Old May 10, 2007, 08:45 PM
raythomas is offline
Find More Posts by raythomas
KZ RIDER
raythomas's Avatar
United States, MS, Tupelo
Joined Nov 2001
sportwing!!!
sportwing!!!
SPORTWING!!!!
Just a goofy question.
Is there a big difference between a J250 and a SP280?
Thanks Ray
raythomas is offline Find More Posts by raythomas
Old May 10, 2007, 08:52 PM
Tony65x55 is offline
Find More Posts by Tony65x55
I'm not flying backwards!
Tony65x55's Avatar
Oshawa, Canada
Joined Sep 2004
Originally Posted by raythomas
sportwing!!!
sportwing!!!
SPORTWING!!!!
Sport Wing next!
Tony
Tony65x55 is offline Find More Posts by Tony65x55
Old May 10, 2007, 08:56 PM
brucej is offline
Find More Posts by brucej
Good glue is evil
melbourne australia
Joined Sep 2003
tnx for the new plans
Tony
sorry to hear about the crash.
brucej is offline Find More Posts by brucej
Old May 10, 2007, 09:59 PM
Foamenator is offline
Find More Posts by Foamenator
AMA 8614
Foamenator's Avatar
Northern Nevada
Joined Mar 2007
Thanks Tony
Thanks again for all your efforts. It is really appreciated by all of us. Bob
Foamenator is offline Find More Posts by Foamenator
Old May 11, 2007, 08:07 AM
FirstShirt is offline
Find More Posts by FirstShirt
You deserve my opinion
FirstShirt's Avatar
Collierville, TN
Joined Apr 2005
Originally Posted by Foamenator
Pat ... Is BB2 still airborne? I didn't take BB Birdog out today. After reading Tony's post I thought I'd let the Karma pass. Bob
Bob, good news. The Blu Baby 2 came back home yesterday while I was at work. Only damage was that the rudder was loose and had to be reattached. Can't help but wonder if the rudder came loose before the tree landing or as a result of it. Given the way things happened, I'm beginning to think that I didn't have the rudder well-attached and that was the cause of encounter with the tree. Guess I'll never know for sure. But at least I got the Lesser Spotted Weevil.
Flew the repaired BB2 early today. It was just great fun. Lots of T&Gs with no problems.
Tony, you are the man! Thanks so very much for your work on the new templates. I think I'm going to have to try the 42".
FirstShirt is offline Find More Posts by FirstShirt
Old May 11, 2007, 09:20 AM
AMA 8614
Foamenator's Avatar
Northern Nevada
Joined Mar 2007
Good to Hear
Pat... My rudder and stab were a little loose after my episode as well so I foamenated them a little for reinforcement. Glad BB2 is back in service. Bob
Old May 11, 2007, 05:20 PM
AlexSv is offline
Find More Posts by AlexSv
AlexSv's Avatar
Savona,Italy
Joined May 2007
Originally Posted by Tony65x55
Thanks for the crying towels guys. I appreciate it.
OK folks, you asked for it. Here are the plans for the Blu-Baby Park 42" and the Blu-Baby AP 52". As well, Bob's Bird Dog was so inspiring, I did a semi-scale fin and rudder for those of you wishing to "Bird Dog" your BBs
Enjoy,
Tony
PS: I really gotta start building
Uao, new plans, new building !! :O)
Thanx for the great job, man !
BYe,
Alex
AlexSv is offline Find More Posts by AlexSv
Old May 12, 2007, 08:52 AM
Mayday!Mayday! is offline
Find More Posts by Mayday!Mayday!
Check my blog-updated
Mayday!Mayday!'s Avatar
Columbus,Ohio
Joined Nov 2005
Hey does anyone have a pic of the inside where they placed the servos, Rx and esc?
Just tryin to get an idea where everything was placed.
Mayday!Mayday! is offline Find More Posts by Mayday!Mayday!
Old May 12, 2007, 10:51 AM
FirstShirt's Avatar
Collierville, TN
Joined Apr 2005
Mayday, I haven't seen Tony's recommendation, but here what I did on my second BB. In the pix, the front of the fuse is to the left. Basically, I pushed all the components as far forward as possible. I have a very light motor (Westport 22.5mm/20T CD), so it doesn't add much weight on the front end.
CG is right-on and the plane is very stable in the air.
EDIT: Thanks to Ray for pointing out that this fuse is wider than what is on the plan.
PS I don't recommend the Bluebird Rx, but am using what I have.
Old May 12, 2007, 11:58 AM
nubee 1 is offline
Find More Posts by nubee 1
Joined May 2006
FirstShirt
What battery are you using ? I'm making mounts for servos now and wondering if I need to keep them as far forward as I can. My tail is 2 popsicle sticks 2 blind nuts and 2 4-40 X 1/2" heavier. I'm using a 24 gram Blu-Wonder and a 68 gram 3s lipo.
Ken
nubee 1 is offline Find More Posts by nubee 1
Old May 12, 2007, 01:38 PM
FirstShirt's Avatar
Collierville, TN
Joined Apr 2005
Hey, Nubee!
I'm using a 2s 620mah (37g) and a 2s 800mah (47g). Because the battery is located at or very near the CG, I don't think the weight of the battery (within reason) is an issue. I think you'll find that the BB requires very little power to operate.
All I can tell you on the servos, Rx, etc. is that moving them as far forward as possible worked great for me. You might consider just sitting your components where you think you want them, add the battery, then check the CG.
Pat
Old May 12, 2007, 01:42 PM
KZ RIDER
raythomas's Avatar
Joined Nov 2001
Hey FirstShirt
Isn't that a picture of your wide body baby blu?
The one with the stacked sheets of epp?
If it is, doesn't it have more room inside for servos and running gear than the original pinkfoam monoblock design?
Just curious.
I also was wondering where to mount the equipment.
Thanks Ray
Old May 12, 2007, 02:13 PM
nubee 1 is offline
Joined May 2006
Mine is a 2" pink one but to use a micro control rod cut in half my servos will be right up even with back of monoblock. I'd like to see where the motor wires go threw the block. I guess i'll cut a grove in top.
Ken
Old May 12, 2007, 02:33 PM
FirstShirt's Avatar
Collierville, TN
Joined Apr 2005
Hey FirstShirt
Just curious.
Thanks Ray
Oops! Ray, you're absolutely right. Both of mine have a wider fuse. So, yes, I have more room for equipment than in the fuse shown on the plan. Thanks for pointing that out. I'll do an edit on that post.
Video Blu-Baby Primary Trainer Tony65x55 Electric Plane Talk 0 May 05, 2007 06:05 AM
Chosing Trainer...Kit?Plans?RTF? Seared Ice Fuel Plane Talk 49 Aug 16, 2004 11:50 AM
Which SPAD Trainer to build?? Plans? VBSuperMaxx SPAD - Simple Plastic Airplane Designs 12 May 05, 2004 09:19 PM
Sold FS: Fireball 550 Trainer "PLANS" Rudderman98 Aircraft - Electric - Airplanes (FS/W) 4 Dec 05, 2002 07:38 PM
