Old Jun 02, 2007, 07:46 AM
joekoz is offline
Find More Posts by joekoz
Certified Riteaholic
joekoz's Avatar
San Marcos, CA.
Joined Oct 2003
Ouch, man I'm really sorry to hear that story Charger.
joekoz is offline Find More Posts by joekoz
Old Jun 02, 2007, 07:48 AM
Atom1025 is offline
Find More Posts by Atom1025
Fly me to the moon...
Atom1025's Avatar
Sacramento
Joined Jun 2005
CK's the man! 40.5 oz is impressive!
Atom1025 is offline Find More Posts by Atom1025
Old Jun 02, 2007, 10:07 AM
Charger is offline
Find More Posts by Charger
I B Chargin'
Charger's Avatar
Arizona
Joined Aug 2003
Yeah, even though it was a very light TL, CK built it rock solid. I was feeling kind of invincible with it. I had a friend out from Georgia a couple of months ago and put him on the buddy box with it and had some problems. The TL went in pretty hard a couple of times and that's when the servo probably loosened. Then I let another friend fly it, and the loose servo probably made him crash a couple of times
I looked at the plane for a day. The rip went from the motor cut out corner, through a totally displaced servo ( which had been buried ). The battery bay looked like a hurricane went through it and the nose was just a mess.
I got a hold of CK and ordered a couple more TL 50's and hated to throw out this one because the elevons were still nicely attached to the wings. I started pealing and cutting the glass back off the whole midsection and decided to go for a major overhaul repair. I cut a piece of plywood (weighed one ounce) that exactly fit the battery bay floor and used about a foot long stick of hot glue in the whole floor and the back of the ply. I put a big board in my lap to keep things flat, put the TL on top of that and held the ply down with hard finger pressure on a couple of batts. Then started piecing things back together. Wound up using 3 long sticks of hot glue, goop, spackle, strapping tape and coroplast, re-glassed the whole middle, and recovered with Monokote.
It gained 5 1/2 oz but pretty much looks like it did before the crash AUW 46 oz. I am shocked at how good it flies. I didn't even check CG and tossed her up and it flies great even with the extra nose weight!! It's a little more sluggish.......but will get me through till my order comes in.
A totally Bunged up Ritewing has more potential than most other brand kits brand new!! Don't worry CK, my order still stands........The check is in the mail .........Must have more TL 50's
Charger is offline Find More Posts by Charger
Old Jun 02, 2007, 08:43 PM
Atom1025 is offline
Atom1025's Avatar
Sacramento
Joined Jun 2005
Good to hear Charger.
Please post any tips and tricks along the way to keep this thread alive. Of course finished pics are required
Old Jun 02, 2007, 11:11 PM
Charger is offline
I B Chargin'
Charger's Avatar
Arizona
Joined Aug 2003
Ok
These are the things that work for me. Seems like the inside corners of the motor mount cut out are a weak area. If the plane noses in, the heavy motor has inertia and can rip these inside corners. Something has to give!! If it's not too bad, I like to bury the nose of a hot glue gun in, several places along the rip. The hot tip heats it's way in. Fill up the crack and the hole you just made and lick you finger and shape the surface smooth. When I repaired this one, I made extra 2" square "Henry's" grommets wrapping over the edge of these inside corners, when I re-glassed, one from the top, and one from the bottom on each side. I really liked the plywood for the bay repair, cuz it's flat ( nothing had any shape after the crash ) and hot glue sticks to it and the foam and it sets up pretty fast. I also like having a big flat board in my lap to keep pressing the plane down onto as the hot glue was setting up to keep the plane flat as I rebuilt the bits and pieces.
I've got about 10 flights since the repairs (4 today) with 4s set up and the plane hasn't got any bad tendencies. One test was figure 8's with inside loops and outside loops...........pretty clean
Old Jun 03, 2007, 12:16 AM
reefboy is offline
Find More Posts by reefboy
Luke 12:7
reefboy's Avatar
USA, CA, Sunnyvale
Joined Nov 2006
I experienced the same tears in the motor mount area. When I repaired mine I picked up a few 20 cc syringes and EFD metal tips to get it way into the crack. I then injected Gorilla glue into the cracks along with a little water and tried to work the torn section. Then I used the larger T-pins from both sides to help keep it together while it was glueing. I also added a few small pieces of Henry's to span the repaired area.
