| RCCars | Crack Roll | Flying Giants | RC Power | The E Zone | Lift Zone | Our Sponsors | |||||||||||||
VS Tank Infrared 1/24th Scale Tiger I and Leopard 2 A5 Review
Hobbico is now importing the the VS tank lines of 1/24 scale infrared combat tanks! Currently available are the Germany Tiger, the M1A2 Abrams and the German Leopard 2 in the A5 and A6 versions all with at least a couple of different paint scheme options. I have always enjoyed the look of tanks, and the VS Tiger tank looked very authentic to my eye and a quick comparison to pictures in a book. I thought it would be fun to get a couple and have some infrared combat with friends in the evening, and I was right! It has proven even more fun to let two visitors do battle. Now, let me share the fun with this review.
Tiger Tank I Early Production Model
Tank Set Includes:
Additional Items Needed:
Features:
Infrared Battle Features:
Leopard2 5A Tank
Tank Set Includes
Features
Infrared Battle Features for Both Tanks:
Both tanks come already assembled. I only had to install the batteries into the tanks and the transmitters, install the antennas and install a few details such as the tank commanders.
Instruction Warnings
Per the instruction manuals, do not operate these tanks in water, on sand or on carpet. Do not operate them for more then 10-15 minutes at a time or they might overheat.
Tank a Look Around
1/24 scale
These are nice size tanks. They can be easily seen and operated in a variety of settings, but are easy to store; the boxes will fit easily on most shelves. Even an apartment dweller should be able to find space for these tanks for both operation and storage.
Operational sounds & Lights
Both tanks have operation sounds that include motor/tread sounds when the tanks are in motion and firing sounds when the main gun is fired. Both tanks have exploding sounds and flashing lights from under the turret when they are hit with an infrared shot from the other tank. The Tiger I also has machine gun sounds, but the Leopard 2 A5 does not. Both tanks have two operating LED headlights. The Leopard 2 A5 also has rear LED red taillights. These tanks both make robust sounds, nice and loud! Neither of the tanks’ motor/tread sounds are truly authentic operational sounds. While I wouldn't use them to dub a movie soundtrack of real tanks, the sounds were nicely mood-setting - especially the Tiger. There was no volume control on either tank.
Tiger I Movements
Neither of these tanks have proportional control and neither one uses a joystick. The tanks have different transmitters and therefore do not move in an identical manner. As one would expect, the Tiger I can circle in place at two speeds and in either direction. I found the slow speed worked very nicely, but that the fast speed was too fast for me. The turret rotates 330 degrees. The Tiger has three forward speeds, three forward turning speeds, two reverse speeds (straight or turning) and two turning radii. I found with these speed options, I didn't miss proportional control, and I quickly became very comfortable with these control options. It can climb an incline of 30-35 degrees in forward or reverse. As mentioned above, it makes tread sounds as it travels that I found these to be fun in operation (but my wife didn't appreciate them while watching TV). The Tiger I's transmitter is a two-handed design. The turning buttons in the upper right corner do nothing on their own and must be used with the forward and reverse buttons on the left to steer the tank in a turn. The 4 buttons on the bottom right with Roman Numerals cause the Tiger I to pivot or circle in place. This is an outstanding control system! The best I have experienced in the dozen plus tanks I have operated before. Touch is a personal thing, but I thought it had excellent control. The transmitter has a very nice ergonomic design and allows for quick control motion. Multiple actions can be done at the same time such as firing while turning or moving turret while running.
Leopard 2 A5 Movements
The Leopard 2 5A transmitter has 5 columns of buttons. The outer two columns are for combat, and the center three are for movement. The Leopard 2 also has three forward speeds but only one reverse speed. These directional speed buttons are in the center column of the transmitter. To the right of that column are two buttons for right forward turns and one reverse turn, and the left side column has three identical buttons for the left. To pivot or circle requires using two buttons simultaneously (one from each of the last two columns mentioned). The Leopard 2's controls are similar to those I have seen from some other tanks and they are good enough though not as smoothly operating the Tigers I’s. Both tanks’ top forward speed was about the same. I missed having two back-up speeds with the Leopard 2 - it only backs up quickly, no slow speed back-up.
