Old May 09, 2007, 01:54 AM
bradb is offline
Find More Posts by bradb
what goes up crash's
bradb's Avatar
Mccrory, Arkansas
Joined Jun 2006
Question
problems with trex 450 after crash
Last week I tried to do a loop with my throttle up switch in normal mode (did not mean to) and it dropped about 60 foot out of the air on to its side. I replaced every thing on it that was broke but the first time I took it out normal mode was fine, idle up 1 was fine, but idle up 2 was not changeing anything its like it was still in idle up 1. I straped the heli down and ran the motor up. I went into idle up 1 changed the throttle curve from 100 70 100 to 100 90 100 and there was no change. it was like the motor would not go over 70% throttle. Also when I fliped the throttle hold switch it would idle down but the rotors was still spinning slightly. I went into the house and reprogramed the esc and now it seems fine but I dont want to fly it untill I get some feedback on this. Can the esc lose its programing in a crash? do you think it just lost the full throttle position? or can it be something other than the esc? I have the align 35a esc
bradb is offline Find More Posts by bradb
Old May 10, 2007, 04:27 AM
bradb is offline
bradb's Avatar
Mccrory, Arkansas
Joined Jun 2006
any comment would be helpfull
Old May 10, 2007, 06:23 AM
jermo is offline
Find More Posts by jermo
Pantera .61 - Yeah Baby!
jermo's Avatar
United States, SC, Fort Mill
Joined Nov 2006
If the heli is powered up with high/max throttle it will go into programming mode. To my knowledge once you get into programming mode you either program it or it goes to defaults (a few reports on the web supports this).
If you powered the copter on in ilde up mode you'd be at full throttle. As part of your preflight always set/reset all switches/knobs/levers before powering up your bird.
jermo is offline Find More Posts by jermo
Old May 10, 2007, 08:50 AM
timphan84 is offline
Find More Posts by timphan84
TEAM SCHC
Joined Jul 2006
what kind of TX do you have? make sure when you set your throttle hold/cut position make sure its below 0%. If its not your rotors will still spin and its not cutting the throttle.
timphan84 is offline Find More Posts by timphan84
Old May 11, 2007, 04:43 AM
bradb is offline
bradb's Avatar
Mccrory, Arkansas
Joined Jun 2006
I have a dx 7 and the throttle hold was set at -6%
Old May 11, 2007, 04:52 AM
bradb is offline
bradb's Avatar
Mccrory, Arkansas
Joined Jun 2006
it was like full throttle on the tx was only 70% on the bird and full down on the tx throttle was -30% on the bird. it seemed that the esc was out of phase or something.
Discussion Revo CP with tail wag after crash dwelch Mini Helis 11 Jan 17, 2007 02:07 PM
Discussion Governor mode with trex 450 larsen2000 Mini Helis 0 Oct 30, 2006 05:02 PM
Video Problem with Trex 450 XL tail belt Ursine Electric Heli Talk 0 Oct 14, 2006 08:32 AM
Radio Problems with Trex TThroop Mini Helis 3 Jul 05, 2005 07:00 AM
anybody else have problems with Etec 450 3's? BrunswickOH Batteries and Chargers 9 Apr 03, 2005 09:10 PM
