Old Aug 30, 2007, 12:15 PM
tuppertn is offline
Find More Posts by tuppertn
Postcards From The Purple Edge
tuppertn's Avatar
United States, OK, Sand Springs
Joined May 2007
My son is only 6, so I don't think he's quite real to take the sticks on his own yet. He can fly the heck out of just about anything on RealFlight G3.5--video game monkey that he is. Not exactly a good thing, though. The couple of times he's worked the BB sticks he got frustrated because he wanted it to handle like an Ultimate.
tuppertn is offline Find More Posts by tuppertn
Old Aug 30, 2007, 12:24 PM
Kaos2 is offline
Find More Posts by Kaos2
Heli's don't fly voluntarily
Kaos2's Avatar
United States, TN, Columbia
Joined Apr 2007
Build him a Regal and let him go!
Kaos2 is offline Find More Posts by Kaos2
Old Aug 30, 2007, 02:56 PM
muidaq is offline
Find More Posts by muidaq
USA, OH, Westerville
Joined Aug 2007
I'm nearing completion of my 52" flat wing BB and I noticed the wing is quite flexible. Does the wing need to be more rigid than a single piece of foam? Does it need support and/or reinforcement? I got some wooden plant support sticks from the foam section of the craft store i was thinking of attaching along the bottom of the wing. Is this a good idea?
muidaq is offline Find More Posts by muidaq
Old Aug 30, 2007, 03:02 PM
Kaos2 is offline
Kaos2's Avatar
Joined Apr 2007
Turn it into a top step KF airfoil. That will solve your wing flex issue, plus fly better than a flat plate.
Old Aug 30, 2007, 03:17 PM
muidaq is offline
Joined Aug 2007
Are there plans for the 52"kf?
Old Aug 30, 2007, 03:49 PM
elight50 is offline
Find More Posts by elight50
Joined Aug 2006
Servo for Ailerons:
Does this servo have to be beefier than the servos on the rudder/elevator? Any special considerations about where to locate it and to run the control rods?
elight50
elight50 is offline Find More Posts by elight50
Old Aug 30, 2007, 03:52 PM
Kaos2 is offline
Kaos2's Avatar
Joined Apr 2007
You don't need plans. Cut a hunk of foam that is 50% the size of your wing. Bevel the front with your Xacto on the top and bottom to a 45 degree angle. Get a piece of spruce 1/8" X 3/8" X 36". Measure 1/2 way back from your leading edge on the lower wing and glue the spar in centered. Lay your top foam on the spar. Edges should be flush with spar, leading edge, and of course wing tips. Glue the top foam to the spar. Use packing tape to secure the top to the bottom stock along the leading edge. Cut 3/8" foam filler for the gap between the spar and the wing tip and glue in place. You can aslo cut a wedge to fill the wing tip opening.
Look at the pictures in this thread.
Old Aug 30, 2007, 05:36 PM
Truglodite is offline
Find More Posts by Truglodite
Registered Aircraft Offender
Truglodite's Avatar
Carmichael, CA
Joined Feb 2007
Originally Posted by elight50
Servo for Ailerons:
elight50
typically yes, but if you're tail servos are overkill then maybe not.
to give you an example a 9gm servo works well on a 32"bb wing, but if you have 9gm servos on the tail then they're all the same size. on the other hand you can probably get away with 5gm servos on the tail of the 32" bb, in which case the 9gm wing servo would be "beefier".
it also depends on the wing config: 1 or 2 servo (ailerons or flaperons). for example, if a single 9gm servo works well for ailerons on a given wing, then obviously using 2@ 9gm servos on the same wing for flaperon control would be overkill/wasted weight. in this case 2@ 5gm servos would be a better/lighter fit, since 2@ 5gm servos put out the same or more torque than a single 9gm servo.
btw, what size were you building again, & are you using flaperons? (sorry, my short term memory is horrible)
-kev
[nm, it's 42" right? i'd use hs-55 (or similar) all around. when you are ready to convert to kfm you can add a second servo for flaperons & more aggressive controls, but a single 55 should be enough for now.]
