Old Oct 24, 2002, 04:23 PM
Appie is offline
Find More Posts by Appie
Appie's Avatar
The Netherlands, DR, Emmen
Joined Aug 2002
Pibros Twinn EDF-50 "My first EDF project"
A few day ago i received (from Aircraft world, Thanks David!) my first EDF-50's And yes when running them the first time the fans came loose. One should wear a safety helmet handling these 'babies'....... But after three nights of crafting i finished my first EDF project
An Pibros delta with two EDF-50 on his back.
Some details:
- Width 600mm (23.62 inch)
- Weight 289gr (8.67 oz)
The BIG question however is, Will this thing fly
I posted some photo's, here they come
Appie is offline Find More Posts by Appie
Old Oct 24, 2002, 04:26 PM
Appie is offline
Appie's Avatar
Joined Aug 2002
some more
Some more
Old Oct 24, 2002, 04:27 PM
Appie is offline
Appie's Avatar
Joined Aug 2002
Number three
Yes another one
Old Oct 24, 2002, 04:29 PM
Appie is offline
Appie's Avatar
Joined Aug 2002
At last..........
The last one
Old Oct 24, 2002, 04:34 PM
thulizulu is offline
Find More Posts by thulizulu
Bzulu
thulizulu's Avatar
Canada, NT, Yellowknife
Joined May 2002
Hello Appie,
it seems to be airworthy .
There are some cooling devices attached to the motor, are they custom made? Any information would be appreciated.
thulizulu is offline Find More Posts by thulizulu
Old Oct 24, 2002, 04:38 PM
Appie is offline
Appie's Avatar
Joined Aug 2002
Cooling Devices
No they are standard items, they come with the impellers. They Look like the things they use for cooling transistors etc
Old Oct 24, 2002, 04:43 PM
Bzulu
thulizulu's Avatar
Joined May 2002
I see, would´ve been nice to get that stuff for other motors.
Old Oct 24, 2002, 04:50 PM
Vipula AD is offline
Find More Posts by Vipula AD
Vipula AD's Avatar
Greensboro/H.Pt/Win-Salem P.T. Intl, North Carolina, United States
Joined Dec 2001
Nice job Appie,
From the information you have given, it looks like you have just about a 1sq.ft of wing area, so about 9oz/sq.ft. of wing loading.
I'dd say it will fly, but not knowing what type and number of cells you are using, cant say about how much thrust you are going to get from that setup.
On a 7X720 NiMH pack, I have been able to get a little above 3 ozs of thrust with one EDF-50, but when I put two EDF-50s to the same battery pack I dont get 6+ ozs of thrust, its more like 5+.
What I am trying to say is, keep the flying fast and level and it should do fine. Avoid high angle of attack flying. Keep the momentum.
Please tell us about the flights, and do fly it, if you dont you'll never know.
Vipula.
Vipula AD is offline Find More Posts by Vipula AD
Old Oct 24, 2002, 05:14 PM
Appie is offline
Appie's Avatar
Joined Aug 2002
Thrust
Hi Vipula,
I measured 31000 Rpm on each impeller how much thrust that will give
At the moment (shown in the picture) there is an LI-IOn pack (7.2V/1200mah) but i'm a bit concerned if they can provide the amps i need.
Maybe its better to change to Nicad's instead, but wich ones (the 500AR's are too heavy!)
I will keep you guys informed about the flying. The @#$% thing is however that the weather-forecast for this weekend is really BAD so i have to wait another week or so
Old Oct 24, 2002, 05:43 PM
DBCherry is offline
Find More Posts by DBCherry
Worcester, MA.
Joined Nov 2001
Thuli,
Those cooling devices are "heat sinks" and are available from many places (Hobby Lobby, Todd's, Aeromicro I think). They are made specifically for the small GWS motors and need to be applied with heat sink paste to be most effective. This paste can be found at most electronics shops.
Dennis-
DBCherry is offline Find More Posts by DBCherry
Old Oct 24, 2002, 05:53 PM
Gary Warner is offline
Find More Posts by Gary Warner
York Electronics
Gary Warner's Avatar
Dallas Tx USA
Joined Apr 1999
Looks Great! I'll be interested in a flight report.
BTW, One thing I noticed is that there is no inlet rings. They can add 20-30% more thrust w/o additional amps. I made one out of blue foam and it weighs next to nothing. Well worth the extra effort for the improved thrust. Mine took all of 10 minutes to make.
Gary Warner is offline Find More Posts by Gary Warner
isaac-bees is offline
Find More Posts by isaac-bees
isaac-bees's Avatar
Newport, WA US
Joined Aug 2000
When I ran my two fans on Li-Ions (qualcom I believe about 830 mAh) the battery really started warming up. That was after a 30 sec run too. I am going to try 700 mAh AAA NmHd
isaac-bees is offline Find More Posts by isaac-bees
Old Oct 25, 2002, 06:25 AM
Vipula AD's Avatar
Joined Dec 2001
Appie,
I would go with the 700 or 720 NiMH pack, 7 cells. I have not come accross a Li-Ion cell that can safely handle more than 4 amps. I hear the Li-Poly cells can do a lot better.
31000 is about 2.5ozs of thrust, if bothe were spinning at the same rpm when connected to the one cell then you would get about 5. On 7X720s one would spin at 39000, when you put two together the rpm dropps, because at the current draw the oltage to the fans also dropps.
Vipula.
Old Oct 25, 2002, 04:57 PM
Appie is offline
Appie's Avatar
Joined Aug 2002
Intake Rings
Hi Gary,
Doyou have any pics's and or spec's of the intake rings you're taking about. ?? I think its wise to put them on because 20-30% increase of performance is worth it............
Thanks on forehand
Appie
BTW i will keep you guys informed about the flight progress.
(and if the twin EDF-50's don't work i will glue this one on the back of this little plane, and that will rock )
F-86 Sabre - My first EDF project BQuick Electric Ducted Fan Jet Talk 5 Sep 27, 2004 06:54 AM
Pics of my first EDF F5 Tiger 11 RCKing Electric Ducted Fan Jet Talk 5 Dec 30, 2003 12:57 PM
Return of Ubermoth... (also known as "My first poor attempt at aerial videography".. flipnidaho Aerial Photography 6 Jan 28, 2003 08:51 PM
Got my first EDF - T33 Wantab Electric Ducted Fan Jet Talk 8 Feb 02, 2002 10:15 PM
My First EDF Which one... kepople Electric Ducted Fan Jet Talk 8 Jun 30, 2001 01:43 AM
