Old May 08, 2007, 10:40 PM
hoppy is offline
Find More Posts by hoppy
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
A Goldmine of Motor Test Data from Dr Kiwi
Dr. Kiwi has run many many tests on motors and props. I was trying to think of someway to get a handle on all of it and happened to look under his profile.
By looking at "Threads Started by Dr Kiwi" under his profile, many of these tests pop up.
Impressive amount of work, wouldn't you agree?
What I'd like to do is make a list of all the motors he has tested ranked in order of maximum thrust with a 3s lipo. If I make any headway, I'll post the info.
Thanks Phil
hoppy is offline Find More Posts by hoppy
Old May 09, 2007, 06:23 PM
Stark Flyer is offline
Find More Posts by Stark Flyer
Stark Flyer's Avatar
Canal Fulton, Ohio
Joined Jun 2003
Good idea. I have been trying to list all the prop information, RPM vs. thrust vs. size vs. manufacture. Once I get it completed I will post it.
Dick
Stark Flyer is offline Find More Posts by Stark Flyer
Old May 10, 2007, 08:33 AM
hoppy is offline
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
Dr Kiwi was kind enough to send me the data he has collected in spread sheet format. This data can be sorted by a number of parameters to zero in on the motors that meet your criteria. I think there are close to 5000 entries!
As I said in the heading, this is a goldmine of motor information.
Thanks again Phil,
hoppy
Old May 10, 2007, 09:02 AM
Bajora is online now
Find More Posts by Bajora
AA6JB
Bajora's Avatar
Joined Sep 2004
Hey Sir Hoppy ... any chance you would be able to forward that to me? I'b be interested in having that as a resource? Would you mind Phil?
Bajora is online now Find More Posts by Bajora
Old May 10, 2007, 09:11 AM
Dr Kiwi is offline
Find More Posts by Dr Kiwi
Dr Kiwi's Avatar
Chattanooga, Tennessee, United States
Joined May 2003
Send me your e-mail address in a PM and I'll attach it for you.
Dr Kiwi is offline Find More Posts by Dr Kiwi
Old May 10, 2007, 09:44 AM
AA6JB
Bajora's Avatar
Joined Sep 2004
Cool! Tnx very much Doc! PM on the way!
Old May 10, 2007, 11:29 AM
Dr Kiwi is offline
Dr Kiwi's Avatar
Joined May 2003
It's been sent - just remember that entries with "pusher" in the Notes column are the most recent and IMHO most accurate. Some of the earlier stuff is good for amps/rpm, but thrust numbers will tend to be lower than they should be.
Old May 10, 2007, 06:36 PM
arx_n_sparx is offline
Find More Posts by arx_n_sparx
Dismembered Member...
arx_n_sparx's Avatar
Niagara Falls/Toronto area
Joined Dec 2003
PM sent too!
Thanx Doc
Brad
arx_n_sparx is offline Find More Posts by arx_n_sparx
Old May 16, 2007, 01:21 PM
Canal Fulton, Ohio
Joined Jun 2003
I went to GoBrushless and used their calculator to obtain prop information and put it in a spreadsheet. The data for the calculator was provided by MorrisM and Dr. Kiwi. Many thnaks for the effort it took to create the data!!!
Next step is to post it here but spreadsheet files (.xls) are invailid for posting. I will have to see what is the best way to convert the data to a vaild file I can post. Any ideas appreciated.
Dick
Old Jun 03, 2007, 04:33 PM
Canal Fulton, Ohio
Joined Jun 2003
Prop Data
I have attached a Word document that has prop information. This data is not mine but came from others, Dr. Kiwi, Morris and GoBrushless (http://www.gobrushless.com/testing/t...Calculate+Now).
Many thanks for making this data available!!!
I hope this helps others when selecting props.
Dick
Question Neu's motor test data aragon NeuMotors 3 Jan 20, 2007 05:35 AM
Download Motor Specs from Phil AKA Dr Kiwi bidlynd Australia 2 Sep 08, 2006 09:18 AM
Discussion BM2908 1100kv motor test data and question RMS Power Systems 30 Jul 30, 2006 10:20 AM
Motor Test Data and Constants Gene Bond Power Systems 36 Apr 21, 2003 09:18 PM
It's not as good as DNA's but here is some motor test data on qc830's Spaulding Parkflyers 5 Feb 04, 2002 03:39 PM
