Well the first static test is done, numbers are;
657watts 45amps. My pitch speed is going to be around 150 - 160mph I think... all I need now is a nice day
I did find and solve one strange problem with my power system. I am using an E-Flite 60 amp pro Switch mode ESC which has many programming features, some of which I was unfamiliar with, for example, PWM frequency and Throttle range (PWM) both of these settings caused me trouble. Through trial and error, I have found the correct settings using this ESC and a MicroDan 2505 speed motor. Here are my settings:
1. Voltage cutoff - 4-cell
2. Brake type - Medium brake
3. Timing - High timing (12 pole)
4. Throttle range - 1.2 - 1.8ms
5. Start-up rate - .25sec
6. PWM switching frequency - 32khz (THIS WAS THE CRUCIAL ONE!) the motor would not reach full throttle at 8 or 16khz, it would cut out at 3/4 throttle until I chose 32khz then it worked normally.
7.Operating mode - (Not sure about this one) I think I chose 8kHz which was the default.
By the way I static tested this inside my house... I am clinically deaf now... just a warning
