Old Aug 18, 2007, 01:14 AM
Kurpal is offline
Find More Posts by Kurpal
Joined Nov 2006
I have been having a problem with my battery packs over heating on this plane due to a lack of air flow, and I think my motor starting to over amp, but none the less I wanted to correct it.
Here is my 'quick fix' for air flow into the battery bay. Sorry for the poor picture quality, I am using a ghetto digi cam.
I am in the process of getting the plane ready to paint after hours of flight time. I finally decided I should paint it when someone asked "What made you paint it pink and blue?" to which I had to explain that was the default color of the foam.
Kurpal is offline Find More Posts by Kurpal
Old Aug 18, 2007, 02:46 AM
Truglodite is offline
Find More Posts by Truglodite
Registered Aircraft Offender
Truglodite's Avatar
Carmichael, CA
Joined Feb 2007
i never had that problem with my original bb. then again, it never had a battery hatch. i admit, your table tennis ball idea looks better.
when ppl ask me why it's blue i tell them it's a spy plane & sky blue is harder to spot. j/k nobody has even asked me about colors or materials yet; they just ask "what's the wingspan?".
please post pics when you're done painting. i'd like to see it.
Truglodite is offline Find More Posts by Truglodite
Old Aug 18, 2007, 08:11 AM
qban_flyer is offline
Find More Posts by qban_flyer
Micro Flyer "Q"
qban_flyer's Avatar
United States, MD, Silver Spring
Joined Sep 2003
Originally Posted by warhead_71
I took the plans for the 33" BB and enlarged them to 48" - the exact width of a piece of FFF. It has KFm airfoil and I "slightly" modified the nose to accept my cowl, which is simply a plastic 1-quart oil bottle (2-3/8"x4" cross-section) - which leaves the perfect sized hole for a BP-21 when the neck is sliced-off. I'm using polystyrene for the monobloc and capping the ends with FFF. My KFm wing has about 1/2" dihedral and will have ailerons, perhaps flaperons just for kicks. Also, the KFm wing has a 1/2" step at the wing-tips and tapers to 3/4" in the center (total height, including the FFF). I won't be using that heavy LG and huge wheels, just balanced the plane on them to see how it'll look.
Gotta love that cowl, gotta love it!
qban_flyer is offline Find More Posts by qban_flyer
Old Aug 19, 2007, 03:00 PM
Truglodite's Avatar
Carmichael, CA
Joined Feb 2007
hehe, i totally love that cowl. when i saw that i was imagining what it would look like using mobil 1 gear oil bottles (the tall skinny kind with the handle).
btw warhead, i like your idea of capping the mono block with fff. i also used eps for the block on my 60" (home depot 2" white foam w/ the plastic skin peeled off). it's nice that it is less "pink". the capped block looks better & probably makes it much stronger regardless if it's pink or white.
kev
Old Aug 19, 2007, 06:48 PM
High Flyin' is offline
Find More Posts by High Flyin'
Out the Window
High Flyin''s Avatar
United States, FL, Alachua
Joined Jul 2004
I am thinking of building a Blue Baby with a KFm wing for my second plane. I had great luck with a STC with a blue wonder motor, but would like to try something different and maybe larger. I have one of these UH motors: https://www.unitedhobbies.com/UNITED...idProduct=4706
How large of a Blue Baby should I shoot for? I kind of like the idea of putting some wood spars in the wings for strength. Also the built up front end might help me as I was always breaking the front end off of the STC...not a fault of the airplane but bad pilot errors.
Any help would be appreciated!
Ray
High Flyin' is offline Find More Posts by High Flyin'
Old Aug 20, 2007, 04:35 AM
frank48 is online now
Find More Posts by frank48
Went to mow a meadow
frank48's Avatar
United Kingdom, Dur
Joined Feb 2007
Ray
Check out post #439 by Kaos2, he's built a 40" with exactly the same motor. It flies great you can see his video on post 440
Frank
frank48 is online now Find More Posts by frank48
Old Aug 20, 2007, 08:59 AM
warhead_71 is offline
Find More Posts by warhead_71
Always Ready!
warhead_71's Avatar
Chicago, IL
Joined Dec 2006
Yeah - the motor-oil 1-qt bottle makes a great cowl. Best thing is, every time i change the oil I get to make 5 more cowls. Like I said, I had to cut down the nose of the fuse "slightly" to make it fit... keeping the same thrust line and be careful that the motor lines up with the hole for the cut off neck. I originally thought I'd use the same bottle for a cowl for my 40" Tiger Moth that I'm building -- and it's a very, very close fit -- but I decided to make something more scale for that.
warhead_71 is offline Find More Posts by warhead_71
Old Aug 21, 2007, 11:46 AM
Truglodite's Avatar
Carmichael, CA
Joined Feb 2007
ray, 33" is a bit too small for for that motor (blue wonders turn a 33" into a hotrod trainer, more than that & you should start looking at faster designs meant for higher wingloadings). 52/60" would be on the floaty side with that motor. so i agree with frank: a 40" kfm with ailerons & that motor would make a great second plane. should be fun to fly when learning basic aerobatics like loops, rolls, inverted..., but it will still be cake to land in one piece.
