Looking forward to the maiden report. Bz1mcr (Don), I need to stop by your place and drop a few foam trays on you. Ken
Latest blog entry: MPF M6 Mermaid Scratch and Kit Built
Wow! Every week there is a new brood of BB's. They sure are looking fine.
Kudos to Cybernaught, Aranel, Maguro, and Emil. Ken
I put the video of the BBAP1 maiden on YouTube. My first approach and landing leave a lot to be desired. Full flap landings are going take some practice. Next time out I will have the the camera on board. I can upload a video of the photo session and some aerial photos if anyone is interested.
BBAP1 Maiden (4 min 10 sec) |
Aranel
You can pick them up at almost any place that has a pots and pans section in the store. Also can be found by the BBQ grill section. Some have skewers at both spots. Light weight and super strong. I paid a $1 for a 100 12" at Walmart. Mike |
Hi,
Where goes the battery at the blu baby AP1? Above the camera bay?Isn`t that too high? Post a picture with the exact location of the battery Thanks ![]() Later edit: Is this wing good?(see picture) I can`t bend my foam 180 degrees because it breaks. I reinforced the front edge of the wing with 2x10mm pine wood,and the whole wing with 4x4 pine wood.
Maguro,
Very nice vid. I am going to rebuild that bird later when I get some more flight time under my belt. I want to take some AP at some point. she looks good. Quote:
wing looks good but, Someone else can correct me if I'm wrong, you might want to eather bevel the leading edge or I like to sand mine to a nice radius. Hope that helps Jon |
I would add fiber tape reinforcement to the leading edge after sanding.
The secret to folding a wing is to score the inside of the fold with a ball point pen or other pointed object. On the outside of the fold put packaging (fiber) tape. THen just easily coax the upper surface to fold over. Practice on a piece of scrap foam. You will pick up the skill very quickly. |
USA, ME, Ellsworth
Joined May 2008
Another method of folding is the one shown in the Wing Folding Instructions that were posted by Tony:
http://www.rcgroups.com/forums/showp...&postcount=140 http://www.rcgroups.com/forums/showa...mentid=1306286 I use those, cutting matching bevels on the pieces first, and have embellished the process by spraying an aerosol contact adhesive on the area the tape will be attached to. That makes the tape stick much better. After a couple of test tries, you get a feel for how much of a gap to have between the mating edges at the start of the fold. I usually have about a 1/8" gap and they just start to touch when the strip gets to about 90 degrees or vertical. Then the pressure starts increasing from there. I've also been laying a piece of 2.5 mm fibreglas rod (from kite kits) in the gap so that it winds up on the leading edge of the wing as a reinforcement and stiffener. How good an idea is the leading edge wing stiffener? I put my Industrial Strength BB 33 into a tree at about 30-35 MPH last week and it sounder like a wood chopper's ball. It made a *lot* of noise and I figured it was the death knell of that plane. I spotted the fuselage lodged up in a tree about 40 feet off the ground, all four of the #32 rubber bands had broken and the wing was laying on the ground. Undamaged! Well, one aileron horn did have to be hot glued back on. It took a 10 foot ladder and my roof snow rake handle (all 18 feet of it) to dislodge the fuselage. As a reward, it bonked me on the head on it's way down. No damage to the fuselage! A missing prop and a little minor repair and it was ready to go again. A monument to the carbon fiber arrow shaft that I am using as a fuselage stiffener. The BBIS 33 is steadily worming it's way into the cockles of my heart. It has been flown about six times for a total of maybe 15-18 minutes. I keep doing stupid things to bring flying sessions to an early close or have some mechanical issue pop up (motor falls off, prop saver loosens itself, etc.) that ends them. But I am still with the same plane and it is little worse for wear. I figure that within the next few sessions I will actually fly a battery to depletion! I had a motor that was haunting me, it seemed to have a vibration in it that terrified me if I got over 1/2 throttle. That was a 70 gram Hobby City HXM2730-1700. I just swapped that motor out for a 2410-12D 1200KV ($9.00 from Lazertoys.com) and now have a motor that appears to be much better matched to the plane and me talents too. If you give up easy, you'll end up having given up easy. Stubborness pays in the long run! Jack |
Utrecht, The Netherlands
Joined Jul 2006
That pine wood seems a bit heavy-ish, but it might not be a problem. If you cant do the round LE trick, then you'll have to sand the LE round yourself. As long as the top panel is glued on tight it should not matter structurally.
| Thread Tools | |
| Video Blu-Baby Primary Trainer | Tony65x55 | Electric Plane Talk | 0 | May 05, 2007 06:05 AM |
| Chosing Trainer...Kit?Plans?RTF? | Seared Ice | Fuel Plane Talk | 49 | Aug 16, 2004 11:50 AM |
| Which SPAD Trainer to build?? Plans? | VBSuperMaxx | SPAD - Simple Plastic Airplane Designs | 12 | May 05, 2004 09:19 PM |
| Sold FS: Fireball 550 Trainer "PLANS" | Rudderman98 | Aircraft - Electric - Airplanes (FS/W) | 4 | Dec 05, 2002 07:38 PM |
