Old May 25, 2007, 09:49 PM
resU deretsigeR
PaulVi's Avatar
Dublin Ca
Joined Aug 2004
I use hot glue to join the halves I would not use epoxy because it is brittle
PU works too but you will have to keep wiping the foam off the center..
Hot glue is a nice mix and does not seperate from the foam. I use a full heat gun but squezze a bit out and spred it on if it cools to much u use a mini torch to sofen it just before pressing together
PaulVi is offline Find More Posts by PaulVi
Old May 25, 2007, 11:02 PM
mrj
Joined May 2007
Uh oh.Next is carbon strips then elevon's.THe last will be motor choice.12mm Feiagio or 5300 himax? Pics below(hopefully)
mrj is offline Find More Posts by mrj
Old May 26, 2007, 01:34 AM
mrj
Joined May 2007
Glued in the carbon spars. Cut elevon's,and hinged.
CK-What do you recommend for elevon width,and control surface throw.I cut my elevons 1.5"
After setting the feiagio ontop of the fuselage, something doesnt feel right. It keeps screaming more power!
Old May 26, 2007, 01:16 PM
mrj
Joined May 2007
REady to go. AUW with a 3cell 1320 pro lite lipo 9oz.with the polyrc 2 cell 1500 8.7oz. I used 3 pieces of 1.4mmx4.5mm carbon strip.Gonna try it with the feigiao then the himax.Gone flyin.
Old May 26, 2007, 01:26 PM
Mum is the word!
Joined Jun 2003
Looks good Jason,If you find the elevator effect and rolls are slow you will have to extend the elevons a bit.See the elevons on the skyvak they extend back farther where the stabs straitn and compress the airflow.Ifit rolls slow then the tips should be wider too.
Ck
klique is offline Find More Posts by klique
Old May 26, 2007, 01:57 PM
mrj
Joined May 2007
I just measured and i end up with .700"-.800" for deflection.More than this? I cant clearly see the elevon's on the Skyvac.Thanx for the help
Old May 26, 2007, 06:20 PM
swoof's Avatar
Upland, CA
Joined Mar 2007
mrj, how about some bigger pics? I picked up one of these at MWE also. Trying to figure out where to mount the motor. I want to get a couple more, and a 25" also. I was thinking about trying a ducted fan on one also. So far I have the wings gooped on. Now I need to go pick up some TE stock. I'm also trying to figure out where to put the spars.
swoof is offline Find More Posts by swoof
Old May 26, 2007, 07:40 PM
mrj
Joined May 2007
Old May 26, 2007, 07:47 PM
mrj
Joined May 2007
Swoof-
Decided to go sloping in the morning,so i took the motor off.I ran a piece of carbon fiber front to back in the center of the fuselage,i then marked center on the top of the fuse in between the vertical stabilizers.I drilled 4 holes through the fuselage and zip tied through the Epp and around the carbon spar.Last i used shoe goo to reinforce the Epp and the carbon where the motor sits.Trying to keep my build lite, as was suggested. BElow i added pics of how i mounted my 12mm brushless(with zip ties) and how i will mount my 20mm brushless.
Old May 26, 2007, 10:58 PM
Mum is the word!
Joined Jun 2003
MJR did you get a chance to fly it powered yet?
I flew mine on the slope quite a bit today in 25 mph wind it was a bit much for it weighn at 8 oz or so.
It flew pretty good on the slope but i think it will really shine w a razor motor or a himax 20 mm 4000 kv on 3s or somthin close to that.I will set mine up next week like that.
ck
Old May 27, 2007, 12:33 AM
mrj
Joined May 2007
CK-ya i flew with the feiagio it flew nice but i had it a little nose heavy in gusty wind. Those cheap gws 3x3 props break when you glance at them,every time i'd land i'd break a prop.I've got my 4100 himax ready to go after tommorrow. What would you guess the powered version auw be? I'am right around 13oz with a 3cell1320 lipo or 2 1500 2cell and the 20mm motor.I dont have a wide enough selection of battery sizes to help with balancing the himax.I dont want to add weight i'd rather add battery.
Old May 27, 2007, 01:08 AM
swoof's Avatar
Upland, CA
Joined Mar 2007
MRJ thanks for the pictures. That helps a lot. I have a 2025-4200 would that work for a 20mm on 3s? If so what size prop?
Old May 27, 2007, 01:50 AM
mrj
Joined May 2007
2015 is the 20mm motor size, which is equal to 370 brushless. 2025 is 25mm? and is equal to 400 size brushless. My 370 size weighs 1.5oz.The 400 size may make it real hard to balance,but thats just my opinion it may be fine?
Old May 27, 2007, 02:11 AM
swoof's Avatar
Upland, CA
Joined Mar 2007
I'm still new to the whole brushless thing. I was planning to go with the Medusa Afterburner 12mm 5300 because that's what Chris recommended for a 2s which is what most of my LiPo's are. But I can't find anyone that has them in stock, not even Medusa. I guess if I'm going to run a 12mm I'll either have to go with a Medusa 4000 on 3s or get a Feigao 12mm. I understand the 2015 beig easier to balance, maybe I just need a bigger battery. *evil laugh*
Old May 29, 2007, 09:41 PM
Purples a fruit
punkrockd's Avatar
Walnut Creek
Joined Aug 2006
got my fs and spanker today. love the fs. the other looks alot like my 26 minid core i got.
anyway not totally decided with the power, but i'm leaning toward the 110 arc motor and 2 910 3s parallel. should scoot. i've got a 20mm heat sink mount that mounts using a stick. and then i have a custom cdr hot wind that is a lot lighter. and a lspj.
punkrockd is offline Find More Posts by punkrockd
Build Log Ritewing Mini-Demon build (22" mini-wing) chuckand Flying Wings 85 Sep 08, 2009 01:10 AM
Sold Ritewing Mini-Demon Kit (NIB) Tank52 Aircraft - Electric - Airplanes (FS/W) 6 Oct 28, 2006 01:30 PM
Discussion RiteWing Mini Demon Project - Quest for Ballistic / Clean Handling Mini Wing! Dynomike Flying Wings 12 Jun 04, 2006 05:34 PM
Mini Demon, Any one use it yet? GoodTill Power Systems 0 Feb 02, 2003 08:37 PM
Mini Demon Dual 450 Turbo Greg Covey Power Systems 4 Nov 24, 2002 12:21 PM
