Old Aug 08, 2010, 10:43 AM
bz1mcr is offline
Find More Posts by bz1mcr
AKA Don
United States, FL, Naples
Joined Dec 2002
I have come to like laminated "monoblocks" better anyway. They are much stronger.
bz1mcr is offline Find More Posts by bz1mcr
Old Aug 08, 2010, 11:12 AM
philipa_240sx is offline
Find More Posts by philipa_240sx
philipa_240sx's Avatar
Ontario, Canada
Joined Apr 2010
I now use my hot wire cutter for monoblocks. I'm planning to build a scroll saw version with a rip fence and mitre capabilities... just haven't had the time.
Otherwise, the easiest method I've found is a coping saw with a very fine toothed blade (28tpi or higher). Leave some excess then smooth with a sanding block and 220 grit paper.
philipa_240sx is offline Find More Posts by philipa_240sx
Old Aug 08, 2010, 11:22 AM
Ontario, Canada
Joined Apr 2010
Speaking of BB's, I'm planning a variant of the BB42. A 1/9th scale 1941 Taylorcraft BC12. Wingspan will be stretched a bit to 48".
Just starting the drawings now.
Old Aug 08, 2010, 12:30 PM
Ierwin is offline
Find More Posts by Ierwin
Germany
Joined Jun 2009
just wanted to report another successful BB maiden flight.
We had higher wind than I normally would have liked for a maiden, but since I knew the model I knew it wouldnt do anything funny.
Still on the first battery pack my friend managed take offs, landings, loops and general wind fighting.
mission accomplished: Another person addicted!
Ierwin is offline Find More Posts by Ierwin
Old Aug 08, 2010, 04:38 PM
marhar is offline
Find More Posts by marhar
Mark Harrison
USA, CA, Piedmont
Joined Jun 2010
Originally Posted by Hazydog View Post
How did you cut the block?
I had great results with a straight-edge bread knife like this:
marhar is offline Find More Posts by marhar
Old Aug 08, 2010, 07:19 PM
Hazydog is offline
Find More Posts by Hazydog
Hazydog's Avatar
USA, Concord NC
Joined Aug 2010
Thanks for the quick replies. I'll give the bread knife a try. Keep my eyes peeled for an electric craving knife too.
Hazydog is offline Find More Posts by Hazydog
Old Aug 09, 2010, 08:52 PM
AltonMan is offline
Find More Posts by AltonMan
My middle name is Alton
AltonMan's Avatar
Grand Rapids, Michigan
Joined Nov 2007
Hi guys, I have been a fan of the blu-baby for a couple of years now. I currently have a blu-baby 33 and a 42 with ailerons. I love this plane.
I have been working on a pusher prop plane that has monoblock construction similar to the blu-baby.
My most recent design changes I made to the Yeti (that's what I called it) include using the wing from the blu-baby 33.
I first made the fuselage for the Kfm3 Sport wing, and I just made and adapter to let me use the UC wing.
AltonMan is offline Find More Posts by AltonMan
AltonMan is offline
AltonMan's Avatar
Joined Nov 2007
The Yeti - Version 2, Undercambered Wing (2 min 38 sec)
Old Aug 10, 2010, 01:33 PM
TD-Linux is offline
Find More Posts by TD-Linux
Rochester, Minnesota
Joined Apr 2010
I was repairing my 42" blu-baby today which involved gluing in the firewall... however, after the glue set I saw that the motor was pointed downward a bit... about 15 degrees or so from where I would normally put it. I've heard people say that shimming the thrust downward a bit helps, but is this too much? I'd rather not rip off the firewall again if I don't have to, and I have no idea what the thrust angle affects.
TD-Linux is offline Find More Posts by TD-Linux
Old Aug 10, 2010, 02:11 PM
bz1mcr is offline
AKA Don
Joined Dec 2002
Any off axis of a motor will pull the nose of the plane in the direction of the offset when power is increased.
15 degrees sounds like way too much.
High wing, tractor, planes normally use some right thrust to offset the prop blast effect on the vertical stab and the roll effect of the motor torque reaction. They also commonly have some down thrust to balance the wings tendency to pull the nose up with increased speed. When the offsets are right the plane just accelerates forward and begins a shallow climb when power is increased. Like wise the plane maintains heading and just lowers the nose when power is removed. If the thrust angle is wrong the plane will pull right or left and up or down when the throttle setting is changed. You can fly it but it takes alot more stick motion to keep it headed in the desired direction.
Old Aug 10, 2010, 04:13 PM
JohnsPop is offline
Find More Posts by JohnsPop
JohnsPop's Avatar
LaGrange, GA
Joined Jun 2009
Hey TD, is your motor mounted so you can get some washers behind it? If the 15 degrees is too much, maybe you can put a few washers behind the lower mounts to help angle it back upwards a bit. Then maybe you won't have to pull the firewall completely back out.
JohnsPop is offline Find More Posts by JohnsPop
Old Aug 10, 2010, 04:16 PM
TheTrashMan is offline
Find More Posts by TheTrashMan
TheTrashMan's Avatar
Joined Jul 2009
is there any difference performance wise between the 2 different stabs you can use for the bb 33??
TheTrashMan is offline Find More Posts by TheTrashMan
JohnsPop is offline
JohnsPop's Avatar
LaGrange, GA
Joined Jun 2009
Nice little plane there Alton! Looks kinda like a cross between the BB and Tony's Tuffy. Looks like she flies pretty good but maybe a little tail heavy with the up attitude it seems to have. Looks good though dude!
Old Aug 10, 2010, 04:52 PM
schrockie is offline
Find More Posts by schrockie
I hate gravity!!
schrockie's Avatar
Tampa, Florida
Joined Jan 2010
nope, just what style you prefer, old-time or modern.
Troy
schrockie is offline Find More Posts by schrockie
Old Aug 10, 2010, 06:48 PM
insomaniac45 is offline
Find More Posts by insomaniac45
Not always grumpy!!
insomaniac45's Avatar
UK, Eastleigh, Eastleigh
Joined Jul 2010
im gonna stick with the old time feel with mine, so im gonna paint it like a j3 cub
yellow lol
insomaniac45 is offline Find More Posts by insomaniac45
Video Blu-Baby Primary Trainer Tony65x55 Electric Plane Talk 0 May 05, 2007 06:05 AM
Chosing Trainer...Kit?Plans?RTF? Seared Ice Fuel Plane Talk 49 Aug 16, 2004 11:50 AM
Which SPAD Trainer to build?? Plans? VBSuperMaxx SPAD - Simple Plastic Airplane Designs 12 May 05, 2004 09:19 PM
Sold FS: Fireball 550 Trainer "PLANS" Rudderman98 Aircraft - Electric - Airplanes (FS/W) 4 Dec 05, 2002 07:38 PM
