Old Feb 07, 2010, 08:10 PM
Vicarious is offline
Find More Posts by Vicarious
One of the usual suspects
Vicarious's Avatar
United States, AL, Huntsville
Joined Jun 2007
Originally Posted by pdiddyg40 View Post
Hey everyone, I've been following this thread for a while now, and have just recently crashed a plane and free-ed up some electronics
My motor is an Axi 2204-54, so i was wondering if there have been any mini-bluebabies built. (I havent seen any under 22 inches.) Either way, i have 2 questions:
1) what is the suggested RTF weight of a Bluebaby 24" My motor is suggested for planes around 7oz so light is a good thing here. Plus, ive been looking for a solid, mini-backyard plane.
2) Can i scale down the 24 inch plans to make a 15-18 plane? Or can anyone help me scale them down?
Thanks for all the help here, ive been following this thread for quite a while now
About midway down this post is a link for a 12" WS BB
http://www.rcgroups.com/forums/showt...8#post11531498
Vicarious is offline Find More Posts by Vicarious
Old Feb 07, 2010, 09:17 PM
eljay2 is offline
Find More Posts by eljay2
eljay2's Avatar
Texas Hill Country
Joined Sep 2009
RC Fly Boy,
This is how I reinforced my wing. .125 carbon tube glued and taped in both halves, 0.0625 music wire, bent to match the dihedral, slipped into the two ends of the carbon tube.
survived several flights including a tight loop, plus one head in crash.
Oh, also have clear packing tape the length of both wings, doubled over at the joint.
David
eljay2 is offline Find More Posts by eljay2
Old Feb 07, 2010, 10:10 PM
springer is online now
Find More Posts by springer
treefinder
springer's Avatar
SE MI
Originally Posted by rbrown3rd View Post
Sounds like a plan. The KFM wing is at zero incidence when compared to the horizontal stab right?
Right, KFM's are all zero, UC is about 1/8 to 1/4 up at LE, and you can figure that into the saddle sides, about a Blucor thickness.
I just remembered that i'd posted on my blog how mine looks, may want to check it out.
springer is online now Find More Posts by springer
Old Feb 07, 2010, 11:12 PM
RC Fly Boy is offline
Find More Posts by RC Fly Boy
United States, CA, Rancho Cucamonga
Joined Oct 2008
Thanks EljY2, that is what I will do on my new wing...
RC Fly Boy is offline Find More Posts by RC Fly Boy
Old Feb 09, 2010, 07:35 PM
Prop stitches is offline
Find More Posts by Prop stitches
Prop stitches's Avatar
United States, WI, Avoca
Joined Dec 2003
Out of The Loop
Sorry to bother you folks while you are having so much fun. But I have been out of the loop for quite a while now.
I built a Blu-Baby AP1 quite a while back, and even maidened it last summer, I finally feel better now, and was able to get my plane up off the snow a few days ago, and I even got some aerial vid. I sure hope I am in the right forum for this thing. I am sure some one will straighten me out.
Gary flys around his house in Lovely West Wisconsin.wmv (10 min 0 sec)
Prop stitches
Prop stitches is offline Find More Posts by Prop stitches
Old Feb 09, 2010, 09:03 PM
treefinder
springer's Avatar
SE MI
Oooh, 10 minutes! I'll have to wait to get to the library to watch that one!
Old Feb 09, 2010, 10:01 PM
mxspode is offline
Find More Posts by mxspode
If it flies, I will crash it
mxspode's Avatar
USA, CO, Westminster
Prop stitches
Well you are certainly in the right place. Your video defines amateur aerial video. Very impressive and a treat to watch. Simply beautiful. Thanks you so much for posting it.
Rob...
P.S. I encourage everybody to go to YouTube and rate this one. It should be well regarded.
mxspode is offline Find More Posts by mxspode
Old Feb 10, 2010, 09:48 AM
Joined Dec 2003
Thank you so very much for the nice things you said about my video, Rob.
I appreciate your comments.
The video was taken with one of those $11.00 Gum Cameras off of e-Bay.
Prop s
Old Feb 10, 2010, 10:51 AM
PatricMichigan is online now
Find More Posts by PatricMichigan
PatricMichigan's Avatar
United States, MI, Hillsdale
Joined Apr 2008
Prop s
If I may, what vendor did you use to get the cam and were you happy with them?
