Couple of video frame grabs of David Theunissen's Drenalyn almost 7 years ago - November 2001 (pre brushless and LiPos)!
![]() ![]() David's site: http://www.flyelectric.ukgateway.net...r.htm#drenalyn This was the first indoor model I ever saw hover
Joined Feb 2007
Frank, got a question. Have you tried an undercambered SD with a rudder? Or, would it be of benefit in a delta as opposed to a low aspect form like the drenalyn? Also, does the bent airfoil have better low flight properties than a clark y. It seems that a flat fuse could have a couple of ribs over the flat wing wing taped or glued that would have the strength of a kf with a "real" air foil. Or would any benefit be lost due to the added weight if any at all? I have been thinking again this evening which as always can be dangerous.
I posted a pic in the SD thread of the 'Don't Panic' delta, which has an undercambered wing. The designer claims it eliminates the pitch or tunking problem, which all my SD never had, so why bother with all the extra work.
Now the Drenalyn, that's a different story. The undercambered and reflexed wing with the round LE is it's secret to success, as least that's my impression. The shape of the LE provides dihedral effect, the shape of the wing produces extra lift for slow flight, the reflex keeps it on an even keel and the bend provides strength for the foam saving the weight of bracing, even floppy EPP. Even with the UC airfoil, it flies inverted as well as upright. A clark Y wouldn't work well on a platform that has no tail as it needs reflex. Designing the reflex into the airfoil is more efficient than adding up to the elevons as that only produces more drag. Had three Drenalyn show up at indoor last night and they are by far the best all round performer I've yet to find that uses elevons and/or rudder, kind of like a improved version of the Pizza Box Flyer. |
There's a problem with building from that plan. If you look at the side view or the airfoil, the LE goes down too far and the reflex is excessive. There was one built here from that plan and it needed modification to get it to fly properly. If you draw a straight line and draw the airfoil so no portion of it goes below that line, problem solved. Any fuse or spine that's added, is below that line. Just look at the picture of mine. Also note, that the LE only has to come up in a sweeping fashion (the reflex) about 1/4 to 3/8" on a airfoil with a 18 cord.
The shape of the airfoil doesn't seem to be critical and a free hand TLAR is good enough. |
