This thread is privately moderated by RAY GWS, who may elect to delete unwanted replies.
Old Dec 20, 2012, 10:27 PM
Pdr1966 is offline
Find More Posts by Pdr1966
Canada, ON, Toronto
Joined Oct 2012
EPO F15 starting new assemlby
I have an EPO No Power System kit which I am just starting assembly.
Looking for suggestions for mods to consider. Not after super performance, but looking at adding carbon before gluing top to bottom.
Planning on no gear, maybe add carbon rails in the bottom as skids for landing?
Deciding where to mount ESC's in fuse side with heatsink in the air duct? or use one larger amp ESC, instead of two 35a's.
Also, considering, trying to find space for a stabilizer.
Should I go regular elevator or full flying elevator?
I am intermediate flown FMS 64mm F15 ok but for straining through a tree top, and this ones predecessor, again - tree magnet......
Pete
Pdr1966 is offline Find More Posts by Pdr1966
Old Dec 21, 2012, 04:40 AM
jamesdr is offline
Find More Posts by jamesdr
Unrepentant Carnivore
jamesdr's Avatar
Brandon, Fl
Joined Mar 2005
Building mine - number 3. I'm using the Aero 64mm edf setup from HeadsUpRC. Solid fans. I will be mounting my ESCs in the duct, the fuse doesn't have enough air flow. Doing a single ESC is possible but you would have to use something around 100 amp ESC. You have to use 2x plus 15%. I recommend using the full flying stab and that requires using GWS park servos. The splines on the stab clips are made for those servos, every other option will fail. CF reinforcement isn't necessary unless you break something. The model is not really fast, the wing is thick and draggy. But it looks great and flies better.
Jim
jamesdr is offline Find More Posts by jamesdr
Old Dec 21, 2012, 11:44 AM
denial15 is offline
Find More Posts by denial15
swede
denial15's Avatar
United States, UT, Vineyard
Joined Aug 2005
Jim, are you gluing your wings on, or keeping them removable? If you're gluing them on, I could really use the wing clips. My GWS15 has been grounded for months.
2nd on the GWS Park servos and full flying stab. If you plan on belly landing in long(ish) grass, I would reverse the sides on the elevators, or at least the clips if you haven't glued them on yet. It elevates them a little higher than "scale", but it keeps them from digging in on the grass.
denial15 is offline Find More Posts by denial15
Old Dec 21, 2012, 03:31 PM
Pdr1966 is offline
Canada, ON, Toronto
Joined Oct 2012
Grass
As I plan mostly grass landings, I may opt for fixed stabs as they may be more durable.
Also, I may "pin" the rudders on so I can avoid the ugly brackets in th kit.
Wing clips, if I decide to glue, I may make the clips available.
Pete
Old Dec 21, 2012, 04:02 PM
denial15 is offline
swede
denial15's Avatar
Joined Aug 2005
With the full flying elevators elevated, they haven't ever caught the grass. Mine is only full flying tail, but I've heard of those that have some conventional ailerons/elevators that the full flying tail is more responsive.
Old Dec 22, 2012, 01:55 PM
Pdr1966 is offline
Canada, ON, Toronto
Joined Oct 2012
Maybe sell
Before I really get started, would anyone here like to buy this kit?
I have $130 into it including shipping.
It is no power system, white, EPO foam bought from filephidels shop in NY.
Located now in Toronto Canada.
Can include two motors and esc s $ negotiable
Just thought I'd post the idea as I have lots of lanes now and one good f18 edf.
Wouldn't mind a fly zone beaver, or eflight stearman over this.
Pete
Old Dec 22, 2012, 08:32 PM
jamesdr is offline
jamesdr's Avatar
Brandon, Fl
Joined Mar 2005
Swede
Sorry, I need to have the wings removable. Have you thought of using neodymium magnets to attach the wing? Two per may do the trick.
Jim
Old Mar 24, 2013, 01:43 PM
jamesdr is offline
jamesdr's Avatar
Brandon, Fl
Joined Mar 2005
Retracts
This has been a slow boat build. I've putzed and played, tried different combinations, and a lot of mock-up and finally got to to the point of having working retracts on the F-15. Still need to tidy up my dremmeling (that is why the right gear got stuck). The rest of the build should be quick(er).
F-15 retracts (0 min 37 sec)
Jim
Old Mar 24, 2013, 02:40 PM
denial15 is offline
swede
denial15's Avatar
Joined Aug 2005
Pretty fancy.
Old Mar 26, 2013, 08:56 PM
jamesdr is offline
jamesdr's Avatar
Brandon, Fl
Joined Mar 2005
More done
Fuse is sealed up, all the electronics in and working. Need to clean-up, sand, paint, and balance. Wish I could have gotten the nose wheel further into the fuse but there are limitations with this size model and foam.
GWS F-15 (0 min 34 sec)
Jim
Old Mar 26, 2013, 10:24 PM
denial15 is offline
swede
denial15's Avatar
Joined Aug 2005
If you ever plan on belly landing in the grass, you may want to reverse the elevator's. Obviously since you're putting this much effort into gear, it will likely be rare, but just in case.
With the stock configuration the tips of the elevators dipped below the rest of the plane. When I would flare for landings, they would always catch the grass and break the tips off or strip a servo.
Someone on here (might have even been you for all I can remember) recommended switching sides. It lifts them up a little bit, but it fixed the problem.
Even with gear, this plane still hand launches just fine for those places with grass, but no runway.
Old Mar 27, 2013, 04:33 AM
jamesdr is offline
jamesdr's Avatar
Brandon, Fl
Joined Mar 2005
Fortunately my fields are both prepared, one petro mat and the other asphalt. Will keep your concern in mind anyway.
Hope to paint this weekend.
Jim
Old Mar 31, 2013, 03:48 PM
jamesdr is offline
jamesdr's Avatar
Brandon, Fl
Joined Mar 2005
All prettied up
Painted and decaled. Did a taxi test yesterday sans paint. Tracked well. Maiden next weekend.
Jim
Old Apr 02, 2013, 09:57 PM
RAY GWS is offline
Find More Posts by RAY GWS
Joined Jul 2004
Jim,
You always have something fancy&nice to see. I added a link to the video and your photos to the #1 thread. Hope you do not mind. Ray
RAY GWS is offline Find More Posts by RAY GWS
Old Apr 02, 2013, 10:12 PM
denial15 is offline
swede
denial15's Avatar
Joined Aug 2005
RAY!!!! You still exist.
Is GWS going to come out with anything else, or have they given up?
Discussion GWS F-15......The Eagle has landed!!!! skyhawk Foamy EDFs 1298 Jul 21, 2016 02:25 PM
Discussion gws 15 Eagle bob2005 Product Announcements 0 Aug 03, 2007 07:37 PM
Video Gws F-15...DON'T BUY IT tailslide5_0 Electric Plane Talk 47 Jun 24, 2007 10:18 PM
New Product ****GWS-15: The Eagle Strikes Again**** RAY GWS Product Announcements 7 Jun 24, 2007 06:31 AM
eflightpower.com strikes again tic Vendor Talk 6 Apr 29, 2002 08:17 PM
