Old Dec 31, 2007, 12:52 AM
klique is offline
Find More Posts by klique
Mum is the word!
Joined Jun 2003
Paul that is cookin buddy .
112 flat sounds about rite too.
Ck
Originally Posted by PaulVi
SO i was horsing around with the 4s TL50 today and mounted the "How Fast" to the top of the wing and was doing speed runs..
Max speed in a dive was 158 mph flat and level passes were in the 112 mph range
I just detuned the ESC on the advance so it did have a negative effect i was in the 120 flat out before.. but i flew the whole pack out and it was cool as a kitten when it came down so i think i will leave it this way till after AEF..
klique is offline Find More Posts by klique
Old Dec 31, 2007, 12:57 AM
punkrockd is offline
Find More Posts by punkrockd
Purples a fruit
punkrockd's Avatar
United States, CA, Walnut Creek
Joined Aug 2006
tony i have one of those suppo esc's and they work great for a123's, i only trust the castle esc's with lipos but that is just me. i tryed running with the lowest cut off and ended up turning the lv cut off, off.
when we flew all together in elk grove i remember my plane with 5a123's and a het 4w was slightly faster then the other planes at first. but i had a shorter run time of around 7mins. i miss that day
punkrockd is offline Find More Posts by punkrockd
Old Dec 31, 2007, 01:09 AM
Wingman65 is offline
Find More Posts by Wingman65
Build, Fly, Crash..Repeat
Wingman65's Avatar
St. Peters, Mo. USA
Joined Mar 2005
Hey Punkrockd, how goes it. Sounds like it was a blast. Got the 60a esc and the long can ARC 28-47-2 for $75 and free shipping. Sounds like CK is liking the ARC motors too. I might pick up a 1.5 turn long can and another 60a esc from Lightflight RC, can't beat the price.
Wingman65 is offline Find More Posts by Wingman65
Old Dec 31, 2007, 01:16 AM
Purples a fruit
punkrockd's Avatar
Joined Aug 2006
since i'm not using lipos in the larger range anymore i'm only going to use those esc's for the a123 planes.
cant beat that price. i've been saying for a couple months now that i'd order another esc or 2 and a arc motor. but lately i've been into my airfoilz edge and gliders, i really have not been flying much.
Old Dec 31, 2007, 01:35 AM
Wingman65's Avatar
St. Peters, Mo. USA
Joined Mar 2005
I wish we had a good place to slope around here, looks like good times. Here is the last build pic before glassing. servos all in and foamed over.
Old Dec 31, 2007, 01:46 AM
PaulVi is offline
Find More Posts by PaulVi
resU deretsigeR
PaulVi's Avatar
Dublin Ca
Joined Aug 2004
The airfoilz is the one i hav the 30mm scorpion motor in on 2s 3300 it is the plain i have been doing the altitude runs..
PaulVi is offline Find More Posts by PaulVi
Old Dec 31, 2007, 05:45 AM
e2346437 is offline
Find More Posts by e2346437
Crash Test Dummy
e2346437's Avatar
United States, ME, Mapleton
Joined May 2005
How much height did you end up with in your battery bay Wingman? Just planning a future project
e2346437 is offline Find More Posts by e2346437
Old Dec 31, 2007, 10:35 AM
Wingman65's Avatar
St. Peters, Mo. USA
Joined Mar 2005
It's an inch at the thickest part of the wing with the floor cut in.
Tony
Old Dec 31, 2007, 05:37 PM
Wingman65's Avatar
St. Peters, Mo. USA
Joined Mar 2005
40" Demon A123 build
Ready for glass. This is the part of the build I enjoy the most as the plane really starts feeling stiff. I'm not going into a great deal of detail on this process as Chris and Atom can describe it better than me. I will show my work and a picture speaks a thousand words.
Before glassing, with servos the Demon weighed in at 10.8oz. I'll be sure to get a weight after glassing for comparison. I wrapped 4 layers of duct tape around the battery pack and shoved it all the way forward to create a little bigger pocket so that the pack will slide in easier after the plane is finished.
Old Dec 31, 2007, 06:09 PM
ab8ug is offline
Find More Posts by ab8ug
West Michigan
Joined Nov 2006
I was looking at the rectangular laundry detergent bottles (1.56 gal) as a source for material for the bottom of the battery bay. I can get a piece as large as 6"X7" out of it. It would be almost flat when cut from the bottle. It is pretty tough stuff and thinner than 2mm coroplast. What do you think?
Wayne
ab8ug is offline Find More Posts by ab8ug
Old Dec 31, 2007, 06:19 PM
Wingman65's Avatar
St. Peters, Mo. USA
Joined Mar 2005
It should work for the bottom, not sure if it would be as rigid as the coro. I'm thinking of making some landing skid plates from that.
Old Dec 31, 2007, 06:36 PM
swoof is offline
Find More Posts by swoof
swoof's Avatar
United States, CA, Upland
Joined Mar 2007
ab8ug I would just be worried about the lack of cushion for using the thin plastic as the bottom of the batter compartment. If you use coroplast there is at least some cushion if you land hard.
swoof is offline Find More Posts by swoof
Old Dec 31, 2007, 06:47 PM
ab8ug is offline
West Michigan
Joined Nov 2006
I don't land hard, I CRASH. :-{)
Old Dec 31, 2007, 09:18 PM
JustGoFly is offline
Find More Posts by JustGoFly
Rochester, NY
JustGoFly's Avatar
United States, NY, Monroe
Joined May 2004
Originally Posted by kctrading
CK just sent you paypal for Neu (1110-2Y 2500KV) motor too
BTW...has anyone actually fried one of these motors? Over proped that is!
Neu 1110-2Y 2500KV
I've already fried a Justgofly 500TH (Vinnie was not to happy ...nice smoke trail running a 6x4 on 3 cells no yet but around 700 watts is was making a lot of heat and not every efficent! It did do 103mph on the WW and last five packs...doh!
Also what is the record top speed and prop configure with 4S with the above motor and 40" D? Also how much lighter is a Demon lite? Which I will be using.
Ken
Ken - 700 Watts is alot higher than the rating of the motor. We have 550's coming out that will run a 6x4 on 5S. That may be more your style.
I run my Demon on 5S on the 550 and full throttle the whole time the motor comes down cold. I upgraded 60 6x5.5 and still cold. 6S became very difficult to launch. I'll see if I can post some video.
Vinnie
JustGoFly is offline Find More Posts by JustGoFly
Old Jan 01, 2008, 02:08 AM
Atom1025 is offline
Find More Posts by Atom1025
Fly me to the moon...
Atom1025's Avatar
Sacramento
Joined Jun 2005
Happy new years all you wingalings!
Atom1025 is offline Find More Posts by Atom1025
I got some Fan Fold what to build thread part II started by emoone!!! Don Sims Foamies (Kits) 188 Jan 23, 2010 08:28 PM
Build Log RiteWing 48-FT build thread theclaw Slope 46 Dec 09, 2007 08:53 AM
Mountain Models Tantrum Partial Build Thread.. Tram Parkflyers 142 Apr 03, 2004 10:41 PM
My Bobolink Build Thread (very Colibri like) Jim Poor Hand Launch 65 Dec 10, 2003 04:48 PM
Switchback re-build thread (or What the $#*& was that!) Biggles604 Parkflyers 17 Jun 23, 2003 09:34 PM
