Espritmodel.com Heli Air
Old Apr 13, 2008, 06:49 PM
tulz43's Avatar
Los Angeles, CA
Joined Sep 2007
Originally Posted by Atom1025
Yes sir, keep in mind that these batts were tired so a stronger pack may cause you to see 33 or more. Also elevation will have an impact on this. I'm at sea level pretty much.
One last question for ya (well for now anyway).. what esc are you running? I might want to go 4s later... but I think 3s is gonna be enough for now.
tulz43 is offline Find More Posts by tulz43
Old Apr 13, 2008, 07:36 PM
BlueGrass Rules
mando's Avatar
United States, IL, Dahlgren
Joined Nov 2003
Originally Posted by Wingman65
Finally getting the 50slice wrapped up. Here it is with panty lines (thanks Adam ) Plan is to run ARC 2t on 4s.
Nice job Wingman! You'll never notice the VPLs at 50 foot up and scoot'n by 100+ mph
Mando.....
mando is offline Find More Posts by mando
Old Apr 13, 2008, 08:02 PM
Fly me to the moon...
Atom1025's Avatar
Sacramento
Joined Jun 2005
I am running a CC Phoenix 35, for 4s the amps go up so a 45-60 may be needed.
For me 3s is fast enough.
Adam
Atom1025 is offline Find More Posts by Atom1025
Old Apr 13, 2008, 08:16 PM
Atom1025's Avatar
Sacramento
Joined Jun 2005
Originally Posted by jrplane
I have orderd a 40" demon,
I want to be pretty fast, What motor do you guys recomend? I would like to stay with 6s max. 3S would be cheaper but not as fast, 4S ? . I see in the thread (too many pages!) Microdan is used alot and so is mega.
Also servos, if you plane on burying them would metal gear be better choice? Any body using HS5645MG's or someing like that? All I have on hand is jr8411's , really don't want to use them. would hs85mg's be strong enough?
Thanks Jeff
Use the spektrum ds821 servos, they can be had cheap and are great, when using standard size servos metal gears are not really needed. The hs5475's are good the 5645's are just fine as well.
Run the ARC 28-47-1.5 on 4s its the best! Its faster then the 16-25-3 on 6s.
Regarding Micro Lightning questions.
Nuerofun: For me I tried to get mine as light as possible, thats why theres no covering. It will withstand more abuse with covering.
While we're on the subject, I'm nearing up my Mini Lightning build and am concerned about the floppyness f the airfoil near the wingtips. Should I be concerned about that at all? "
Not really as the elevons will help keep it solid, but you can add cf strips if you like, do as you see fit.
Dang Tony your giving me some competition on covering schemes. Yours make my stuff look boring
I've had the servo dip happen before as well, it seems the hot glue caused this maybe? Not sure but next time do the PU trick in those areas as well.
Adam
Old Apr 13, 2008, 09:04 PM
ededge2002's Avatar
Newmarket,Ontario, Canada
Joined Dec 2002
ok its not a "rightwing" but i used the build thread and wanted to post this as im building it the "right" way!
ededge2002
http://www.rcgroups.com/forums/showp...0&postcount=22
ededge2002 is offline Find More Posts by ededge2002
Old Apr 13, 2008, 09:23 PM
tulz43's Avatar
Los Angeles, CA
Joined Sep 2007
Adam
Wow... that would really put a hurtin on my batts. Think I'll stick with 3s and keep the wing on the less expensive side.
Old Apr 14, 2008, 12:16 PM
Fast is good
jrplane's Avatar
USA, IN, Hagerstown
Joined Oct 2003
Well I now see that running 4S or more I need a Ubec, Can anybody recomend one and where ot buy it.
Are you guys running a seperate battery on the ubec.
Jeff
jrplane is offline Find More Posts by jrplane
Old Apr 14, 2008, 01:10 PM
Mum is the word!
Joined Jun 2003
No ubec I use a 6v 5cell 2/3 aaa nimh it is way better and gives off no noise.The 4s is great on the arc 1.5 turn motor,i can get you all the gear if you need. Even the small nimh batt.
ck
Jeff
klique is offline Find More Posts by klique
Old Apr 14, 2008, 01:15 PM
Jay Garcia
JayGarcia's Avatar
Huntsville, AL
Joined May 2006
I was looking through this thread, and I like the way you guys are using fiberglass and spray adhesive. Can someone fill me in on where to find the adhesive spray and fiberglass mesh material? It looks like the stuff you use on drywall seams. I use 3M Super 77 all the time. Is it the 3M Super 90 that you are using here?
JayGarcia is offline Find More Posts by JayGarcia
Old Apr 14, 2008, 02:15 PM
ededge2002's Avatar
Joined Dec 2002
if you look at the start of this thread "thermalking" there is a great how to section....only 1730posts ago you will see the materials and where to get em lol.
ededge2002
Old Apr 14, 2008, 06:16 PM
Jay Garcia
JayGarcia's Avatar
Huntsville, AL
Joined May 2006
ededge2002-
Thanks for the reply. My bad. I swear I looked but did not see that post. Does the 3M 90 dry so it is non tacky. I have a wing which I want to re-cover, so that is why I am interested in this method. I do alot of composites fabrication. What about just using a vacuum bag and some laminating epoxy. My guess is that that would be too brittle and the fiberglass with 3M 90 is fairly ductile. 3 Weeks to go untill SEFF. Now with several projects underway I have to figure out whether I can fit this one in. So many tough decisions and so little time...
Old Apr 14, 2008, 06:34 PM
Atom1025's Avatar
Sacramento
Joined Jun 2005
Yes after 24hrs or so the 3M90 has almost no tack left to it but the monokote grabs on good.
Adam
Old Apr 14, 2008, 06:35 PM
resU deretsigeR
PaulVi's Avatar
Dublin Ca
Joined Aug 2004
I would use the s90 it does dry almost tack free but after your last coat of s90 let it set open in the air for 2 days this will ensure the lightest build because all of the solvents will flash off. also the mono coat sticks better when there is no solvent vapor trying to escape
PaulVi is offline Find More Posts by PaulVi
Old Apr 15, 2008, 12:05 AM
resU deretsigeR
PaulVi's Avatar
Dublin Ca
Joined Aug 2004
2006 Srt8
Just for some of you meatheads out there This was what we were working on the night we recorded the podcast.. I was running back and forth to assist my kid do the lambo doors..
Even Laine would like this one..
Old Apr 15, 2008, 12:10 AM
Fly it like you stole it..
Tram's Avatar
Florence, Al
Joined Oct 2000
Looks good.. butttt... What does it put to the wheels?
Tram is offline Find More Posts by Tram
I got some Fan Fold what to build thread part II started by emoone!!! Don Sims Foamies (Kits) 188 Jan 23, 2010 08:28 PM
Build Log RiteWing 48-FT build thread theclaw Slope 46 Dec 09, 2007 08:53 AM
Mountain Models Tantrum Partial Build Thread.. Tram Parkflyers 142 Apr 03, 2004 10:41 PM
My Bobolink Build Thread (very Colibri like) Jim Poor Hand Launch 65 Dec 10, 2003 04:48 PM
Switchback re-build thread (or What the $#*& was that!) Biggles604 Parkflyers 17 Jun 23, 2003 09:34 PM
