This thread is privately moderated by RAY GWS, who may elect to delete unwanted replies.
Old Dec 13, 2010, 02:37 PM
Dark Angel is offline
Find More Posts by Dark Angel
skunkworks
Dark Angel's Avatar
United States, CA, Clovis
Joined Apr 2008
I took mine out this last weekend also got a flight on Friday. This thing flies nice and seemed a little faster than I had remembered,LOL. I guess I should start showing it a little more love. Maybe start taking it out a little more.
Dark Angel is offline Find More Posts by Dark Angel
Old Dec 14, 2010, 08:32 AM
rdeis is offline
Find More Posts by rdeis
AMA 353531
rdeis's Avatar
United States, CO, Colorado Springs
Joined Aug 2003
Originally Posted by Headspin View Post
I got a "Blue Lipo" 2650 30c as I thought it would be about right.. the thing is HUGE!!! too big to fit in anyways around.
Intersting- I've got a 3s nanotech 2650 that fits just right.
I also have 2 x BQY 2000 25c - now then.. these both fit in so can I parallel them to give me 11.1.v 4000mah ?
If they're 3s, yes.
rdeis is offline Find More Posts by rdeis
Old Dec 14, 2010, 08:47 AM
denial15 is offline
Find More Posts by denial15
swede
denial15's Avatar
United States, UT, Vineyard
Joined Aug 2005
I have Turnigy 3S3300's that fit perfectly.
denial15 is offline Find More Posts by denial15
Old Dec 14, 2010, 10:25 AM
Headspin is offline
Find More Posts by Headspin
It wasn't my fault!!
Headspin's Avatar
USA, MI, Midland
OK.. word of warning to anyone then.. the "Blue" lippo's are HUGE.. lol
Actually I can "just" slide it in now.. I had to pull the wires forward and then shrink the wrapper some more to keep them at that angle. It's in.. but it's a squeeze.
@ denial15 - How long do you get with that? I'm waiting for my order from HK - I wish I had tacked one of those on.. at 21.06 how are you finding it??
AND.. what is that connecter called.. I need an adapter for my charger..
Tx..
Headspin is offline Find More Posts by Headspin
Old Dec 14, 2010, 11:34 AM
denial15 is offline
swede
denial15's Avatar
Joined Aug 2005
I like that battery quite a bit. I have the Park 400 4200kv motors in mine. Depending on throttle usage, I can get anywhere from 3.5-5 minutes. This glides forever, so If I'm flying relaxed I can milk it for quite a while. Full throttle usually puts about 80-85% (2,600+mAh) back into the pack after 4 min.
I probably have 10-15 flights on each pack (I have two), and they seem to be holding up well.
The connectors are the XT60's. I ordered some of the male connectors and made some adapters for the planes that still have the deans.
Old Dec 14, 2010, 09:20 PM
Headspin is offline
Headspin's Avatar
USA, MI, Midland
The picture showed a red connector.. Not sure if its called a banana connector?
Seems a few batteries are coming with them these days
Old Dec 14, 2010, 09:52 PM
denial15 is offline
swede
denial15's Avatar
Joined Aug 2005
Oh, yeah.....oops. I don't use those. I still had some deans style connectors when I got those batteries, so I took off a couple inches of that heavy wire and added a deans.
I'll probably use the XT60's on all my normal stuff from here on out. If I get some serious hankering, I'll switch everything over. But with 18-19 planes with deans on the esc's, that's got to be some serious hankering.
EDIT:
Those red ones are HXT 4mm bullet connectors.
Old Dec 15, 2010, 07:09 AM
jamesdr is offline
Find More Posts by jamesdr
Unrepentant Carnivore
jamesdr's Avatar
Brandon, Fl
Joined Mar 2005
Last spring, I decided I was tired of Deans and the knock-off so I too the XT60 plunge. Spent a few hours transferring every thing to XT60s and haven't looked back. Did have one casualty, miss soldered one ESC and when I connected the battery, the magic smoke got out. One think I really like about the XT60 is that I don't get any arking ever.
Jim
jamesdr is offline Find More Posts by jamesdr
Old Dec 16, 2010, 08:32 PM
cyclops2 is offline
Find More Posts by cyclops2
United States, NJ, Frenchtown
Joined Mar 2003
Is there a built in resistor pin or contact ?
Or is the arc just out of site ?
cyclops2 is offline Find More Posts by cyclops2
Old Dec 16, 2010, 09:22 PM
jamesdr is offline
jamesdr's Avatar
Brandon, Fl
Joined Mar 2005
The arc seems to happen with higher voltage packs. As you get closer to connecting, there is a "zap." Anyone else?
Jim
Old Dec 16, 2010, 09:47 PM
cyclops2 is offline
Joined Mar 2003
The second F-15 just arrived.
The first F-15 was converted to a pusher.
Would like to up the top speed & duration with a gearbox.
Does the combo below look about right ?
4 1100 mahr B & D LIFEPO4 cells...Have to use them.
Plane is 17 oz. cells are 6.7 oz...24 oz RTF.
4 minutes...31 oz. static thrust...63 mph on the ground...186 watts input. 160 watts output...full flying elevators... no rudders.
Old Dec 18, 2010, 06:27 PM
Headspin is offline
Headspin's Avatar
USA, MI, Midland
Well.. I'm slower than a pickle, but I'm getting there. Lots of soldering done, plenty harnesses to make yet. and you can see how big the Blue Lipo is..
GWS F-15 With retracts. Work in progress (0 min 14 sec)
Old Dec 18, 2010, 06:43 PM
cyclops2 is offline
Joined Mar 2003
Looks like Edwards Air Force Base, maintainance shop.
Way to go.
I am doing a more powerfull version of this driveshaft, pusher. It allows the COG to be perfect by maving the motor, ESC & battery anywhere it needs to be. Cut the driveshaft to length when the COG is right.
Those tiny BB in wood blocks take 30,000 rpms.
Rich
Old Dec 24, 2010, 10:15 PM
Headspin is offline
Headspin's Avatar
USA, MI, Midland
Mixed in the elevons.. still need to work on the throws..
GWS F-15 Elevons mixed (0 min 11 sec)
Nosewheel is all set.. Have to secure and maybe do a bit more digging for the mains though.. Although I think I'm very close to the limit?
GWS F-15 Stearable retracts (0 min 22 sec)
Here is a throw together. Everything is functional.. just a LOT of tuning to do yet...
Old Dec 25, 2010, 04:38 AM
jamesdr is offline
jamesdr's Avatar
Brandon, Fl
Joined Mar 2005
Headspin
Looking good! The throws on the elevons are HUGE - almost comical looking. Folks wonder if the park servos will handle such throws - they do and don't get loose and wobbly. I'm at work now - will measure the throws (in feet <grin>) when I get home if you need the measurements.
Merry Christmas all!
Jim
Discussion GWS F-15......The Eagle has landed!!!! skyhawk Foamy EDFs 1276 Today 03:50 AM
Discussion gws 15 Eagle bob2005 Product Announcements 0 Aug 03, 2007 07:37 PM
Video Gws F-15...DON'T BUY IT tailslide5_0 Electric Plane Talk 47 Jun 24, 2007 10:18 PM
New Product ****GWS-15: The Eagle Strikes Again**** RAY GWS Product Announcements 7 Jun 24, 2007 06:31 AM
eflightpower.com strikes again tic Vendor Talk 6 Apr 29, 2002 08:17 PM
