Old Aug 28, 2009, 02:06 PM
mangi is offline
Find More Posts by mangi
http://www.youtube.com/watch?v
mangi's Avatar
Joined Aug 2009
Hy dear modell pilots! my name Dezsi from Hungary
please show my drenalyn video:
electro drenalyn fun rc airplan (2 min 2 sec)
Other videos www.rchalas.mlap.hu
Wery hapi and fun airplan. Y am love the simple modelss.
and pic:
And build the mega drenalyn
wing span: 90cm engine: os max25 3pcs normal servo. Video later.
Picture:
mangi is offline Find More Posts by mangi
Old Aug 28, 2009, 02:42 PM
goldguy is offline
Find More Posts by goldguy
flyin' fool
goldguy's Avatar
Vancouver Island, Canada
Joined Jul 2003
Thanks for posting the video. Nice to see others know a great design. It's hard to believe this design is over 10 years old now.
goldguy is offline Find More Posts by goldguy
Old Sep 04, 2009, 05:23 PM
Atx_Heli is offline
Find More Posts by Atx_Heli
Austin, TX
Joined Jan 2009
Just maidened a 20" Drenalyn....what a floater and great inverted!....have to add a rudder for better hovering next....
Construction: 6mm white Depron...no reinforcing required..."I" beam fuselage to allow hiding the electronics since it has no gear...hot glue throughout
BW -1300 motor, GWS 8X4HD, 3S450 mah Hyperion 5C charge Lipo, HXT900 servos for elevons...
AUW 7.5 oz...2.75oz/sft wing loading....CG at 29% of chord
I found that this model flies a LOT better than my 24" Don't Panic (Delta shaped Drenalyn)....could be that the Depron stiffness is in play here....the DP was made with 6mm EPP with a Depron rib on each wind side to stiffen it chord wise...also, the loading on the DP was about 4 oz/sqft,but I don't think this is the issue...I think the round LE has a significant effect on the flight characteristics...
This and a BW powered, 16" Depron Duplex Delta are my curent "fly everyday" planes....the DDD in any weather....we'll see how the Drenalyn does in wind later this week...will probably have to switch to my 1100mah pack and forward CG...
Atx_Heli is offline Find More Posts by Atx_Heli
Old Sep 04, 2009, 06:01 PM
goldguy is offline
flyin' fool
goldguy's Avatar
Joined Jul 2003
2.75 oz/sft, that's a winner for sure. As you've discovered, the Drenalyn's round LE and undercambered airfoil is it's strong points and yes, it loves inverted and about anything else you can throw at it.
I just maidened a FFF 19 incher and was planning on close to a loading of 3 oz but had CG issues. (too much color junk on the tail area) Had to go with a heavy Komodo, 25A ESC and 3S, so it's up to over 4 oz/sft. Flies up a storm, but lacks that light feel.
On windy days balance nose heavy. I've sloped mine numerous times, so it can fly without a motor too.
Old Sep 05, 2009, 05:41 PM
Atx_Heli is offline
Austin, TX
Joined Jan 2009
Just spent an hour of flight time with my 20 incher (with added rudder)....the more I fly it, the more I love it ..this thing does anything you can think of except knife-edge....this might be my all time favorite foamie ..
just a thought on your CG issue forcing a bigger motor....why not just tack on a 2 or 3" nose box extension?...my next Drenalyn is going to be another 20" 6mm Depron one, but I want to move the servos back within a few inches of the elevons and rudder...I intend to make a nose box of 9mm EPP forward of the LE such that with the BW and ESC, I get a CG at 30% without battery...I prefer to have the battery mount over the CG so that capacity changes don't HAVE to affect CG...and this will give me an EPP crash bumper ....most of my dings to models seem always to be the firewall mount or forward fuselage....usually from low inverted
on my 16" Depron Duplex Delta I used a 6mm EPP fuse with 4.5mm Rediboard wings and it has held up very well to the many "head plants" I've done with it...
in general, what if any differences have you noticed between your Depron and all-EPP Drenalyns?....I am a bit concerned that if I went all EPP, the lack of absolute wing ridigity would affect its precision, which is very good right now...
in my DDDs, if I use EPP for the wings, it just doesn't have the speed range that a Depron wing allows...and wide wide speed range is the triple D's forte ...fun slow, but can be a bat out of h_ll when you want...
I am thinking about putting a few of my other planes into salvage now...
lets see.....
YAK55...nope....3D just too good
Super Slofly...nope....just too nice a slow flyer
Maverick....nope....smoothest fast aerobatic plane I've got
Mini Maverick...nope...same but crash resistant...its EPP
SD....maybe....elegantly simple, but not as much fun to fly
mini SD...nope....just too easy to throw in the car anytime
NB...maybe...the Drenalyn does everything and much more that NB does
DDD...never....best speed range of any plane I've built..
Old Sep 05, 2009, 05:51 PM
Kokopeli is offline
Find More Posts by Kokopeli
Curiouser and curiouser
Kokopeli's Avatar
Rochester, NY, USA
Joined Oct 2005
Oooohhh mannnn...
Please 'splane what all the DDD NB SD mean.
Kokopeli is offline Find More Posts by Kokopeli
Old Sep 05, 2009, 07:09 PM
Atx_Heli is offline
Austin, TX
Joined Jan 2009
Originally Posted by wjbite
Oooohhh mannnn...