Truglodite is offline Find More Posts by Truglodite
Old Aug 30, 2007, 08:39 PM
elight50 is offline
Joined Aug 2006
Kev -
I was intending to build a 42 inch KF with ailerons. To be honest, I don't quite understand how to set up the third servo to operate the ailerons. A mini tutorial on ailerons and servo set up would be helpful.
thanks,
elight50
Old Aug 30, 2007, 09:30 PM
tuppertn is offline
tuppertn's Avatar
Joined May 2007
Put the third servo on the underside of the wing in the center (inside the fuse) close to the LE. Orient the servo along the long axis of the fuse. Use a double-arm control arm oriented parallel to the wing. You'll need to cut your ailerons so they are full span. Control horns go close to the fuse. Run a control rod from each arm to each horn forming a "V" shape pointing toward the nose of the plane. When the servo moves it pushes on one the control rod and pulls on the other moving the ailerons in opposite directions. You'll need to cut "windows" in the sides of the fuse for the control rods to exit out of. My digital camera doesn't work or I'd post a pic of mine, but here's a cheesy MSPaint diagram viewed from the underside of the wing.
EDIT: An aileron deflected upward will change the cord line to reduce that wings lift causing that wing to drop. A downward deflected aileron increases the lift of the wing causing the wing to go up. So just make sure your channel reversing is set so that the aileron on the side you're turning to goes UP, eg: left turn = left aileron UP
Old Aug 30, 2007, 10:12 PM
Daddy-O is offline
Find More Posts by Daddy-O
John 3:16
Daddy-O's Avatar
Dom. Rep.
Joined May 2003
I was just weighing our new B-Baby and it comes in at 9.9 ounces without the landing gear wire. I do have the wheels included in the 9.9oz. I'm not sure how much the wire and glue to get it all in there will come to, but it looks like we are looking at a Baby that will about 11 ounces at birth. How does that compare to the other ones out there? Do I have a big baby, and normal sized baby or a small baby (not likely)?
Daddy-O
Daddy-O is offline Find More Posts by Daddy-O
Old Aug 30, 2007, 11:24 PM
tuppertn is offline
tuppertn's Avatar
Joined May 2007
Mine was 10.2oz with 1320mAh 2S and 24g motor. I added an ounce with the new motor so now I'm 11.3oz, but she flies much better.
11.7oz with the aileron wing.
Old Aug 31, 2007, 11:20 AM
elight50 is offline
Joined Aug 2006
The diagram answers may questions. Thanks again.
To all - have a great holiday weekend!
Elight50
Old Aug 31, 2007, 10:47 PM
Daddy-O is offline
John 3:16
Daddy-O's Avatar
Dom. Rep.
Joined May 2003
We just gave birth to our new baby (it's finished). It weights 10.8 to 10.9 oz (kinda flippin between the two) with the 2s 800 battery pack. It looks pretty good, but I bugered it up a little bit while finishing it up. It's not noticable at first glance though. I did something I've never done before. I connected both control horns to the elevator (didn't have anything on the rudder!). I couldn't believe it when I finished! It's all good though. I'll post some pre-maiden pictures tomorrow.
Daddy-O
Old Sep 01, 2007, 07:50 AM
Daddy-O is offline
John 3:16
Daddy-O's Avatar
Dom. Rep.
Joined May 2003
Here are the promised pictures. It flew just great! It lands very gently and predictably. My son and I were both very happy with the plane (especially my son!). Thanks for putting this out there for us Tony.
Daddy-O
Video Blu-Baby Primary Trainer Tony65x55 Electric Plane Talk 0 May 05, 2007 06:05 AM
Chosing Trainer...Kit?Plans?RTF? Seared Ice Fuel Plane Talk 49 Aug 16, 2004 11:50 AM
Which SPAD Trainer to build?? Plans? VBSuperMaxx SPAD - Simple Plastic Airplane Designs 12 May 05, 2004 09:19 PM
Sold FS: Fireball 550 Trainer "PLANS" Rudderman98 Aircraft - Electric - Airplanes (FS/W) 4 Dec 05, 2002 07:38 PM
