Old May 07, 2007, 09:00 AM
Phil R is offline
Find More Posts by Phil R
Just some bloke
Phil R's Avatar
Up north, UK
Joined Mar 2005
Build Log
The birth of a new heli - it's flown
I decided to expand my aerial photography to include a heli as a platform...
I looked at the obvious helis for the job, then made a decision I may start to regret...
I've decided to scratch build my own AP heli.
I may need a little help along the way...
In terms of size, I've decided to go with somewhere between 1200 - 1500mm rotor diameter which allows me to use some parts (that I can't build) from the Swift/T-Rex 600/Logo etc... I'm thinking gears, boom, belt, blades etc.
My experience with helis is quite limited, I've only been flying them for about 5 months, have limited access to hands on experience of different helis. I own an Eco 8 and like the way it flies. I've therefore decided to base the head geometry on this.
Other parts of the Eco 8, I feel are inadequate for the job though...
Some questions...
I'm thinking of using the main gear from the Century swift (cheap, big teeth on the gears). Can anyone give me the diameter and thickness of this?
I can't see myself making a swash plate... any suggestions? I'll be happy with a 120 degree, but it has to alloy and have metric threads for the ball links. Hole in the ball must be 8mm or bigger.
Can anyone give me the length and O/D of the tail-booms for the Swift and T-Rex 600? Any others?
Any thoughts/suggestions are welcome... will update as progress progresses. Now back to the CAD...
Phil R is offline Find More Posts by Phil R
Old May 07, 2007, 09:41 AM
RC Man is online now
Find More Posts by RC Man
A man with too many toys
United States
Joined Feb 2001
Probably the least expensive way is to start with a very popular helicopter like a Raptor 30/50. You can usually find then on eBay. You can sell the parts you donít need Ė sometimes the parts are worth more than the entire helicopter.
Pick something that there are lots of aftermarket parts available at a reasonable price. ECO8 parts are usually very expensive.
If you use a Raptor E550 upper frame then the stock swashplate will work plus the eCCPM setup will be very easy.
RC Man is online now Find More Posts by RC Man
Old May 07, 2007, 11:05 AM
Phil R is offline
Just some bloke
Phil R's Avatar
Up north, UK
Joined Mar 2005
Originally Posted by RC Man
Probably the least expensive way is to start with a very popular helicopter like a Raptor 30/50. You can usually find then on eBay. You can sell the parts you don’t need – sometimes the parts are worth more than the entire helicopter.
Thought of doing that... but then thought I'd be selling all but about 4 bits...
I don't think I'll be using any Eco 8 parts. The design of the head will be based on the Eco 8, but I'll be making it from scratch.
I'll look at that, but I've already got the frame, head, and gear train drawn...
Old May 07, 2007, 02:43 PM
Fred Bronk is offline
Find More Posts by Fred Bronk
Our Daddy and Heli Junkie
Fred Bronk's Avatar
In Heli Wonderland
Joined Aug 1999
Hmm, why not just get a Swift kit and stretch it out? Get a Raven boom and a Trex belt and you can swing 600 blades. I would for sure use the 3 bearing upgrade.
This way you are not re-inventing the wheel, just getting it retreaded
FB
Fred Bronk is offline Find More Posts by Fred Bronk
Old May 07, 2007, 05:49 PM
Phil R is offline
Just some bloke
Phil R's Avatar
Up north, UK
Joined Mar 2005
FB
For a Milling machine and all the tooling, there's MasterCard... (Just over £400 ($800) so far...)
The feeling that you're flying a unique machine... Priceless
Old May 07, 2007, 05:54 PM
Phil R is offline
Just some bloke
Phil R's Avatar
Up north, UK
Joined Mar 2005
Sat at the CAD machine all day... a neccesary evil...
Thought I'd make a start cutting metal tonight. Just to explain what I mean by "scratch built", there's a pic below...
