Old Apr 05, 2008, 03:27 PM
Micro Dan is offline
Find More Posts by Micro Dan
www.gobrushless.com
North Carolina
Joined Jan 2005
Thanks everybody.
we ran about 80 pcs this time and we completed all our fixturing.
just placed them on the site today and they are already selling.
Thanks for the help.
Dan
Micro Dan is offline Find More Posts by Micro Dan
Old Apr 05, 2008, 03:55 PM
PaulVi is offline
Find More Posts by PaulVi
resU deretsigeR
PaulVi's Avatar
Dublin Ca
Joined Aug 2004
Originally Posted by Micro Dan
Thanks everybody.
Dan
what speed controller do you recomend for the speed motor.. (amps) im hoping to get a bit cheaper than a CC they may be good but way over priced..
PaulVi is offline Find More Posts by PaulVi
Old Apr 05, 2008, 04:34 PM
www.gobrushless.com
North Carolina
Joined Jan 2005
Depends on the cell count but the Markus and Motrolfly work perfectly as do the Scorpion.
25A works just fine for 3s.
Dan
Old Apr 05, 2008, 04:45 PM
PaulVi is offline
resU deretsigeR
PaulVi's Avatar
Dublin Ca
Joined Aug 2004
Dan
So would a 25 amp Scorpion work I have one of those now.. Rember i was having issues with my custon on the HEXtronics i was trying to use
Any plans on doing a 10 mag speed motor..
And if i have not said it.. Thank you for all you do for us wing nuts..
Old Apr 05, 2008, 05:16 PM
methos is offline
Find More Posts by methos
methos's Avatar
Canada
Joined Jun 2006
I have a CC Thunderbird 36 (which goes from $40 - $45) in my Wild wing on 3s, but I have not found an ESC other than the CC Phoenix that will run it well on 4s with a prop larger than 4.75 x 4.75. With the Phoenix 45, I run it with 4s 2500mAh and a 5.5 x 4.5 prop.
methos is offline Find More Posts by methos
Old Apr 05, 2008, 06:02 PM
PaulVi is offline
resU deretsigeR
PaulVi's Avatar
Dublin Ca
Joined Aug 2004
Welp i happens in ever wings life... I think my stalled to cart wheel landing today may have caused enough damage to make it not worth repairing..
I had to dig a servo out and it turns out it was a bad driver board (overheating bad) and then then t plate for the motor mount broke today as well
with the amount of surgey to fix it im not too sure i want to..
I think it is time to dige the rest of the gear out and build a new wing..
Heck this wing has survied 3 in air fires.. and 2 trips to AEF and a trip to reno... so i know it is lucky...
Kind of a shame to toss it out as the rest of the air frame is solid
Old Apr 05, 2008, 06:41 PM
Diggs is offline
Find More Posts by Diggs
Not your average DiggsyBear
Diggs's Avatar
Raleigh, NC
Joined Dec 2006
Motor mounts are finally finished.
custom machined by us at MicroDAN.
Thanks to Adam for his help in the design.
http://www.gobrushless.com/shop/inde...=MDRITEWINGMNT
Dan
www.gobrushless.com
That is one Sexy Motor Mount!! However, I am a bit confused, which isn't unusual Is this designed for one of your outrunners? Looks like an Inrunner mount to me, but again, I can be a bit thick at times. Would love to see one with a motor on it.
Either way, its a badazzz lookin mount.
Diggs
Diggs is offline Find More Posts by Diggs
Old Apr 05, 2008, 06:48 PM
Charger is offline
Find More Posts by Charger
I B Chargin'
Charger's Avatar
Arizona
Joined Aug 2003
Diggs
Does this clear it up??
Paul........sounds like you got a lot of life out of that bird!!
Charger is offline Find More Posts by Charger
Old Apr 05, 2008, 07:28 PM
Atom1025 is offline
Find More Posts by Atom1025
Fly me to the moon...
Atom1025's Avatar
Sacramento
Joined Jun 2005
Paul What bird was this? Tell me it was'nt the oldest flying Ritewing....
Atom1025 is offline Find More Posts by Atom1025
Old Apr 05, 2008, 10:10 PM
hawkz is offline
Find More Posts by hawkz
USA, CA, San Diego
Hey Adam. What microdan motor should I be looking at? The 2800kv speed motor or the 2535kv motor? Or should I get one of each? I plan on running 6x4 or 6x5.5 props on 4s. Will the 2800kv motor burn out if I run it on 4s with these props? Gonna be putting them in the TL40 and TL50 Slice. I also have a couple Mega 16/15/3 and an Arc 28mm 2.5 turn motor. Any suggestions will always be appreciated.
hawkz is offline Find More Posts by hawkz
Old Apr 05, 2008, 10:13 PM
Diggs is offline
Diggs's Avatar
Raleigh, NC
Joined Dec 2006
I think so, is this using a tube in that hole? That is what was confusing me. Looked like a 28MM hole for an inrunner at first. Thanks for the pic!!
Diggs
Old Apr 05, 2008, 10:19 PM
Atom1025 is offline
Atom1025's Avatar
Sacramento
Joined Jun 2005
Use the custom(2535kv)wind for 4s and 6x4 or 6x5.5
The 2800kv is good on 4s and 5x5 or I. Its good for 3s and a 6x4sport. or 6x5.5.
Old Apr 05, 2008, 10:22 PM
Atom1025 is offline
Atom1025's Avatar
Sacramento
Joined Jun 2005
Diggs
Any motor that uses an 8mm tube mount will fit this, IE: Micrrodan Little screamers, CCDR, etc.
The bore on the hole is 8mm, so to answer your question yes there is a tube in the hole. The same tube that holds the stator and bearings.
Old Apr 05, 2008, 10:30 PM
Wingman65 is offline
Find More Posts by Wingman65
Build, Fly, Crash..Repeat
Wingman65's Avatar
St. Peters, Mo. USA
Joined Mar 2005
Demon Power
Changed my Demon drivetrain to ARC 1.5t on 5s A123 cells and 6x4 sport prop. I'm very impressed with static test numbers. 65A and 800W Battery voltage started at 17v and sagged to 12v under full load. I think this setup may be a winner, hopefull find out tomorrow.
Tony
Wingman65 is offline Find More Posts by Wingman65
Old Apr 05, 2008, 10:53 PM
Diggs is offline
Diggs's Avatar
Raleigh, NC
Joined Dec 2006
Thanks for the info guys!! I think my lightning will get one along with a micro dan motor. Adams did so well, seems like the perfect setup.
Well, I said it before, but this time it really is done and ready to fly. The dual motor Demon I bought from Morphs ages ago. Finally got the amps and props and escs all setup so that I shouldn't kill anything during the flight. 40amps at just shy of 500 watts per motor!!
Diggs
I got some Fan Fold what to build thread part II started by emoone!!! Don Sims Foamies (Kits) 188 Jan 23, 2010 08:28 PM
Build Log RiteWing 48-FT build thread theclaw Slope 46 Dec 09, 2007 08:53 AM
Mountain Models Tantrum Partial Build Thread.. Tram Parkflyers 142 Apr 03, 2004 10:41 PM
My Bobolink Build Thread (very Colibri like) Jim Poor Hand Launch 65 Dec 10, 2003 04:48 PM
Switchback re-build thread (or What the $#*& was that!) Biggles604 Parkflyers 17 Jun 23, 2003 09:34 PM