DDD = Depron Duplex Delta .... http://www.rcgroups.com/forums/showthread.php?t=559186
NB = Nutball...
http://www.rcgroups.com/forums/showthread.php?t=836389
SD = Simple Delta....
http://www.rcgroups.com/forums/showthread.php?t=867083
Old Sep 05, 2009, 07:11 PM
goldguy is offline
flyin' fool
goldguy's Avatar
Joined Jul 2003
Ya gotta learn to walk the walk and talk the talk .
Old Sep 05, 2009, 07:36 PM
goldguy is offline
flyin' fool
goldguy's Avatar
Joined Jul 2003
This thread is now over two years old and it's nice to see a few have discovered how great the Drenalyn really is. It's my all time favorite for indoor and out door. NutBalls are silly fun, but your can get a bit more serious with the Drenalyn. It's solves all the problems of other low aspect ratio flattie wing platforms.
Building one in EPP works great. It's important where you place the CF to get the bend at the LE and the reflex, although the reflex can be tuned in with the elevons. The airfoil shape adds to the rigidity of the floppy EPP.
I flew the heck out of my 19" the other night and it was a blast, even being porky. I even left my NutBall at home and got the gears from my FB's. There were lots of others there to make up for it though.
I've got an EPP 16 incher at under 4 oz. RTF for indoor and it's absolutely the best foamy yet that I've build for confined flying, and I've built lots of different designs. Indoor is just around the corner and I'm going for a target of 4 oz. for a 17 incher to take it up a notch.
I brought you guys the Dart and NutBall, so you can trust me on this one too. Give the Drenalyn a try and you'll realize the name is appropriate.
Guaranteed or double your money back.
Old Sep 06, 2009, 03:47 AM
dekan is offline
Find More Posts by dekan
D'oh.. Dumb Left Thumb
dekan's Avatar
London, UK
Joined Nov 2006
Frank, the curved wing is too much effort in Epp for the average NB builder , and on top of that the Gpw Fan club aint bitting....
dekan is offline Find More Posts by dekan
Old Sep 06, 2009, 04:10 AM
Azarr is offline
Find More Posts by Azarr
RIP Azarr - "Old age is not for sissies"
Azarr's Avatar
Dayton Intl, Ohio, United States
Joined Jan 2000
I built one from the plans on David's site years ago before we had the equipment we do now. It may be time to revisit the Drenalyn. I have a 17g motor without a home at the moment so when I finish up a couple of thiings I'm working on I may build a 17" version.
Azarr
Azarr is offline Find More Posts by Azarr
Old Sep 06, 2009, 04:12 AM
goldguy is offline
flyin' fool
goldguy's Avatar
Joined Jul 2003
For the extra effort to build, which isn't really that much, the Drenalyn is well worth it since it out performs most. Why would anyone not want that?
Old Sep 06, 2009, 08:45 PM
Atx_Heli is offline
Austin, TX
Joined Jan 2009
Drenalyn on steriods
Labor day weekend....might as well build another foamie...
target was a small version out of 6mm EPP for a 10g motor with ultra light landing gear for living room flying ...
off to the foam bin, found a big scrap, but a 14.75" WS was all that could be had...no problem, should work fine with 5g servos elevon only and 10g motor on a 3S small battery...
mark, and start to cut and realize that instead of a 1.3# 6mm sheet, it was a 9mm 1.9# scrap...oh h#$@ ...well, lets see what develops...
what developed was a 2.5oz airframe, one a gorilla could sit on , but heavy...by the time the 10g motor and gear was added, it could barely fly with a 2S at 5oz.....okay,but mushy on 3S and the motor was getting hot....
what the heck, rather than scrap it, I changed the 10g for a high KV BW and a 2S450mah battery....6.5oz AUW...4.3 oz/sft...
boy is this thing fun!...not floaty like my <3oz/sft 20" Depron version, but still harriers, slow flys (@ a fast walk), and prop hangs great(notice the extended nose moment)..with its CG at 30% it flies inverted hands off...and its a rocket when called for...
plus its nearly indestructible..its built like a mac truck...I planted it full power from 5 ft several times horsing around with it and no damage ...just bounce
plus its very small...toss in the front seat easily..
sorry mini SD, you've been replaced as my toss and go plane...love these Drenalyns!
Don't be afraid of 4+oz/sqft loadings, these things still fly great at 4-5oz/sft..
Old Sep 06, 2009, 11:20 PM
tymbrewolf is offline
Find More Posts by tymbrewolf
Joined Feb 2007
I might give the Drenalyn a go this fall, but miss nice easy to print BW sized plans. I will need something esle if I ever get tired of my Bullseye deltas as I haven't flown anything else since them. I still haven't gotten to the joystick or the xp-39 either which have been haunting me for months along with a foamie gyro from one of them other RCG forums. The skycart looks interesting. I keep watching this thread hoping for some decent printable PDF plans in American measurements that don't require too much thinking. I am rather patient...
tymbrewolf is offline Find More Posts by tymbrewolf
Old Sep 07, 2009, 09:22 AM
Atx_Heli is offline
Austin, TX
Joined Jan 2009
Originally Posted by tymbrewolf
I might give the Drenalyn a go this fall, but miss nice easy to print BW sized plans. ...sic... I I keep watching this thread hoping for some decent printable PDF plans in American measurements that don't require too much thinking. I am rather patient...
how about these?...just knocked them out this AM....not 100% exactly what was drawn on page 7, but its what I built, is very close to Golds plans, and flies well...
oh, and if you have Excel...here is a little scalable spreadsheet with major dimensions that scales to any WS you wish( WARNING this is NOT a TXT file...change file extension to XLS before using...the site won't allow me to uplaod a file with XLS extension)...
