Espritmodel.com Heli Air
Old May 11, 2007, 05:51 PM
Joined Oct 2006
Solidworks wing modeling
Hi guys ,
I am modeling wing with intention to cnc mill molds later. The shape can be seen on the picture I have attached. What is the most efficient way of protruding airfoil to make this shape ? One way is to produce a lot of cross-section sketches and use LOFT tool- this way seems OK , but takes too much time. Another idea is to select leading edge and trailing edge lines as guide for an airfoil to follow, the problem is that I have now idea how to do this- Please help ! I am using Solidworks .
Thanx for help,
Konstantin
kostixx007 is offline Find More Posts by kostixx007
Old May 11, 2007, 10:20 PM
Heli Headcase
Orion_V's Avatar
Cliffside Park, NJ
Joined May 2003
you can use a sweep feature to do that...you have to create the sweep path of course using a sketched curve or line depending on the shape of the wing
Orion_V is offline Find More Posts by Orion_V
Old May 12, 2007, 11:38 AM
4th Generation
ShaverR6's Avatar
Canada, MB, Winnipeg
Joined Sep 2004
The soildworks help file has excellent tutorials explain how to use all of its features. Have you tried it?
ShaverR6 is offline Find More Posts by ShaverR6
Old May 12, 2007, 07:25 PM
Joined Oct 2006
Yes , I know that sweep tool can be used , but I am still experiencing problems with that ! what should be selected as path ? what should be selected as guide curves ?
Yes , I have used tutorials , and I can only say that they are very general , not going deep into the details.
Old May 13, 2007, 07:38 PM
4th Generation
ShaverR6's Avatar
Joined Sep 2004
Ok, what about using the loft tool? I would use the leading and trailing edges as guide curves. These would have to be two different sketches. Then use your root airfoil as your profile. You don't need to use lots of airfoil profiles. Just use a root, then perhaps the profile located near the wing tip.
This probably didn't nail what you were looking for but its a start. Let me know if I can be of more help.
Here is a rough example of what I mentioned.
Old May 13, 2007, 07:46 PM
4th Generation
ShaverR6's Avatar
Joined Sep 2004
You can accomplish a lot with the loft feature, here is a preliminary hull for an amphibious vehicle I modeled for a class of mine.
Old May 14, 2007, 04:45 PM
Joined Oct 2006
Thanx for help ! I will try playing with LOFT tool
Old May 14, 2007, 08:52 PM
4th Generation
ShaverR6's Avatar
Joined Sep 2004
Good luck, if you have any questions I'd be happy to help.
Wing Modeling Help For Cnc eightwgt Slope 11 Mar 22, 2005 07:13 PM
