Old Jan 01, 2008, 08:09 PM
punkrockd is offline
Find More Posts by punkrockd
Purples a fruit
punkrockd's Avatar
United States, CA, Walnut Creek
Joined Aug 2006
if you let it dry it is sandable but i think heat will soften it. i've taken little bumps out when applying covering.
punkrockd is offline Find More Posts by punkrockd
Old Jan 01, 2008, 08:51 PM
PaulVi is offline
Find More Posts by PaulVi
resU deretsigeR
PaulVi's Avatar
Dublin Ca
Joined Aug 2004
Originally Posted by e2346437
What would be the rite method to fix the window? Henry cloth and 3M 90? Patch it up with a little strip of Monokote? CA? GOOP?
Sorry Paul, I've had days like that too!
Atctually 3m storage tape on the inside will have to do till summer when i replave it..
PaulVi is offline Find More Posts by PaulVi
Old Jan 01, 2008, 08:59 PM
Wingman65 is offline
Find More Posts by Wingman65
Build, Fly, Crash..Repeat
Wingman65's Avatar
St. Peters, Mo. USA
Joined Mar 2005
Bad thing about it being a Miata is you have to replace the whole top.
Wingman65 is offline Find More Posts by Wingman65
Old Jan 01, 2008, 09:30 PM
PaulVi is offline
resU deretsigeR
PaulVi's Avatar
Dublin Ca
Joined Aug 2004
Actuall no.. it is a Robins top so it can just have the window section replaced.. still a hassle but cheaper than the new top from 2 years ago...
Im going to have to get a larger vehicale anyways the miata is a pain to get wings and such to the flying field..
Old Jan 01, 2008, 09:57 PM
Wingman65's Avatar
St. Peters, Mo. USA
Joined Mar 2005
Glad to hear that I'm getting ready to make my elevons and for the forty and don't know if I should round the outer tip or not. Is there any significant advantage in round over squared off? It is not uncommon to see them both ways. Thanks
Tony
Old Jan 01, 2008, 10:39 PM
jstoll is offline
Find More Posts by jstoll
cant leave things stock
jstoll's Avatar
United States, KY, Lexington
Joined Feb 2007
"What is done to cool the ESC and other electronics in these wings ? Anything ? Seems to me the ESC will get pretty hot closed up in that compartment."
I put a scoop over the hole I leave over the ESC & then usually leave an exit for theair as well but have had great results in cooling even with no exit
the blue plane & the red plane both ended up with scoops & I guess like my last 4 or 5 have the pix of those wings are before they were completed
the red slice dosent have elevons in that pic
take care
JAK
jstoll is offline Find More Posts by jstoll
Old Jan 01, 2008, 11:01 PM
Atom1025 is offline
Find More Posts by Atom1025
Fly me to the moon...
Atom1025's Avatar
Sacramento
Joined Jun 2005
When glassing what can be done with the 3M 90 if it ends up lumpy ? Mine kicked so quick today that trying to smooth it caused the Bondo shaper to drag the 3M 90 into little lumps. Will heat smooth it out ? Or what ? It is not all that bad, I just would like a smoother surface for the Monokote.
Bob
Trick is..... dont just sand at it like a madman, sand a little let it cool, sand a little let it cool. reapeat, if it heats up those lumps melt into unremoveable boogers. I use 80-120 grit should be fine. Sometimes scratch at it with your nail in between sanding. Be sure to apply more glue when done sanding.
Hood scoop, idea was stolen from the master.
http://www.rcgroups.com/forums/attac...mentid=1491028
Atom1025 is offline Find More Posts by Atom1025
Old Jan 01, 2008, 11:18 PM
jstoll is offline
jstoll's Avatar
Joined Feb 2007
I use a household iron to put on covering
Ive flattened out the biggest boogers just putting the covering on so that they couldent be seen
Ill take some closeups of my covering jobs so you can see
have a great week
JAK
Old Jan 01, 2008, 11:44 PM
klique is offline
Find More Posts by klique
Mum is the word!
Joined Jun 2003
Some times if the buggers are fresh, I just spray a really thick coat of 90 to soften them up then respread smooth again.
The solvents will soften them again if they are not too dry.
The trick is not to work such a big area so it wont get ahead of you.
Ck
klique is offline Find More Posts by klique
Old Jan 02, 2008, 06:53 PM
Wingman65's Avatar
St. Peters, Mo. USA
Joined Mar 2005
You guys hear that? crickets! The lights are flickering and growing dim around Mesa, power grid is overloaded. Klique labs must be working overtime again.
I guess our wives are moderating our smacktalk now, geez what's next
Old Jan 02, 2008, 07:05 PM
Bayward is offline
Find More Posts by Bayward
Pasco County Florida
Joined Dec 2006
Yeah, everyone sure clammed up. I wondered if they all passed out or something. Hope it wasn't an omen for things to happen the rest of the year.
Bob
Bayward is offline Find More Posts by Bayward
Old Jan 02, 2008, 07:11 PM
Atom1025 is offline
Atom1025's Avatar
Sacramento
Joined Jun 2005
Selling stuff
I am selling some ritewing power plants in the trader area. Take $5 bucks off the asking price if you fly a Ritewing I will be posting more as I dig stuff up.
Adam
Old Jan 02, 2008, 07:18 PM
klique is offline
Mum is the word!
Joined Jun 2003
I am here ,I am just hard at work in the shop on my 250 mph wings for SEFF
LOL.
ck
Old Jan 02, 2008, 07:30 PM
reefboy is offline
Find More Posts by reefboy
Luke 12:7
reefboy's Avatar
USA, CA, Sunnyvale
Joined Nov 2006
Sorry... I was out flying my today! I recently did a bit of maintenance on my my Tee El Fifty. Taped up some loose bits of monokote near the batt bay and electronics bay as well as some small tears on the bottom from landing in rough areas. Definitely seemed to fly a bit faster especially. First flight in about 2 weeks. So I'm as happy as a clam! that thing is a blast to fly! Wooo-hoooo.
Question regarding flourescent colors... how do you protect them?
My top surface has faded immensly!!! For now on I will keep it covered in the car or any other time it might be affected from UV. Am I the only one that has experienced the extreme fading? Is there any way to protect it from UV fading it? Need to replace the flourescent top coat to restore visibility!
Will hopefully finish my Mini Demon in the next few weeks and then transition to my 36 Sportster
reefboy is offline Find More Posts by reefboy
Old Jan 02, 2008, 07:31 PM
klique is offline
Mum is the word!
Joined Jun 2003
Hey scott just dont use orange flouro ,I have stopped using it because of the fading.The red is way better.
ck
I got some Fan Fold what to build thread part II started by emoone!!! Don Sims Foamies (Kits) 188 Jan 23, 2010 08:28 PM
Build Log RiteWing 48-FT build thread theclaw Slope 46 Dec 09, 2007 08:53 AM
Mountain Models Tantrum Partial Build Thread.. Tram Parkflyers 142 Apr 03, 2004 10:41 PM
My Bobolink Build Thread (very Colibri like) Jim Poor Hand Launch 65 Dec 10, 2003 04:48 PM
Switchback re-build thread (or What the $#*& was that!) Biggles604 Parkflyers 17 Jun 23, 2003 09:34 PM
