Old May 11, 2007, 07:18 AM
Ralph Weaver is offline
Find More Posts by Ralph Weaver
Ralph Weaver's Avatar
Indianapolis, IN USA
Joined Nov 2000
Measuring RPM from brushless motor lead
Several data logger measure rpm from one lead of the brushless motor. I assume that it's just hall effect with a bit of filtering. Anyone have more info?
Ralph Weaver is offline Find More Posts by Ralph Weaver
Old May 11, 2007, 09:41 AM
AndyKunz is online now
Find More Posts by AndyKunz
AndyKunz's Avatar
Illinois
Joined Sep 2001
You have to watch for the direction of the current to change, not just for the current to be there or not. The PWM causes the current to flow in one direction, but off and on. The commutation causes the direction of the current to change.
A low-pass filter helps get rid of the PWM pulsing.
Check out the commutation sequence in one of the TI data sheets to get a better understanding.
Andy
AndyKunz is online now Find More Posts by AndyKunz
Site Sponsor
Old May 11, 2007, 12:24 PM
Joined Nov 2000
Makes sense.
I have a tach that uses an optical sensor, but would like to be able to just clamp onto a wire and get more reliable readings. Maybe I'll get one from Eagle Tree and take it apart - or just adapt my tach to use it.
Old May 11, 2007, 01:47 PM
jeffs555 is offline
Find More Posts by jeffs555
"Simplify, then add lightness"
Raleigh,NC
Joined Nov 2000
Just a thought, and haven't tried it, but it might be possible to put an led with a series resistor across two of the motor leads and read the rpm with an optical tach. With a low current led and a high value resistor, it shouldn't upset the controller timing. You would have to scale your tach reading for the number of poles.
Again, don't know if it would work, but would be simple to try.
PS just looked at the Eagle brushless rpm sensor, and it looks like it has connections for two of the motor wires. It is probably just a filter and comparator or maybe an opto-isolator.
jeffs555 is offline Find More Posts by jeffs555
Brushless Motor Lead Broke Cincy E-Flyer Power Systems 2 Jun 06, 2005 10:06 AM
Measuring voltage on a brushless motor ? ChrisP Power Systems 3 Apr 25, 2005 07:01 AM
Brushless motor lead question Zhack Power Systems 3 Mar 07, 2004 08:39 PM
measuring amps from a brushless motor? rcnutt Power Systems 4 Jan 16, 2004 12:10 PM
Brushless motor lead clipping Wiseguy Parkflyers 9 Sep 18, 2003 12:27 PM
