Old Feb 23, 2010, 01:49 PM
Diesel 48 is offline
Find More Posts by Diesel 48
Diesel 48's Avatar
USA, MI, Zeeland
Joined Sep 2006
What can I say? When this slacker cleans up, he cleans up really well!
Diesel 48 is offline Find More Posts by Diesel 48
Old Feb 23, 2010, 04:37 PM
jims123 is offline
Find More Posts by jims123
jims123's Avatar
USA, CA, San Diego 92120
Joined Oct 2007
Originally Posted by Atom1025 View Post
Jim during your venture the IYF44 did not exist, this one has your name written on it. Mine slopes awesome, I just leave the prop on and it glides great. Much tamer then demons and tl's. Check youtube for vids if you have not seen them.
Will do.. thanks
jims123 is offline Find More Posts by jims123
Old Feb 24, 2010, 12:22 PM
jpinn is online now
Find More Posts by jpinn
jpinn's Avatar
United States, CA, Poway
Joined Jan 2006
Just got my new Demon from CK. Couple of questions.
First, the sparring appears different, there is one thick carbon tube spar, I am assuming this goes between the wing halves. And there are several white fiberglass rods. How should these be oriented? Also, does the main spar go in the forward or aft hole?
Second, I was under the impression that there was a better way to lay down the covering than just using 3m-90 spray for a speedy wing. How is this done using PU or gorilla glue?
thanks.
jpinn is online now Find More Posts by jpinn
Old Feb 24, 2010, 01:54 PM
Mark Wood is online now
Find More Posts by Mark Wood
characters welcome!
Mark Wood's Avatar
United States, CA, Bear Valley Springs
Joined Feb 2000
Did you get the DVDs and watch them?
mw
Mark Wood is online now Find More Posts by Mark Wood
Old Feb 24, 2010, 02:08 PM
jpinn is online now
jpinn's Avatar
Joined Jan 2006
I have a dvd from over a year ago, has anything changed on them? if not I will just rewatch it
Old Feb 24, 2010, 02:35 PM
PaulVi is offline
Find More Posts by PaulVi
resU deretsigeR
PaulVi's Avatar
Dublin Ca
Joined Aug 2004
Some changes the new DVD is like 9 month over due to be done... I have all the raw video edited but....
Search on adam's posts he has a few build threads that cover the updates. ck shows a few of them in the ritewing vender thread as well.. but the basic build is the same just some fine tuning.. mostly in the light builds..
PaulVi is offline Find More Posts by PaulVi
Old Feb 24, 2010, 03:46 PM
jpinn is online now
jpinn's Avatar
Joined Jan 2006
I still don't understand how to use the small white rods. When I built my TL-50 I had 3 carbon spars, now I only have one carbon spar and 4 much thinner white rods.
Can anyone help me?
Old Feb 24, 2010, 05:04 PM
hawkz is online now
Find More Posts by hawkz
USA, CA, San Diego
Instead of having 3 carbon rods in an "A" formation, you can still use the carbon spar in one of the pre-cut holes. If you want a light build, then use the hole closest to the nose and you can cut in your motor mount area a little more. If you're looking for a heavier build, then use the rear hole. Then you can use two of the white rods on top and two on bottom, still making the "A" formation.
hawkz is online now Find More Posts by hawkz
Old Feb 24, 2010, 06:04 PM
klique is offline
Find More Posts by klique
Mum is the word!
Joined Jun 2003
lol
http://www.youtube.com/watch?v=C9PEfX78YZE
klique is offline Find More Posts by klique
Old Feb 24, 2010, 08:14 PM
Atom1025 is offline
Find More Posts by Atom1025
Fly me to the moon...
Atom1025's Avatar
Sacramento
Joined Jun 2005
I was hesitant about the glass rods, I used them on the last build just as you described, and wow!!! Very stiff! Much stiffer then the flat stock, and much lighter then the arrow shaft.
Atom1025 is offline Find More Posts by Atom1025
Old Feb 25, 2010, 11:44 AM
Danjuan is offline
Find More Posts by Danjuan
Huh?! well waddayouknow!?
Slackramento ,CA
Joined Jul 2006
slackers!
Danjuan is offline Find More Posts by Danjuan
Old Feb 25, 2010, 09:28 PM
jpinn is online now
jpinn's Avatar
Joined Jan 2006
Demon build progress
I now understand the fiberglass rods after taking to CK on the phone, thanks for the help!
So they make a relative I beam with the foam. Instead of single carbon shafts through the wing, you install one rod in the top and one in the bottom. The one in the bottom goes all the way from root to tip. This was the first one I installed. The top ones go from the servo location to the tip, so I have not yet glued them in until I position my servos.
One question I had was about the motor placement and cutout. CK recommended using the front spar location (with the arc 28-47-1.5 motor). Then I lined up the snap off line on the engine mount and traced it. This seems to make a huge cutout for the motor. Please let me know if it looks right in the picture. I am afraid that there will be no space for an electronics bay behind the battery one. Could the electronics be placed to the sides?
thanks for the input.
Old Feb 25, 2010, 09:31 PM
klique is offline
Mum is the word!
Joined Jun 2003
Move the motor back am inch or so, even if you have to ad some nose weight she will rock.
Old Feb 26, 2010, 12:07 AM
jpinn is online now
jpinn's Avatar
Joined Jan 2006
I moved the placement of the motor mount back by about an inch. It is now 9.5" from the nose to the front of the motor mount. I am only cutting out about 1.5" from the root for the motor cutout.
I will be glassing the front of the bottom section tonight with riteweave and PU for ultra strength.
jpinn is online now
jpinn's Avatar
Joined Jan 2006
the updated lines are in green.
I got some Fan Fold what to build thread part II started by emoone!!! Don Sims Foamies (Kits) 188 Jan 23, 2010 08:28 PM
Build Log RiteWing 48-FT build thread theclaw Slope 46 Dec 09, 2007 08:53 AM
Mountain Models Tantrum Partial Build Thread.. Tram Parkflyers 142 Apr 03, 2004 10:41 PM
My Bobolink Build Thread (very Colibri like) Jim Poor Hand Launch 65 Dec 10, 2003 04:48 PM
Switchback re-build thread (or What the $#*& was that!) Biggles604 Parkflyers 17 Jun 23, 2003 09:34 PM
