Old Sep 07, 2009, 09:49 AM
Azarr is offline
Find More Posts by Azarr
RIP Azarr - "Old age is not for sissies"
Azarr's Avatar
Dayton Intl, Ohio, United States
Joined Jan 2000
Originally Posted by Atx_Heli
how about these?...just knocked them out this AM....not 100% exactly what was drawn on page 7, but its what I built, is very close to Golds plans, and flies well...
oh, and if you have Excel...here is a little scalable spreadsheet with major dimensions that scales to any WS you wish( WARNING this is NOT a TXT file...change file extension to XLS before using...the site won't allow me to uplaod a file with XLS extension)...
Very nice, could you post a 17" version?
Azarr
Azarr is offline Find More Posts by Azarr
Old Sep 07, 2009, 11:06 AM
goldguy is offline
Find More Posts by goldguy
flyin' fool
goldguy's Avatar
Vancouver Island, Canada
Joined Jul 2003
Heli:
Thanks, nice simple updated plans. Maybe this will get the thread boiling. It's great to see some positive input here, as this is an exceptional flyer.
When balance right, the D. will do torque rolls all day long. Using the throttle, you can bring it right down to touch the tail and go back up, come back down, go back up...........even hop across the ground.
And, as you've found, it excels at inverted, you can even put the TX down, sit back in your folding lawn chair and enjoy .
I built one for a FB to use in combat. He flew only big scale stuff, mostly upright. On his first flight he was shooting inverted T n' G and was amazed he could pull it off. So much for a good design.
goldguy is offline Find More Posts by goldguy
Old Sep 07, 2009, 12:00 PM
Atx_Heli is offline
Find More Posts by Atx_Heli
Austin, TX
Joined Jan 2009
Azarr
here tis.....I don't show on these plans the nose extension I've started to use, but if you want to mount your servos rearward, instead of close to the target CG, then just build the nose out a couple of inches...it also helps on prop hanging hovers since the longer the nose moment from the CG, the longer the pendulumn effect (ie slower swings when hanging)...
I build the airframe, then add the servos , RX, and battery, then just cut the nose box back until the motor and esc balance it at 27-30% of length..
Atx_Heli is offline Find More Posts by Atx_Heli
Old Sep 07, 2009, 12:10 PM
Azarr is offline
Azarr's Avatar
Joined Jan 2000
Thanks Atx_Heli
Azarr
Old Sep 07, 2009, 10:20 PM
tymbrewolf is offline
Find More Posts by tymbrewolf
Joined Feb 2007
Well, so much for I don't have a good plan excuse....
Can I be just a little bit picky though. Can you take out the green cross hatching. That is alot of ink to run through a printer according the the better half.
tymbrewolf is offline Find More Posts by tymbrewolf
Old Sep 08, 2009, 12:38 AM
goldguy is offline
flyin' fool
goldguy's Avatar
Joined Jul 2003
There's enough info on this thread that it can be built without a plan. It's just a half circle with a rectangle added and a big lazy 'S' for an airfoil. With all the measurements available you can draw the plan on the foam and save a step, or two.
The airfoil is easy, note the high and low points, then connect with something flexible like a steel ruler, length of CF or a French curve.
No more stallin', get busy................
Old Sep 08, 2009, 04:44 AM
Jimmy JFlyer is offline
Find More Posts by Jimmy JFlyer
For us He died, in me He lives
Jimmy JFlyer's Avatar
United States, MI, Saint Clair Shores
Joined Dec 2008
Tymbrewolf, just hurry up & build it would ya!? I'm anxious to hear your flight report on this guy.
Jimmy JFlyer is offline Find More Posts by Jimmy JFlyer
Old Sep 08, 2009, 06:15 AM
gpw is offline
gpw
Find More Posts by gpw
gpw
“There’s no place like Foam”
gpw's Avatar
United States, LA, New Orleans
Joined Jul 2002
One might want to make the S shaped airfoil no more than 4% thick for best performance... Just FYI
gpw is offline Find More Posts by gpw
Old Sep 08, 2009, 10:08 AM
goldguy is offline
flyin' fool
goldguy's Avatar
Joined Jul 2003
Good advice........4% it is then.
Old Sep 08, 2009, 11:44 AM
gpw is offline
gpw
gpw
gpw's Avatar
Joined Jul 2002
That's actually from GeneBond who has researched all this stuff...
Old Sep 08, 2009, 11:54 AM
High Flyin' is offline
Find More Posts by High Flyin'
Out the Window
High Flyin''s Avatar
United States, FL, Alachua
Joined Jul 2004
Here is a dumb question. Do you mean that the material thickness should not be more than 4%? Or are you talking about the height of the airfoil? Or is it both added together?
A good piece of information....thanks,
Ray
High Flyin' is offline Find More Posts by High Flyin'
Old Sep 08, 2009, 12:00 PM
dekan is offline
Find More Posts by dekan
D'oh.. Dumb Left Thumb
dekan's Avatar
London, UK
Joined Nov 2006
Height of the airfoil... divide the chord (usually the Root chord) by the height of the airfoil "under side" at it's highest point .. IE 16" divided by 100 x 4 = .64"
dekan is offline Find More Posts by dekan
Old Sep 08, 2009, 02:23 PM
goldguy is offline
flyin' fool
goldguy's Avatar
Joined Jul 2003
can you please do up my taxes for me..................
Old Sep 08, 2009, 03:04 PM
dekan is offline
dekan's Avatar
London, UK
Joined Nov 2006
Hmm... I always thought Vancouver Island was a tax haven
Old Sep 08, 2009, 03:51 PM
goldguy is offline
flyin' fool
goldguy's Avatar
Joined Jul 2003
Are you kidding? Our forest fire fighting bill has now reached over 400 million, only 340 million over budget and someone has to pay.
Just shaved 1.75 ounces off my 9.5 ounce Flop and just heading out to see if the diet worked as planned.
