Old Feb 16, 2010, 05:23 AM
Atom1025 is offline
Find More Posts by Atom1025
Fly me to the moon...
Atom1025's Avatar
Sacramento
Joined Jun 2005
Originally Posted by PaulVi View Post
I use the standard router bit but have been known to use a drill bit as well..
The rotozip bits are nice, but an 1/8" dewalt(quality) drill bit works fine
Atom1025 is offline Find More Posts by Atom1025
Old Feb 16, 2010, 09:57 AM
Tram is offline
Find More Posts by Tram
Fly it like you stole it..
Tram's Avatar
Florence, Al
Joined Oct 2000
I've used all sorts of bits for my dremel with the route attachment.. There are a handful that work really well..
Tram is offline Find More Posts by Tram
Latest blog entry: Wow.. 3 years..
Old Feb 16, 2010, 07:43 PM
e2346437 is offline
Find More Posts by e2346437
Crash Test Dummy
e2346437's Avatar
United States, ME, Mapleton
Joined May 2005
Standard Dremel router bit here too. You can use the Dremel plunge router attachment if you want to make accurate shelf lids. I find that running it at the fastest speed is best as it cuts the foam rather than tears it.
Eric
e2346437 is offline Find More Posts by e2346437
Old Feb 16, 2010, 08:40 PM
AgentCow007 is offline
Find More Posts by AgentCow007
USA, CA, Los Angeles
Joined Sep 2004
Thanks for the input... can anyone tell me what the "standard dremel routing bit" is though? I got a black and decker RTX that is supposedly dremel-accessory-compatible, but I have no idea what to buy for it since typing "dremel router bit" brings up bits of all shapes and sizes.
like, which one of these is it? http://www.dremel.com/en-us/Attachme...me=Router+Bits
AgentCow007 is offline Find More Posts by AgentCow007
Old Feb 16, 2010, 08:50 PM
PaulVi is offline
Find More Posts by PaulVi
resU deretsigeR
PaulVi's Avatar
Dublin Ca
Joined Aug 2004
http://www.sears.com/shc/s/p_10153_1...061224x0000002
like this
PaulVi is offline Find More Posts by PaulVi
Old Feb 16, 2010, 08:53 PM
e2346437 is offline
Crash Test Dummy
e2346437's Avatar
Joined May 2005
I use this one http://www3.towerhobbies.com/cgi-bin...&I=LXC639&P=FR
I also have the Black & Decker unit, works great.
Eric
Old Feb 16, 2010, 09:16 PM
Atom1025 is offline
Atom1025's Avatar
Sacramento
Joined Jun 2005
Thats what I prefer.
Old Feb 16, 2010, 10:22 PM
Prof100 is offline
Find More Posts by Prof100
Prof100's Avatar
Canton, Michigan USA
Joined Jul 2007
Eric
That's what I prefer too when making dust if I don't decide to melt my way through the foam and sniff fumes with a soldering gun.
Bill
Prof100 is offline Find More Posts by Prof100
Old Feb 16, 2010, 10:38 PM
PaulVi is offline
resU deretsigeR
PaulVi's Avatar
Dublin Ca
Joined Aug 2004
http://s.sears.com/is/image/Sears/00...sm=0.9,0.5,0,0
The way this is designed it lifts the foam out of the way. Of cource i use it with the router depth gadge as well lets me cut a nice 2mm shelve to mount the coro on..
Then i hog out the center with the weller soldering gun..
best of both worlds
Old Feb 16, 2010, 10:59 PM
Prof100 is offline
Prof100's Avatar
Joined Jul 2007
best of both worlds
Great, you get dust and fumes.
Old Feb 17, 2010, 12:08 AM
PaulVi is offline
resU deretsigeR
PaulVi's Avatar
Dublin Ca
Joined Aug 2004
Yes but that is what an exshaust hood is for...
Old Feb 17, 2010, 12:31 AM
jpinn is online now
Find More Posts by jpinn
jpinn's Avatar
United States, CA, Poway
Joined Jan 2006
what amperage can the arc 28-47-1.5 pull on 4s with a 6x4 sport prop? I want to get some 40C 5000mah packs, so draw on the packs can be a maximum, I just want to know what the draw might be to get an esc large enough.
thanks.
jpinn is online now Find More Posts by jpinn
Old Feb 17, 2010, 02:30 AM
hawkz is offline
Find More Posts by hawkz
USA, CA, San Diego
Last time I tried, they pulled 72 amps static. I don't have eagletree or whatnot, but heard that the 1.5 and 6x4 sport setup drop to sixty-some amps in flight. If your 5000mAh packs are really 40C, they should be barely warm when they come down.
hawkz is offline Find More Posts by hawkz
Old Feb 17, 2010, 03:14 AM
moparmyway is offline
Find More Posts by moparmyway
Why the dirt on the wings?
moparmyway's Avatar
New York
Joined Jan 2009
thanks.
103 amps @ launch
80 amps straight and level
90 amps in a vertical climb
45/90 packs
moparmyway is offline Find More Posts by moparmyway
Old Feb 17, 2010, 05:02 AM
jackosmeister is offline
Find More Posts by jackosmeister
DroneWorlds - TEAM NEW ZEALAND
jackosmeister's Avatar
Auckland NZ
Joined Aug 2007
hawkz those numbers must be for a 28-48-2.
My testing is near identical too mopar's (+/- 1A) , and I severly melted the motor on flight 20 something! very burnt windings.
Personally I rekon the 48-1.5 4S 6x4sport setup sucks, its too amp hungry and the efficiency isnt very high at all, Id go with something else using higher voltage and less amps. I dont think you'll regret it in the long run.
jackosmeister is offline Find More Posts by jackosmeister
I got some Fan Fold what to build thread part II started by emoone!!! Don Sims Foamies (Kits) 188 Jan 23, 2010 08:28 PM
Build Log RiteWing 48-FT build thread theclaw Slope 46 Dec 09, 2007 08:53 AM
Mountain Models Tantrum Partial Build Thread.. Tram Parkflyers 142 Apr 03, 2004 10:41 PM
My Bobolink Build Thread (very Colibri like) Jim Poor Hand Launch 65 Dec 10, 2003 04:48 PM
Switchback re-build thread (or What the $#*& was that!) Biggles604 Parkflyers 17 Jun 23, 2003 09:34 PM