The block of ally is destined to be the head. I've drilled and reamed the block for an 8mm silver steel main shaft and am using this as a datum.
Here I'm clocking up a ground steel shaft that's a good fit in the hole in readiness for the final cut with the end mill.
Old May 07, 2007, 06:20 PM
ozace is offline
Find More Posts by ozace
Renewed interest
ozace's Avatar
Melbourne , Australia
Joined Jun 2002
After just getting a mill and lathe myself i am in awe of such an undertaking. I cant wait to see more as this takes shape.
ozace is offline Find More Posts by ozace
Old May 07, 2007, 06:23 PM
Kosmic is offline
Find More Posts by Kosmic
Canada
Joined Dec 2004
hmmm this should be interesting ... please proceed
(subscribed)
Kos
Kosmic is offline Find More Posts by Kosmic
Old May 07, 2007, 06:57 PM
Wheelhaus is offline
Find More Posts by Wheelhaus
volts x amps = watts.
Wheelhaus's Avatar
Denver
Joined Sep 2006
(subscribed)
+1 I'm not into AP but I love custom projects...
Wheelhaus is offline Find More Posts by Wheelhaus
Old May 07, 2007, 09:56 PM
Fred Bronk's Avatar
In Heli Wonderland
Joined Aug 1999
Heck, I just got my 3rd mill (2 working though)
Time for a project
FB
Old May 08, 2007, 01:15 PM
heli_addict is offline
Find More Posts by heli_addict
High speed bug smasher
heli_addict's Avatar
Bradenton, FL
Joined Jan 2007
Subscribed...this sounds like a fascinating project and one that's way beyond my (current) skill level. Will follow with interest!
heli_addict is offline Find More Posts by heli_addict
Old May 08, 2007, 03:34 PM
Phil R is offline
Just some bloke
Phil R's Avatar
Up north, UK
Joined Mar 2005
Believe me, this is a big learning process for me... I've worked metal before, owned a lathe for years, but 'till I bought the mill, I'd never used one.
Lessons learned so far...
A mill is almost useless without a dial test indicator.
Swarf is rather difficult to get out of the carpet.
Wood router bits make quite good end mills for ally - they're dirt cheap. It's a good job because...
Buying the mill is only the start of the big money spend. The list of extras - tooling, clamping stuff, vices, collets, arbours, etc. is a never ending one.
This heli is going to cost me a fortune...
Progress so far...
The head looks like the pic below. There's a lot more metal to be removed now I've had a look at it (I'm not that good at visualizing things on the CAD machine). The bolt is going to nip the head to the shaft to take up any (tiny amount) play - there's a slot to cut of course.
So far, I'm quite pleased with myself...
Old May 08, 2007, 05:44 PM
ozace is offline
Renewed interest
ozace's Avatar
Joined Jun 2002
i know all about tooling costs i am looking for a rotary table for mine right now.
Nice start on the head block , cant wait to see more
Old May 08, 2007, 08:11 PM
Heli Mod Man is offline
Find More Posts by Heli Mod Man
---------Speed!!---------
Illinois
Joined Jul 2003
Very nice! It is amazing what you can do with the right tools and some patience.
Matt
Heli Mod Man is offline Find More Posts by Heli Mod Man
Old May 08, 2007, 09:50 PM
Fred Bronk's Avatar
In Heli Wonderland
Joined Aug 1999
What size you looking for? I have a 6 inch that I don't need anymore. New, but has a little surface rust (fire hoses get water everwhere )
FB
New to heli's, Hummingbird problem? Summer Micro Helis 0 Nov 21, 2003 11:05 PM
New to Heli's! ECO 16 first mistake?? Luckylandings Electric Heli Talk 15 Jul 24, 2003 09:41 PM
Hey guys, new to heli's and would like some info =) jayboy Electric Heli Talk 8 Feb 21, 2002 12:48 AM
Hobby Lobby has some new Heli's wayne Electric Heli Talk 2 Nov 09, 2001 12:54 AM
