Old May 10, 2007, 07:11 PM
flyboycrawford is offline
Find More Posts by flyboycrawford
Joined May 2007
Help!
Newbie asking Tony 65x55 for Advise on Blu-Baby Build
Hello Tony, I am very impressed with Your build of the 33" Blu-Baby and I thank You for all the info. and help so far. I hope to have one built by the next weekend, However, I am stupid when it comes to the proper radio gear for this model. Let me tell You what I have on hand and then please instruct me as to what I need to complete the power plant. I have the J250 motor, A 20 amp GFS Micro Speed Control, 3 HS-81 Hitec servos, and 2 Ni-MH 7.2 volt 900 mah batteries. I know the motor will work, can I use any of the other stuff?? What size prop to use, I can't find any labeled GWS 4350 with rubber connectors. Thanks for the help.
flyboycrawford is offline Find More Posts by flyboycrawford
Old May 10, 2007, 08:53 PM
Tony65x55 is offline
Find More Posts by Tony65x55
I'm not flying backwards!
Tony65x55's Avatar
Oshawa, Canada
Joined Sep 2004
You're in pretty good shape. The J250 will work direct drive, although it would be better in a GWS EPS-100(C) drive. Run a GWS 4025 prop with it or a GWS 9070 prop with the gear drive. Use two of the HS-81 servos, one for rudder, one for elevator. I don't know the speed control you mentioned but it is probably OK too. Those batteries will certainly deliver the power required but they are probably very heavy. The Blu-Baby was designed to be very light and needs to be if you are running a "minimum" motor like a J250 direct drive. I would recommend you pick up some lithium polymer batteries and an inexpensive charger for them. If you plan on using these lipos with a J250 they must be capable of delivering no less then 7 amps continuous or you'll fry them.
I hope this helps,
Tony
Tony65x55 is offline Find More Posts by Tony65x55
Help! Newbie asking Tony 65x55 for Advise on Blu-Baby Build flyboycrawford Foamies (Scratchbuilt) 5 Feb 24, 2008 12:14 PM
Looking for advice on a twin engine build cessnajfb Electric Plane Talk 23 Dec 04, 2005 02:10 PM
Newbie needs advise on the vip jaycey High Performance 11 Sep 30, 2004 02:16 PM
Newbie: Stuck on E-Starter Build Suntzu GWS (Grand Wing Servo) 17 Feb 03, 2004 09:58 AM