I used a few carbon fiber strips top and bottom to span a few wrinkled areas and give the wing a bit more stiffness in those areas. When completed I added a new layer of Henry's top and bottom from the CG forward. I was able to take some weight out.
reefboy is offline Find More Posts by reefboy
Old Jun 05, 2007, 11:46 PM
Atom1025 is offline
Atom1025's Avatar
Sacramento
Joined Jun 2005
So I am in the process of building my 40" Demon lite!
The gear will consist of:
Mega 16-7-7
CC25
5.5x4.5 apc
Berg 4l
3s2p4200 Prolites
My goal! No lead needed!!!
My life has been really hectic and stressfull lately, there is a lot going on. As soon as I can catch up with my sanity and when I get the pics back I will finish the dang build report.
You guys to post your tips and tricks to keep this thread alive! Heck go ahead and spam it, I don't care.
Old Jun 06, 2007, 12:09 AM
klique is offline
Find More Posts by klique
Mum is the word!
Joined Jun 2003
Adam what is the kv on that motor,I dont remember?
ck
klique is offline Find More Posts by klique
Old Jun 06, 2007, 12:18 AM
Atom1025 is offline
Atom1025's Avatar
Sacramento
Joined Jun 2005
about 2500, I flew this motor on my obese 36" and it moved it quite well. Prolly 70 mph or so at 25amps static. Came down barely warm so it may handle a 6x4
Old Jun 06, 2007, 12:24 AM
klique is offline
Mum is the word!
Joined Jun 2003
Ya a 6/4 or a 5.5/4.5 will be great keep it lite like you said.
ck
Old Jun 07, 2007, 01:24 PM
Atom1025 is offline
Atom1025's Avatar
Sacramento
Joined Jun 2005
Allright! I got the pics from the Sis in law just now.
So here is the finished pics of the plane in the build report.
Old Jun 07, 2007, 01:51 PM
reefboy is offline
Luke 12:7
reefboy's Avatar
USA, CA, Sunnyvale
Joined Nov 2006
I like it! Looks awesome! Good job!
Old Jun 07, 2007, 02:45 PM
PaulVi is offline
Find More Posts by PaulVi
resU deretsigeR
PaulVi's Avatar
Dublin Ca
Joined Aug 2004
Cool love the GFX even my old eyes could see that one a ways out...
Nice back drop too..
PaulVi is offline Find More Posts by PaulVi
Old Jun 08, 2007, 09:35 PM
TaSaJaRa is offline
Find More Posts by TaSaJaRa
More props are better than One
TaSaJaRa's Avatar
United States, AL
Joined Nov 2004
Man that is sweet looking...
Love the Neon Yellow/green how ever you look at it...
Looks like it will be very visible way out...untill you get to the magic point where it turns
into a 1" black line...LOL and makes it tuff on the older guys to see.
That plane turned out super nice...
TaSaJaRa is offline Find More Posts by TaSaJaRa
Old Jun 08, 2007, 09:42 PM
punkrockd is offline
Find More Posts by punkrockd
Purples a fruit
punkrockd's Avatar
United States, CA, Walnut Creek
Joined Aug 2006
it is even better in person.
i always get to launch his planes for him. as always his builds are kick arse.
he is just sooo picky. looks like a big pay off.
punkrockd is offline Find More Posts by punkrockd
I got some Fan Fold what to build thread part II started by emoone!!! Don Sims Foamies (Kits) 188 Jan 23, 2010 08:28 PM
Build Log RiteWing 48-FT build thread theclaw Slope 46 Dec 09, 2007 08:53 AM
Mountain Models Tantrum Partial Build Thread.. Tram Parkflyers 142 Apr 03, 2004 10:41 PM
My Bobolink Build Thread (very Colibri like) Jim Poor Hand Launch 65 Dec 10, 2003 04:48 PM
Switchback re-build thread (or What the $#*& was that!) Biggles604 Parkflyers 17 Jun 23, 2003 09:34 PM
