Old Aug 25, 2007, 12:15 AM
winghead is offline
Find More Posts by winghead
N Cal
Joined Jun 2003
Long story short on my TL50: I talked to Chris K. about trimming out and did a dive test. Power on dive, chop throttle and see what it does. When I tried to pull out it wouldnt and went nose in. I rebuilt it, flew twice and have it trimmed again. When in a mild dive it flys straight until I pull up. It pulls up but also rolls to the right. When level it flys straight. Two questions: 1) why wouldnt it react to up elevator when in a high speed dive 2) why does it fly straight until you want it to pull out of a mild dive- it pulls up and rolls right? low DR at 35%, high at 65%, CG 8", 45 oz. AUW,
winghead is offline Find More Posts by winghead
Old Aug 25, 2007, 12:44 AM
klique is offline
Find More Posts by klique
Mum is the word!
Joined Jun 2003
What servos are you using?
what is the all up weight?
klique is offline Find More Posts by klique
Old Aug 25, 2007, 02:23 AM
winghead is offline
N Cal
Joined Jun 2003
HS-225MG, 45oz AUW
Old Aug 25, 2007, 11:51 AM
winghead is offline
N Cal
Joined Jun 2003
To address the above problem I retaped the hinges, readjusted the control horns, played with the transmitter sub-trims. Off to test fly... This is like a part time job for me.
Old Aug 25, 2007, 01:26 PM
klique is offline
Mum is the word!
Joined Jun 2003
Do you have any up close pix of the elevons and thrust angle?
ck
Old Aug 25, 2007, 02:34 PM
winghead is offline
N Cal
Joined Jun 2003
I will get some pics up later but I found out a couple of things. When I pull the right stick down I probably was pushing it slight left at near bottom. I played with the spring tension and practiced. Also, I re set up the rods, horns, and retaped the hinges. It loops nice and even now. As far as not wanting to pull out of a high speed dive that might be fixed now also. I believe there was too much play of the tape hinges. It looks tighter now. With only 35% on the rates, in a high speed dive it is very important not to have loose ailerons. I will get more aggressive on my dives until I am confident enough to do another power on dive test. Learned alot, cant take the tape hinge step lightly. Thanks. Also, talked to a shop that is interested in selling wings. Send me that postage we talked about or PM me if you didnt get my email.
Old Aug 27, 2007, 08:21 PM
Pilot Tim Nunn is offline
Find More Posts by Pilot Tim Nunn
Newport, NC
Joined Jun 2007
40 Slice Flying
Hey Ritewing Flyers,just Wanted To Give Some Specs On The 40 Slice Mega 3 Turn,cc 35 ,2 1320 Thp Par. Not Series ,5/5 4/5 Apc,1 Ounce Lead Up In The Nose,c G Is About 7 3/4 . Flys Great Very Fast,flys Like Its On Rails, Guessing 80 To 100 Mhp,half Power Take Offs
Pilot Tim Nunn is offline Find More Posts by Pilot Tim Nunn
Old Sep 01, 2007, 10:27 PM
Atom1025 is offline
Find More Posts by Atom1025
Fly me to the moon...
Atom1025's Avatar
Sacramento
Joined Jun 2005
Good News & Bad News
I maidened the 60 today!!! I love it!!! It felt great right off the bat! A few click of up elevator, a few right clicks and she felt great. I think I have a new favorite.
Very stable, handled very well, speed was great for a wing of this size. Prolly 80-100. Never really left it open long enough to unload. I worry this motor will smoke at 50 amps! I am running the arc 2t longcan on 3s 7200mah packs, with an 8x4 direct drive. The thrust is enough to hover it in my hand. I am getting a new gearbox to try this motor on 6s, it'll bring the amps down to 30ish. This motor might do a 7x5 full throttle all day, its to soon to tell.
I got my demon lite almost dialed! I was really enjoying this one. Its sorta a beater so I am getting reckless with it. She is flying great now! I had to tweak the thrust angle, lower the rates, dropped an ounce of lead, and she is feeling great in the air! Not bad for a 200watt setup!