Combat Basics
Combat is performed by hitting the fire button on the transmitter. The tank fires an infrared beam in the direction that the turret and gun barrel are pointing. At the same time, there is a firing sound and the tank recoils. In the Tiger I the gun barrel also recoils. They advertised a range of 8 meters (28 feet) indoors and about 20 feet in direct sunlight for the infrared combat. I decided to test the claimed range as well as the angle of attack (how accurate did my aim have to be to score a hit). See the results in my combat video below. For combat, each tank starts with 40 shots, and after those are fired the tank is out of ammunition. There is a three second delay between shots to account for loading time. Each tank records six hits, and with each hit the tank shakes, makes an exploding sound, and lights located under the turret flash. After a tank is hit it has a short invulnerability period of about 6 seconds during which it can’t be hit again. After six hits are scored, a tank is destroyed and the tank has to be reset by turning if off and back on. On the Tiger I, the combat controls are on the top of the transmitter. Right top front fires the main gun and left top front fires the machine gun. The middle buttons on both sides raise and lower the gun barrel. The rear right button turns the turret to the right while the left side button moves it to the left. Good action, good sound and good control.
The Leopard 2 A5's combat buttons are in the outside columns. the left outside column turns the turret to the right with the top button and to the left with the bottom button. The right most column's top button fires the main gun and the bottom right button raises and lowers the barrel. There is no machine gun for the Leopard 2 A5 tank.
"That cover was really really on there good!"
My first night with these tanks, I was shooting at the parked Leopard 2. I hit it from all directions except when the commander was between the sensor and my Tiger's gun barrel so I parked the Tiger I and looked for a sensor. The manual didn't show the sensor on the Tiger I - just on the Abrams. The actual sensor cover was much smaller then the one on the Leopard so I wasn't sure if it was a sensor cover or just a detailed part. I put a fingernail from each hand under the top of the cover and tried to pry it off. I tried to lift the cover, and the whole tank lifted off the ground. I wondered if the sensors might be under the turret as part of the light system used to show a hit. I fired shot after shot at the Tiger from point blank range to as far back as ten feet. The only kills were shots from behind at the rear light bar under the back of the turret from about a foot. I worked on the problem for hours and finally sent Hobbico an e-mail. they responded the next morning, and I soon learned the little molded piece was indeed the cover. Armed with the certainty, I got a small nail into the small opening and popped it off and twisted and raised the sensor. The Tiger had gone from invincible to an ordinary target for the Leopard. In my defense I just want to say: "That cover was really really on there good!"
Infrared Combat
Both tanks fire an infrared beam from the gun barrel that is supposed to register on the other tank as a hit. The Leopard 2 A5 has a sensor that is covered by a small turret when not in use. This protective turret lifts off and a sensor pops up. The protective turret can be stored under a turret hatch cover for safe keeping. I had no problem scoring hits on the Leopard 2 with the Tiger I from most angles around the tank. I found the only dead spot was when the tank commander of the Leopard was between the Tiger I's gun and the Leopard's sensor. He was like a hockey goalie and would block my shot. Like a goalie, he can be pulled leaving an "empty net" for no blocking. The Tiger I has a covering with pins to the left of the tank commander and slightly behind him. It took some effort to remove this cover the first time (see side bar) but since then it pops right off when I need it to. A slight twist and the sensor popped up on the Tiger I. There is a very small dead spot on the Tiger I tank if you attack from the left middle area as the tank commander and the raised hatch cover serves as a blocker from a couple degrees of angle in that direction. Otherwise, with the sensor up the Tiger was a good target.
Combat Tip: Both tanks pivot in place faster than their turrets turn. In combat, pivot the tank don't turn the turret unless the aiming adjustment is a very tiny adjustment.
Range and accuracy of the Infrared system
Indoors
The first video below is just offered as proof that the infrared system has at least the advertised indoor range of 28 feet. The second video shows the dead zone on the Leopard when the tank commander is in place, and that the infrared gun scores a kill even if a full tank off in front, behind or above the target tank.
Outdoors
Under a canopy of heavy shade trees I had an infrared kill zone from about 12 feet or less at noon and slightly greater than that about 8:00 in the morning and 6:00 at night. Under the shade of one medium tree in an otherwise open field my infrared kill range was a maximum of about 3-5 feet with an occasional rare kill from 6-8 feet (but that was extremely rare). In the full noontime sun the kill range was down to 1-2 feet. An occasional kill, but very very rare from 4 feet plus away. Most of my combat will be in the evening anyway or indoors, and any outdoors combat on a hot and sunny day will be under the shade trees for me.
