Old May 15, 2007, 01:32 AM
Atom1025 is offline
Find More Posts by Atom1025
Fly me to the moon...
Atom1025's Avatar
Sacramento
Joined Jun 2005
I use the spackle over the spars and any holes, or whatnot. I will show some pics of what I like to do, its hard to explain. I don't do the whole wing however.
I like to use epoxy mixed with microlight. http://www.aircraftspruce.com/catalo...microlight.php
It dries quckly, easy to sand, flexible, yet extremly strong, but it adds alot more weight.
For this build I wanted to use something readily available plus I want to keep this one lighter then my last one. You know always have to do better then the last one!
Atom1025 is offline Find More Posts by Atom1025
Old May 15, 2007, 02:28 AM
PaulVi is offline
Find More Posts by PaulVi
resU deretsigeR
PaulVi's Avatar
Dublin Ca
Joined Aug 2004
Whewww for a minute i thoiught you were doing the whole wing.. BTW i like the mount install looks like it would be simpler to get the starting thrust angle right.. although i worrry about the longevity of hot glue on a piese of metle have you thought about gooping the mount in it creates a bond that does not weaken over time..
And doing the mount the way you showwould alow for much less glue in the tail it could be spread thinner from the start
PaulVi is offline Find More Posts by PaulVi
Old May 15, 2007, 09:31 AM
Atom1025 is offline
Atom1025's Avatar
Sacramento
Joined Jun 2005
Yeah, I have done it both ways, goop works great, so far hot glue works. I'd say if you have the time use goop. I guess time will tell regarding the hot glue
Yeah I really like this method better the the vid, the one in the vid makes it easy to get the plate crooked. I feel a lot better being able to see what I am working on.
I believe Chris is going to draw up a template to get the thrust angle close. Basically print it, cut it, place it on the wing, and check your angle.
Adam
Old May 15, 2007, 12:42 PM
PaulVi is offline
resU deretsigeR
PaulVi's Avatar
Dublin Ca
Joined Aug 2004
Looks like it may be time to update the video...
Keep up the good work. Did you get my motor info i pm'ed you
Old May 15, 2007, 08:01 PM
Atom1025 is offline
Atom1025's Avatar
Sacramento
Joined Jun 2005
Yep, its been added to the list, some of it anyways.
Old May 16, 2007, 04:51 PM
Atom1025 is offline
Atom1025's Avatar
Sacramento
Joined Jun 2005
I have the bottom glassed, its curing now, the top will be glassed by tonight!
I also have the Prepping for Glass portion added to the front page!
Old May 17, 2007, 11:40 AM
winghead is offline
Find More Posts by winghead
N Cal
Joined Jun 2003
What a great help this build log is, thanks! It inspired me to tackle this build. TL 50 and motor system is on the way. Im the guy walking around the LHS with your list on a clipboard. Qs: 1) At the nosetip, how did you handle the overlap/seam? 2) At the motormount, did you make the glass flat where it contacts the metal? The pic looks like it isnt. 3) On double glassing the battery bays, is this optional if weight is a priority? How about double layering with 1/2" strips in key areas? Thanks again.
winghead is offline Find More Posts by winghead
Old May 17, 2007, 12:30 PM
punkrockd is offline
Find More Posts by punkrockd
Purples a fruit
punkrockd's Avatar
United States, CA, Walnut Creek
Joined Aug 2006
you can build it to you're specific needs or wants.
on the nose i like to just make it smooth. i'll trim the glass once it is dry if any fibers are stickin up. i've sprayed a bit more glue on the seam and that has helped to float it a bit.
i first cut the foam around the mount so the metal is exposed and perfect for the clam shell. then glass the area. i cut the glass off the metal. and use a bit more glue to make sure its down. others may disagree or have thier own. other then that i cover the motor mount with monokote.
the battery bay i recommend a few layers or what tasajara and adam have shown. a layer of henry's lining the battery bay with goop. thats a good idear.
when you get the batt bay cut you will notice how thin the foam can be. and that will aid in your decision
most of all enjoy the build it is fun.
punkrockd is offline Find More Posts by punkrockd
Old May 17, 2007, 12:33 PM
Atom1025 is offline
Atom1025's Avatar
Sacramento
Joined Jun 2005
On the LE cap, you don't have to worry about the overlap seam, you can cut the glass down to size for no overlap. Or have it overlap a 1/4" on each side. There really is no wrong way. I'd say use some overlap if its your first build to keep things simple, but again its your choice.