I've been looking at them but not being an active ebay-er I haven't done anything yet.
Thanks!
Patric
PatricMichigan is online now Find More Posts by PatricMichigan
Old Feb 10, 2010, 05:07 PM
Lowflyer52 is offline
Find More Posts by Lowflyer52
Lowflyer52's Avatar
Albany, Or
Joined Jan 2009
I bought one from hobby partz. I paid almost 30$ though I never thought to check ebay. I am happy with mine - very simple to use. But does anyone else get interference from the planes motor? More throtle = more distortion. I get a wavy picture.
Lowflyer52 is offline Find More Posts by Lowflyer52
Old Feb 10, 2010, 06:18 PM
mxspode is offline
mxspode's Avatar
That is normal and some cams are worse then others. Best to get it as far away from the ESC and motor as possible. Not much else you can do about it.
Rob...
Old Feb 10, 2010, 08:51 PM
jackerbes is offline
Find More Posts by jackerbes
Jack
USA, ME, Ellsworth
Joined May 2008
"..But does anyone else get interference from the planes motor? More throtle = more distortion. I get a wavy picture..."
If it is a swimming motion like you'll see here:
http://www.vom.com/jack/swimming.avi
A more rigid mount might fix it. It can be a challenge though. If the airframe is vibrating then you need to isolate the camera from that with some foam or something. If the wing is not vibrating, just the camera is vibrating, then firming up the mount or adding something like a layer of well compressed foam between the camera and the wing might do it.
I started with a thin, bendable for look angle, aluminum bracket on the camera. Then worked out a way to put that on the wing.
It the first two photos is the first mount I used. It was two loops of small bungee cord that went over the aluminum bracket. That worked fairly well but the swimming would come and go with air speed and motor speed. Folding a double layer of 1/4" RC foam (the white foam seen on the battery there) and putting that between the bracket and the wing, along with tightening the bungee cord loops, finally got it solid.
The next two are another flying wing. I drilled a hole so it was a snug fit on the short cylindrical nylon bushing and put the bushing in the hole in the wing. Then I put nylon flat washer on top and bottom of the wing and used a 1/4" nylon machine screw. The screw came up from the bottom, the camera rested on a piece of foam that was on top of the washer, then I put a 1/4" wing nut on it all. When it was snugged down pretty good it did not vibrate.
Sometimes is looks like I have too much time on my hands...
Jack
jackerbes is offline Find More Posts by jackerbes
Old Feb 10, 2010, 09:47 PM
treefinder
springer's Avatar
SE MI
Can't remember if I posted this or not, but somewhere back in this thread, there was a mention of doing a dual rotor gyrocopter version of the BluBaby. If any of you guys are interested, here's the link to the thread in the gyrocopter forum: http://www.rcgroups.com/forums/showthread.php?t=1186165
Old Feb 11, 2010, 11:27 AM
steve1935 is offline
Find More Posts by steve1935
Steve
1901 Skaggs Rd., Sherman, TX 75090
Joined Jan 2007
I am getting ready to build a BB33 and need to order a motor. I know that there are bound to be posts in this thread that would be helpful, but there are 904 to wade through. I would like something on the economical side. I would like something on the upper end of the power requirement. I need some other things from HobbyKing so would prefer to but there. Thanks for your imput
Steve
steve1935 is offline Find More Posts by steve1935
Old Feb 11, 2010, 11:47 AM
Vicarious's Avatar
Joined Jun 2007
Steve
I'm gonna say the Blue Wonder from Heads Up RC
Specs are on the page.
Video Blu-Baby Primary Trainer Tony65x55 Electric Plane Talk 0 May 05, 2007 06:05 AM
Chosing Trainer...Kit?Plans?RTF? Seared Ice Fuel Plane Talk 49 Aug 16, 2004 11:50 AM
Which SPAD Trainer to build?? Plans? VBSuperMaxx SPAD - Simple Plastic Airplane Designs 12 May 05, 2004 09:19 PM
Sold FS: Fireball 550 Trainer "PLANS" Rudderman98 Aircraft - Electric - Airplanes (FS/W) 4 Dec 05, 2002 07:38 PM
