Old Dec 30, 2007, 06:26 PM
Wingman65 is offline
Find More Posts by Wingman65
Build, Fly, Crash..Repeat
Wingman65's Avatar
St. Peters, Mo. USA
Joined Mar 2005
Hey Rob, welcome to the madness Hey CK, a couple of degrees change of thrust angle worked great on the forty. Dead level with "0" elev trim and just 2 clicks of right. Flew 2 flights with the 40 on 4s and 2 on the Fity on 3s2p. Man, the TL40 on 4s and Medusa 2200 with 6x4 sport prop is the fastest, most stable plane I've flown
Wingman65 is offline Find More Posts by Wingman65
Old Dec 30, 2007, 06:36 PM
klique is offline
Find More Posts by klique
Mum is the word!
Joined Jun 2003
Sweet,its so nice to getu'm dialed aint it.Thnx for havin somuch fun
I know exactly ho you feel
ck
klique is offline Find More Posts by klique
Old Dec 30, 2007, 06:42 PM
Wingman65's Avatar
St. Peters, Mo. USA
Joined Mar 2005
Thank you CK. Just looking at the 54 Lightning, be a good candidate for twins or just a big A123 plane. Back to work on Demon.
Tony
Old Dec 30, 2007, 06:50 PM
klique is offline
Mum is the word!
Joined Jun 2003
Ya ,it would be perfect for the a 123's more so than the others, and it would not be a hard build for them.
ck
Tony
Old Dec 30, 2007, 09:59 PM
kctrading is offline
Find More Posts by kctrading
kctrading's Avatar
Joined Mar 2005
CK just sent you paypal for Neu (1110-2Y 2500KV) motor too
BTW...has anyone actually fried one of these motors? Over proped that is!
Neu 1110-2Y 2500KV
I've already fried a Justgofly 500TH (Vinnie was not to happy ...nice smoke trail running a 6x4 on 3 cells no yet but around 700 watts is was making a lot of heat and not every efficent! It did do 103mph on the WW and last five packs...doh!
Also what is the record top speed and prop configure with 4S with the above motor and 40" D? Also how much lighter is a Demon lite? Which I will be using.
Ken
kctrading is offline Find More Posts by kctrading
Old Dec 30, 2007, 11:27 PM
Atom1025 is offline
Find More Posts by Atom1025
Fly me to the moon...
Atom1025's Avatar
Sacramento
Joined Jun 2005
Dynomike radared his demon running a Medusa 28-40-2500 and 4s at 154 in a dive. There is video on the first post of this thread. I imagine performance will be similar if not better.
Atom1025 is offline Find More Posts by Atom1025
Old Dec 30, 2007, 11:37 PM
Wingman65's Avatar
St. Peters, Mo. USA
Joined Mar 2005
40" Demon build
Making progress, slow and steady. It is starting to take shape as I have all compartments formed and servos with burried rods glued in.
Should I separate the Rx from other components with block of foam. Not sure if it would make a difference or not.
Tony
Old Dec 31, 2007, 12:08 AM
PaulVi is offline
Find More Posts by PaulVi
resU deretsigeR
PaulVi's Avatar
Dublin Ca
Joined Aug 2004
People tend to over look this part of setting up the clevis's The threaded rod used to attach the clevis should be long enough to go inside the outer sheath of the nyrob this will prevent a week point in the control mechanics
I do this by using threaded control rod and cut it about 3 inches long then i stick the wire (unthreded side into the inner nyron and thread it in.. I can still attach the clevis but the metal control rod provides a nice mechanical advantage over just the inner nyrod
PaulVi is offline Find More Posts by PaulVi
Old Dec 31, 2007, 12:12 AM
klique is offline
Mum is the word!
Joined Jun 2003
You are rite Paul,I usually extend mine in appx 3 inches tohelp keep the flex down to a minmum.
ck
Old Dec 31, 2007, 12:22 AM
Wingman65's Avatar
St. Peters, Mo. USA
Joined Mar 2005
Nice illustration Paul. I definitely like using the clevices over z-bends for slop-free control surfaces. Do you think separating the rx with a block of foam will make any difference in noise?
Old Dec 31, 2007, 12:31 AM
rmorhan is online now
Find More Posts by rmorhan
rmorhan's Avatar
wasaga beach ont canada
Joined Jan 2004
ck,the liteflight sounds like a good excuse to get another motor. wanted to try the 4t & 4s in my funjet anyway .kc what,s the neu worth?? good stuff wingman....happy new years guys (party on wayne!)... rob m
rmorhan is online now Find More Posts by rmorhan
Old Dec 31, 2007, 12:34 AM
klique is offline
Mum is the word!
Joined Jun 2003
Any seperation you can do will help.Tony you have a good handle on the build buddy.You got the lay down good.
ck
Old Dec 31, 2007, 12:36 AM
klique is offline
Mum is the word!
Joined Jun 2003
Hey bud do the long can 1.5 turn on 4s it is sweet.
ck
Old Dec 31, 2007, 12:39 AM
klique is offline
Mum is the word!
Joined Jun 2003
Ken I will cut you a Dlite tommorow and sendit out with the wing .That neu is awesome on 4s and 5s also bud.
ck
Neu 1110-2Y 2500KV
Ken
Old Dec 31, 2007, 12:49 AM
PaulVi is offline
resU deretsigeR
PaulVi's Avatar
Dublin Ca
Joined Aug 2004
SO i was horsing around with the 4s TL50 today and mounted the "How Fast" to the top of the wing and was doing speed runs..
Max speed in a dive was 158 mph flat and level passes were in the 112 mph range
I just detuned the ESC on the advance so it did have a negative effect i was in the 120 flat out before.. but i flew the whole pack out and it was cool as a kitten when it came down so i think i will leave it this way till after AEF..
I got some Fan Fold what to build thread part II started by emoone!!! Don Sims Foamies (Kits) 188 Jan 23, 2010 08:28 PM
Build Log RiteWing 48-FT build thread theclaw Slope 46 Dec 09, 2007 08:53 AM
Mountain Models Tantrum Partial Build Thread.. Tram Parkflyers 142 Apr 03, 2004 10:41 PM
My Bobolink Build Thread (very Colibri like) Jim Poor Hand Launch 65 Dec 10, 2003 04:48 PM
Switchback re-build thread (or What the $#*& was that!) Biggles604 Parkflyers 17 Jun 23, 2003 09:34 PM