Now the bad news! My Beloved TL50 lite came in really hot! There was to guys who pulled over in this beautiful 48? Ford to watch us fly. They were standing in my landing path, if they werent there I would of prolly kicked the throttle and took it for another pass. But instead I slammed the elevator driving her to a major belly flop 3' above the earth. Would of been fine except this 10lb chunk of earth kissed the nose bringing the bird to an abrupt stop! 30-0 in a split seconed!That chunk of earth jumped off the ground about a foot vertically and a foot horizontally! Everything survived! The covering is trashed and I tore the henrys at the prop slot. Easy fix but that covering ain't cheap!
Had a blast though Been a while since I've gone out for a few hours and flown.
I am going to try to get in a couple more flights on the 60 this weekend.
Atom1025 is offline Find More Posts by Atom1025
Old Sep 01, 2007, 10:39 PM
punkrockd is offline
Find More Posts by punkrockd
Purples a fruit
punkrockd's Avatar
United States, CA, Walnut Creek
Joined Aug 2006
it was going way faster then 30 when it hit that mini boulder.
gonna check the video and see if it is worth a darn
punkrockd is offline Find More Posts by punkrockd
Old Sep 01, 2007, 11:01 PM
Purples a fruit
punkrockd's Avatar
Joined Aug 2006
here it is. need much more recording to cut up more good shots. so this one is choppy. i could spend more time making it better, but here ya go.
http://youtube.com/watch?v=HBpMARJtZu4
Old Sep 02, 2007, 12:37 AM
PaulVi is offline
Find More Posts by PaulVi
resU deretsigeR
PaulVi's Avatar
Dublin Ca
Joined Aug 2004
I had a bad day today.. Ither the batteries were not charged or the FS was a V1 and flew like do do or i spun the shaft in my mega on the tl50 all in all i should have stayed home today..
Better than all my bad luck hitting me sunday when im racing the miata..
PaulVi is offline Find More Posts by PaulVi
Old Sep 02, 2007, 12:51 PM
Atom1025 is offline
Atom1025's Avatar
Sacramento
Joined Jun 2005
We all gotta have bad days once in a while
So did ya get the 50 down safely? Did you check the prop adapter? Could it be loose?
What happened with the FS, did it fly at all?
Good luck at the races!!!
Adam
Old Sep 02, 2007, 02:08 PM
twilkers is offline
Find More Posts by twilkers
twilkers's Avatar
Livermore, CA
Joined Jan 2007
Hey Adam, ready to maiden my 60. what control throws did you use on yours? I have a het3w on 3s, 7x5e
tim
twilkers is offline Find More Posts by twilkers
Old Sep 02, 2007, 02:56 PM
mrforsyth is online now
Find More Posts by mrforsyth
So. Cal.
Is this correct? If so, I wouldn't recommend even attempting to fly this combination. If it's a 4W, you can do it. My 4W on 3S with a 7x5e pulls right at 50 amps static on good 3S 5000mah packs. A 3W will pull over 90 amps on 3S and 7x5e and will release the magic smoke in a hurry. Either the battery, ESC, or motor will smoke.
mrforsyth is online now Find More Posts by mrforsyth
Old Sep 02, 2007, 03:37 PM
Atom1025 is offline
Atom1025's Avatar
Sacramento
Joined Jun 2005
tim
He's Rite. That motor can barely handle a 6x4 on three cells.
I have my DR set at 50&70% for elevator. When she slows down you need a bit more elevator. The aileron is set at the same 50-70%.
50% is a good place to start and then you can go from there.
Good luck!
I got some Fan Fold what to build thread part II started by emoone!!! Don Sims Foamies (Kits) 188 Jan 23, 2010 08:28 PM
Build Log RiteWing 48-FT build thread theclaw Slope 46 Dec 09, 2007 08:53 AM
Mountain Models Tantrum Partial Build Thread.. Tram Parkflyers 142 Apr 03, 2004 10:41 PM
My Bobolink Build Thread (very Colibri like) Jim Poor Hand Launch 65 Dec 10, 2003 04:48 PM
Switchback re-build thread (or What the $#*& was that!) Biggles604 Parkflyers 17 Jun 23, 2003 09:34 PM
