights went out ans I could see the body floating suspiciously slow down to earth, I start to give chase as its still going down. bout a hundred yard dash and I almost get to it as its coming to rest, in between two levees thats for water runoff....There was water in it!!!!! My plane came to rest aside the levee mere feet from water that has more bacteria then Courtney Loves "Hole". I scream out "It missed the Water!!!!" picked it up to inspect the damage in the dark and it was tore down the middle. No biggie its just foam........Then I notice the motor is gone(including mount) So I look inside and the powersystem is stripped clean!!!! Only thing left was my receiver and BEC![]() Still ecstatic from one of the most exciting flights I have had in at least a year, I write off the stuff as a loss and start planning my next nite flier. Eric says he has a flashlite and says lets take a look. I also had Josh's Niteflier that I was show and telling so I powered up the lights and started off down the water ditch lighting it up with Joshs wing ,LOL! Eric took the high road with his mag and the hunt was on. still about 50-100' from the touchdown I am already searching.... My god there's my thunderpower 910 3s that runs my radio and lights!!! What are the odds. So I mark the find and look in the immediate area for the rest..... Nothing in a 10' circle ![]() Erics up on the levee which has a beaten path. Either side of the path had foot tall grass.... The path itself had short grass. As he lit the trail to see he came up to where the TP was found and sitting parallel to the path, almost centered was a foot long string of wire, esc, and motor. ![]() I lost an old tired 18c 2100 2s but thats a meazily sacrifice to the aerogods compared to a MD2505 and cc 36. Heres the great news!!! Its on video!!!! The flap can be clearly seen and heard in the vid!!!! You can almost see the wingtips touch just as the lights go out! Stay tuned..... So what went wrong........ If ya'all recall I used a tiny little 1/8" carbon rod for a spar that was bowed.... Ummmmm yea dont use anything that small
That was sooo cool
I can now see exactly why people are interested in the "night fliers"I will try to get the video up in the next day or so. It won't be as good as being there in person, but I think we got some good footage. I should have kept the video running during the search to show just how lucky Adam was to get the gear back. |
| Thread Tools | |
| I got some Fan Fold what to build thread part II started by emoone!!! | Don Sims | Foamies (Kits) | 188 | Jan 23, 2010 08:28 PM |
| Build Log RiteWing 48-FT build thread | theclaw | Slope | 46 | Dec 09, 2007 08:53 AM |
| Mountain Models Tantrum Partial Build Thread.. | Tram | Parkflyers | 142 | Apr 03, 2004 10:41 PM |
| My Bobolink Build Thread (very Colibri like) | Jim Poor | Hand Launch | 65 | Dec 10, 2003 04:48 PM |
| Switchback re-build thread (or What the $#*& was that!) | Biggles604 | Parkflyers | 17 | Jun 23, 2003 09:34 PM |