-kev
Old Aug 21, 2007, 12:24 PM
Micro Flyer "Q"
qban_flyer's Avatar
Joined Sep 2003
YEP, elight50 has a BP-21 on his on two cells, spinning a GWS 10" prop. It will loop right out of your hands on hand launch if throttled higher than 1/2 open. Those motors are better used with the larger versions of the BB.
I will be using an E-Flite Park 300 on mine. It should be just about the right motor for it.
P.S. BP hobbies has that same motor for $12.50 and the ESC for an additional $16.95 which is a bit more than what you would pay from UH, but you would get it quicker and being a US purchase I would consider a bit safer.
They have one of their "own brand" BP outrunners that looks quite a bit like the Park 300 selling $17.95 (first link below). Second link leads to a Blue Arrow 10A ESC for $20 from them too. It should be just fine for the smaller BB .
http://www.bphobbies.com/view.asp?id...7&pid=B2171399
http://www.bphobbies.com/view.asp?id...1&pid=NBA06112
Old Aug 21, 2007, 06:00 PM
elight50 is offline
Find More Posts by elight50
Joined Aug 2006
Link Request
I can't seem to find the 42'' BB with the KFM wing marked on the drawings. Assistance appreciated.
elight50
elight50 is offline Find More Posts by elight50
Old Aug 21, 2007, 07:18 PM
horton is offline
Find More Posts by horton
ExtremeFlightRC.com
horton's Avatar
Joined Jun 2006
elight,
I think Tony is working on the plans. He mentioned he'll have them up within a week.
I'm looking forward to them.
Horton
horton is offline Find More Posts by horton
Site Sponsor
Old Aug 21, 2007, 08:38 PM
Truglodite's Avatar
Carmichael, CA
Joined Feb 2007
elight50, i'm not sure if the 42" kfm wing tony will post is the same, but i know kaos' 42" kfm flies great. if building the wing is holding you back from flying you could use some info from his posts to improvise one.
kaos cut the standard 42" wing then taped a 5" wide fff kfm strip to the LE (post 531). he also claims the optimal step thickness is between 7-9% of the chord (post 528). this equates to using a ~1/2" spar/filler under rear of the strip.
hope this helps.
-kev
[edit: btw, kaos used 2" wide ailerons if you're curious.]
Old Aug 21, 2007, 09:29 PM
chewytm is offline
Find More Posts by chewytm
Ipoh, Perak Malaysia
Joined Jul 2006
Originally Posted by horton
elight,
Horton
Tony, I hope you will publish the full-size plans also (like you did before), instead of just the tiled ones like some others do.
Tony, thanks for a great design, and for sharing.
chewy
chewytm is offline Find More Posts by chewytm
Old Aug 21, 2007, 09:35 PM
Daddy-O is offline
Find More Posts by Daddy-O
John 3:16
Daddy-O's Avatar
Dom. Rep.
Joined May 2003
I am going to start building a Blu-baby with my 11 year old son this week. He has been asking me to teach him how to build planes, and he wants an easy flying plane. I figured this would be the perfect plane. We have already built a STC with an epp fuse that I have since attached lights to, and fly at night. I think this will be a great plane for him and I to do together. We are going to start on Thursday after school, and work on it each night until it's finished. I am going to let him do most of the cutting and gluing, so I don't know how it will turn out. It should be interesting. He will have to learn to be careful with the sharp blades we use, and be sure not to glue his fingers together. Should be fun!
Daddy-O
Daddy-O is offline Find More Posts by Daddy-O
Old Aug 21, 2007, 09:36 PM
van-c is offline
Find More Posts by van-c
St. Pete, FL
Joined Feb 2006
33" KFm with Ailerons Build
I'm almost done with my 4-channel 33" BlueCor KFm build. As planned, I used dual HS-55 servos for the ailerons with radio mixing for flaperons and differential compensation. Ailerons are 2" at the root and 1.5" at the tip. Actually, I did not span them quite to the wingtips because I plan to experiment with different tip configurations and want a full cord fixed structure at the tips.
The only thing I'm a little puzzled about is the very narrow elevator cord. The horizontal stabilizer seems adequate, but I wonder about the authority of the elevator. Oh well, nobody else seems to have reported any problems with it, so I'll assume it's all right.
AUW is right on target at just under 9 oz. with AXI 2204/54 motor and 400 maH 2S. I hope to maiden Thursday or Friday.
--Van
van-c is offline Find More Posts by van-c
Video Blu-Baby Primary Trainer Tony65x55 Electric Plane Talk 0 May 05, 2007 06:05 AM
Chosing Trainer...Kit?Plans?RTF? Seared Ice Fuel Plane Talk 49 Aug 16, 2004 11:50 AM
Which SPAD Trainer to build?? Plans? VBSuperMaxx SPAD - Simple Plastic Airplane Designs 12 May 05, 2004 09:19 PM
Sold FS: Fireball 550 Trainer "PLANS" Rudderman98 Aircraft - Electric - Airplanes (FS/W) 4 Dec 05, 2002 07:38 PM
