Old May 07, 2007, 02:39 PM
kleaners is offline
Find More Posts by kleaners
Joined Feb 2006
Why can't I maintain a steady altitude hover 5#6
My 5#6 hovers well laterally but no matter how I try, the heli seems to always be going up or down. I cant get it to maintain a steady hoh in altitude. Anyone have better luck? Suggestions?
kleaners is offline Find More Posts by kleaners
Old May 07, 2007, 02:41 PM
TachyonDriver is offline
Find More Posts by TachyonDriver
21st Century Space Cowboy
TachyonDriver's Avatar
Chipping, Lancs, UK
Joined Oct 2006
Remove the ratchet on the throttle, or at least put some fuel tubing over it to remove the clicks.
Tach.
TachyonDriver is offline Find More Posts by TachyonDriver
Old May 07, 2007, 02:43 PM
kleaners is offline
Joined Feb 2006
There is no ratchet on the 5#6. It smoothly slides. I just cannot find a neutral position.
Old May 07, 2007, 03:07 PM
Chipping, Lancs, UK
Joined Oct 2006
Ah... erm..oh well... sorry!
All I can suggest now is that when you've got a feel for the heli's rising and falling you try and anticipate that on the throttle. Yes, you'll constantly have to fly the throttle...
Tach.
Old May 07, 2007, 03:20 PM View Post
"The Dwarf"
A moderator felt this post violated the following rule: Trolling (Obnoxious behavior). It is temporarily hidden while "The Dwarf" edits it. Show it to me anyway.
Old May 07, 2007, 03:28 PM
Doubletap is offline
Find More Posts by Doubletap
Si Vis Pacem Para Bellum!
Doubletap's Avatar
United States, CA, El Segundo
Joined Jul 2005
I find that simply removing the spring steel ratchet on my throttle stick leaves the stick with almost no tension and feedback making it harder to precisely modulate throttle, so I put a piece of shrink wrap tubing over the steel clip which eliminates the ratcheting feel but also provides some drag on the throttle lever. Fuel tubing probably works good too.
Doubletap
Doubletap is offline Find More Posts by Doubletap
Old May 07, 2007, 03:56 PM
Butters is offline
Find More Posts by Butters
Butters's Avatar
Your Mama's house!
Joined Mar 2005
Hay Doubletap, that's a cool idea. Next time you are in your handle can ya post a pic, just so I can be sure?
James
Butters is offline Find More Posts by Butters
Old May 07, 2007, 04:38 PM
Septimus is offline
Find More Posts by Septimus
Joined May 2007
The throttle trim should prove helpful in finding the neutral position. Say if it goes up a wee bit, you just take the throttle trim down a bit!
Septimus is offline Find More Posts by Septimus
Old May 07, 2007, 07:56 PM
Butch777 is offline
Find More Posts by Butch777
Livermore, CA
Joined Sep 2004
All 3 of my 5#6's are the same way. Either going up or down. The throttle doesn't have enough steps in it around the hover rpm. There is no throttle trim!
Its just a useless decoration.
I thought about adding some weight, but I think it would just push the motors to much. Maybe I'll try to lighten it.
I picked up a 5#5b and it does the same thing!
It has a throttle trim, but it doesn't have any smaller steps, so its just like the stick, too much up or down.
It would be nice to be able to use a good Tx and rx on these little helis. Butch
Butch777 is offline Find More Posts by Butch777
Old May 07, 2007, 08:07 PM
Doubletap's Avatar
Joined Jul 2005
I think it has to do with the cheap integrated speed controllers in these RTF's. I can get my 5#6 and 5#5B to maintain altitude fairly well buy my Esky Lama V3 is a different story. There seems to be a step right where it hovers which makes it almost impossible to HOH.
Doubletap
Old May 07, 2007, 08:25 PM
crashdumby is offline
Find More Posts by crashdumby
TREE TOP PILOT
crashdumby's Avatar
United States, IN, Greenfield
Joined Feb 2007
I removed throttle spring entirely..Can hover at any level needed.There are no steps in my esc.I think a prisey tx would be an overkill for a heli of this caliber.Main thing is if your having fun thats all that counts
crashdumby is offline Find More Posts by crashdumby
Old May 07, 2007, 08:37 PM
TREE TOP PILOT
crashdumby's Avatar
Joined Feb 2007
HEY Doubletap
On your sabure heli did you trim down your main rotor blades to 15" ? whats the best way to do that? Do you like them that way?.You can pm me if you like.I think i would like to try that on my falcon 40...Randy.
Old May 07, 2007, 08:46 PM
Lou is offline
Lou
Find More Posts by Lou
Lou
Ground Penetration Tester
United States, VA, Waynesboro
Joined Dec 2005
Doubletap
That or the blades are flexing too much and the heli is losing lift. Are the blades on this heli rather thin or thick? I am not familiar with this heli, is it possible to use the Xtreme blades? They are much thicker and provide better lift.
Lou is offline Find More Posts by Lou
Doubletap's Avatar
Joined Jul 2005
Sorry, OT here: I left my Sabre full size; only my GWS Dragonfly is mothed, mains cut down to 15". There's a link to an article on how to do this; do a search in the micro forum to find it. I like my Dragonmoth alot more than my Sabre because it's far more responsive and I can fly it in a much smaller space. Removed the flybar weights from both of them which made a big difference. I'm hovering full packs now indoors in a 9' x 10' space! Full size Sabre takes alot more effort though.
Doubletap
Old May 07, 2007, 08:47 PM
Doubletap's Avatar
Joined Jul 2005
I have the Xtreme blades on my V3 yet it still is very difficult to maintain constant altitude.
Doubletap
Why Can't I Swap Crystals Between Two JR Radio Systems? RazorB Power Systems 6 Mar 09, 2008 04:28 PM
Trex doesn't maintain steady altitude at hover Orion_V Mini Helis 28 Aug 21, 2005 06:34 AM
Why can't I set a custom LVC of 5.x volts ? OzzieFlyer Castle Creations 8 Jul 14, 2004 04:25 PM
Why can't I hover ? OzzieFlyer 3D Flying 9 Mar 28, 2004 04:29 PM
Why can't I pull Directories & Data off my Burned CD-R's? mrebman Life, The Universe, and Politics 4 Oct 04, 2001 11:17 PM