Welll, the glass is as flat as it can be around the motor mount. You just try and manipulate it the best you can. Once the clamp goes on this area is never seen so, its not a problem area. Leaving the glass around this area is a must as it gives the mount plate its stiffness and strength.
It really depends on your build and what you expect from the plane. Lets say you gave a superthin battery bay, Starting at the TE of the batt bay I would double glass from this point all the way up to the nose, on top and bottom.
Anything is optional with this build. I could of got away with a single layer over the batt bay but I gave it a little extra. This stuff will add weight but in the right places you'll benifit from it. Keep CG in mind, only double up ahead of the CG when possible.
Now if your going to break the sound barrier, you need more reinforcement. Build it like the video shows. Use 1/4" overlap. And criss cross in the middle for torsional strength.
The pics are of my first build. This was a TL40 lite and it came out lite. I run 3s2p 4200 prolites in this one.
Ask as many questions as you like.
Old May 17, 2007, 12:47 PM
winghead is offline
N Cal
Joined Jun 2003
Thanks.
Old May 18, 2007, 02:02 AM
COMBAT007 is offline
Find More Posts by COMBAT007
LOVE TO FLY!!!!!!
Joined Oct 2006
Adam
HI ADAM,
I'M HAVING PROBLEMS GETTING MY THRUST ANGLE CORRECTLY ON THE DEMON.
VIDEO SHOW THE CUT TO BE ABOVE THE CF.
MY PROBLEM IS WHEN I DO CUT THE CENTER OF THE MOTOR MOUNT AREA OF THE EPP, THE CUT FROM CENTER TO CF IS ANGLED UPWARD TOWARDS THE PLANE.IS THIS CORRECT?
I THOUGHT THE CENTER LINE WAS FROM THE TIP TO THE REAR CENTER?
PLEASE HELP?
THANKS
COMBAT007 is offline Find More Posts by COMBAT007
Old May 18, 2007, 12:14 PM
Atom1025 is offline
Atom1025's Avatar
Sacramento
Joined Jun 2005
Sounds like you got it rite! If its from the center of the TE and sits a top of the internal CF spar, you have it rite.
Don't stress off it to much as adjusting the thrust angle is easy.
Old May 18, 2007, 02:04 PM
LOVE TO FLY!!!!!!
Joined Oct 2006
THANKS ADAM
Old Jun 01, 2007, 11:15 PM
Atom1025 is offline
Atom1025's Avatar
Sacramento
Joined Jun 2005
Flew the new 50 lite today. Heavier then I wanted, I was aiming for 40oz which is high hopes. It came in at 44oz AUW.
I went with the 4s 4000 Maxamps, Het 4w, and 6x4E.
I really dig this setup more then the 3s and 7x4 setup. Its less draggy without that huge prop, higher speed, thrust actually seemed better.
The plane was very responsive compared to its heavier brother. The maiden was smooth and uneventful. I need to take it out on a not so windy day to dial it in.
I will have pics shortly, my camera system took a dump so I am using my inlaws camera so it has to go through their computer first and then get emailed to me. I'll keep ya'all posted.
Next up, either the TL60 or a 40 Demon ultralite?
Old Jun 02, 2007, 12:25 AM
Charger is offline
Find More Posts by Charger
I B Chargin'
Charger's Avatar
Arizona
Joined Aug 2003
Ck built me a light TL50 18 months ago. It's AUW was 40.5 oz with 4s poly 3700's. I flew the living out of it. It was the perfect plane. Apparently I had a loose servo last weekend and it went in hard during just a basic climb out. Just about ripped the wing in half and tore the nose off I was flying one month old 4000 MaxAmps and one two cell went up in smoke. Kinda glad, ordered a new pair of poly 3700 2s's today.
Charger is offline Find More Posts by Charger
I got some Fan Fold what to build thread part II started by emoone!!! Don Sims Foamies (Kits) 188 Jan 23, 2010 09:28 PM
Build Log RiteWing 48-FT build thread theclaw Slope 46 Dec 09, 2007 09:53 AM
Mountain Models Tantrum Partial Build Thread.. Tram Parkflyers 142 Apr 03, 2004 11:41 PM
My Bobolink Build Thread (very Colibri like) Jim Poor Hand Launch 65 Dec 10, 2003 05:48 PM
Switchback re-build thread (or What the $#*& was that!) Biggles604 Parkflyers 17 Jun 23, 2003 10:34 PM