Are These tanks For a Beginner?
Either tank can be enjoyed by a beginner that has down the elements of movement and combat basics. Combat with a skilled operator will take some practice - newbie tank operators are much like newbie pilots at the front... the fodder for aces. That said, combat in bright daylight is a great equalizer. The combat video below features newbie operators with only a couple of minutes at the controls before I started videotaping.
Battle Video/Photo Gallery
The following combat video was shot slightly after 6:15 PM on May 23, 2007. The combatants were newbies to tanks - John and his son Kody. A good time was had by all.
Pluses & Minuses
Pluses:
Minuses
I have enjoyed the infrared combat as have the several friends I have done battle with to date. I think we will be having major tank battles in just a few weeks, but you can have fun with just one of these tanks. I really enjoy the two handed operation of the Tiger. The ease of operation and the quality of sound make them enjoyable to operate. As with most things in life they are more fun when you can interact with someone else. Last edited by Angela H; Jul 11, 2007 at 10:39 PM.. |
Thread Tools |
#2 |
Well, that looks fun for about 10 minutes. After that its eBay time.
#3 |
Im stupider than you!
How Dumb. The slow tanks,not the review,to each his own I guess.
#4 |
↑ Δ ← ♣ ↓ ♠ → ♦ ©
If you don't have nothing nice to say, don't say anything at all.
Mike, ignore these guys. The tanks look fun and your review was GREAT! Bill |
#5 |
We all have different interests, especially in this hobby. That is one of the great things about this hobby. I like almost everything RC. I love watching that Tiger tank in operation and the barrel recoil when it fires. My favorite plane is often the one I am flying at a given moment.
#6 |
The sky is my playground.
Looks like fun to me...
#7 |
Survival is Attitude!
Wife has NOTHING to do with RC, but she said she wanted to shoot me with a tank a couple of Christmases ago. Might just have to ante up for a pair.
You never know, she might get into airplanes later! |
#8 |
I have a pair of "tanks" that have an IR laser and sensor and shoot the other person. When you get "hit" you get an electric shock through your controller. It's good fun to watch a couple drunk friends get pissed at each other.
#9 |
Like russian roulette?!?.........
#10 | |
#11 |
I think this is excellent work!
way to go with all the testing...Now what would be cool was it there was a battle simulation.
I wonder if those tanks can be outfitted with mini brushless motors, and if a lipo will fit on the inside of them. maybe have an all out infrared war with 10 tanks vs 10 tanks, and real terrain with real obstacles. heck maybe even incorporate a slo flyer or two into the mix with the infrared rc system for planes. Now that would make a good video. |
#12 |
I'm looking into the tank thing especially since the r/c heli didn't work out. Being that what space I have is limited for flying, I am too looking for something that is ground based. I'm figuring out the pros and cons of the r/c cars vs. the tanks.
The tanks would raise my brow even more if they had more speed. So, has anyone tinkered with theirs (motor, suspension)? I have in-mind an off-road chassis and suspension utilizing the tank tracks and body. Last edited by BUZZARD464; Jul 26, 2007 at 10:03 AM. |
#13 |
Achieving Air Superiority
I don't get it..why do they need to be faster?...I think the speed is about scale for the tanks...I have a set of no name I\R battle tanks from ebaY in this scale and they are a blast as long as you have an enemy to shoot at...takes 2 to play...anyway, these are the Cadillacs of the RTR IR Battle tanks. Nice review..I know, some people just don't get it..its gotta be fast or its boring eh rhondaward? Maybe we should stick a mamba in it and then it will be cool yes?
| Thread Tools | |
| 1/6 Scale Tiger Tank Accessories on ebay | Mike Stannard | rec.models.rc.land | 0 | Oct 05, 2003 04:01 AM |
| 1/4 Scale Tiger Moth Battery Temp | Bundy | Scale Electric Planes | 2 | Aug 07, 2003 01:38 AM |
| Fs : 1/4 Scale Tiger Moth Rtf | fchristian | Aircraft - Electric - Airplanes (FS/W) | 3 | Aug 11, 2002 02:21 AM |
| 1/5th Scale Tiger Moth | Gordon | Scale Electric Planes | 16 | Jan 03, 2002 03:00 AM |
| 1/4 Scale Tiger Moth ? | GordonTarling | Scale Electric Planes | 10 | Jul 03, 2001 08:16 AM |
