Old Oct 24, 2002, 09:24 PM
Bonafidepirate is online now
Find More Posts by Bonafidepirate
define("BEASTMODE", "1");
Bonafidepirate's Avatar
United States, LA, Moreauville
Joined Jan 2002
Servo setup for Mini Mega Pencam???
Hi, I was just at a local Wal-Mart, that had one Aiptek Mini Mega Pencam left, on sale for $59.83, so I bought it. Boy, this should be an improvement from the Pencam Trio I was using!
I'd like to see some methods of putting a servo on it to work preferably both buttons, but maybe just the shutter.
Thanks in advance.
Keith
Bonafidepirate is online now Find More Posts by Bonafidepirate
Old Oct 24, 2002, 09:40 PM
Flying Taco is offline
Find More Posts by Flying Taco
Flying Taco's Avatar
NRH, TX
Joined Jan 2002
I don't have a picture but I removed the lanyard mount thingie from the top of the camera and mounted a servo with a V configured horn cut down to hit the shutter button in one direction, and the mode button the other. I stopped using this method cause it gets confusing when changing modes in flight. I now use the ball bearing set up Boomer came up with which presses the shutter only. I just power up before launch and go. I rarely shoot video cause it doesn't come out that great anyway.
Flying Taco is offline Find More Posts by Flying Taco
Old Oct 24, 2002, 09:43 PM
William A is offline
Find More Posts by William A
Tacoma, WA, USA
William A's Avatar
United States, WA, Tacoma
Joined Jun 2001
Try here.
http://www.rcgroups.com/forums/searc...topic=ezone&s=
William A is offline Find More Posts by William A
Old Oct 24, 2002, 11:41 PM
rpm3 is offline
Find More Posts by rpm3
rpm3's Avatar
Pleasanton, California
Joined Nov 2000
Try this
http://www.rcgroups.com/forums/showt...k&pagenumber=2
There are other setups..the one under my name (with 3 photos) is the one I use..there are other very clever setups....mine suits me fine!
rpm3 is offline Find More Posts by rpm3
Old Oct 25, 2002, 10:02 PM
Atom_Bomb is offline
Find More Posts by Atom_Bomb
Atom_Bomb's Avatar
Charlotte, MI , USA
Joined Oct 2002
Ill have to try those ones out too cause i was trying to think of a good setup for my pencam
Atom_Bomb is offline Find More Posts by Atom_Bomb
Old Oct 26, 2002, 07:35 AM
Capt. Electron is offline
Find More Posts by Capt. Electron
Senior Moment Member
Virginia Beach, Va.
Joined Jan 2002
This is probably a different model Aiptec than yours, but may give you some ideas.
I wanted something that would provide control without any mods to the camera. And rubber-banding a servo to it and fiddling with adjustment each time was a real pain. With this set-up you just slide the camera in or out. The foam box adds a little impact protection as well, you know, just in case.
http://www.rcgroups.com/forums/showt...%2Foff+shutter
Jimmy
Capt. Electron is offline Find More Posts by Capt. Electron
Old Oct 26, 2002, 12:04 PM
Sparky Paul is offline
Find More Posts by Sparky Paul
Ascended Master
Sparky Paul's Avatar
Palmdale, CA
Joined Oct 2000
This is my current setup:
I use the rudder channel. Full left rudder (with rudder trim set full left) pushes on the Mode switch to turn the camera on, just before launch.
Then the rudder trim is pushed full right, to lessen the odds of an inadvertant mode change in flight.
The shutter is tripped by full right.
Sparky Paul is offline Find More Posts by Sparky Paul
Old Oct 26, 2002, 12:31 PM
Virginia Beach, Va.
Joined Jan 2002
Sparky,
I see you opted for the "easy to find in tall weeds" color. Good choice.
Jimmy
Question brushles power setup for mini xe and xe2 planecrazy2 Power Systems 1 Dec 02, 2003 09:42 AM
Motor setup for a Mini graphite Heli Slime Electric Sailplanes 9 Aug 08, 2003 06:57 AM
What's the actual diference between mini and mega pencam? Ben C Aerial Photography 10 Nov 30, 2002 04:49 PM
4 or 6 servo setup for DLG leverick Electric Sailplanes 2 Mar 25, 2002 01:01 PM
CNC setup for mini mill from harbor freight stealthy Life, The Universe, and Politics 0 Jan 21, 2002 02:32 AM
