![]() I tried using thin tie wire and guitar string before but didn't like it personally. Seems to me to be too hard to work with. Steve. |
Can anyone point me to a post with the pdf file that has details for the 60" polyhedral wing? I used the thread search engine but didn't find anything. Also searched for AP1 and AP2 but didn't find anything on the wing in the results. Is it a KFm3 with a 10" chord and 3 20" pannels?
Has anyone tried the Clark Y as shown in the article at: http://www.ncflyingtigers.org/combat...%20Study21.pdf (See screen capture below.) Tony said: "Stock stabs are fine." Thanks I got the guides for the hot wire cutter made. I did the elevator with it and it makes a beautiful clean cut. Elevator on and hinged. back decking cut and fit. Thanks, Steve. |
Hello
Hi, everybody. I feel like I need to introduce myself again...Wow! My last post in this forum was back in April--about 250 pages ago! I don't have the time or the bandwidth to play catch-up right now and I still won't be able to check in regularly. I just wanted to pop in and say "Howdy" to my fellows in the BB fan club. So--"Howdy!"
Tony, after five and a half months out in the middle of the Afghan desert we're finally back in near-civilization. Right now I'm sitting on the boardwalk outside the Timmy's trailer, surrounded by your countymen, and surfing the free wireless internet (can you believe that?!). I still have a few weeks to hang out here, but it's almost time to dust off those plans you promised. kendall |
Kendall!!!!!! Whoo-hoo!!! How are you Buddy. It's great to hear from you. I figured you were lost in a sandstorm. Thanks for the periodic updates from the sandbox though. It's good to know you're OK.
The plans are still waiting for you to beta, as promised. I bet that Timmy's tastes like heaven after 5 1/2 months of sand. You tell those Canadians that Tony said to treat you good and give you extra Timbits. When are you coming home? Tony |
It has all the plans for the BBAP2 and a description on the wing. Yes, it is three panels. The original is designed to come apart in the middle for easy transportation but you can easily build it as one piece. Flies great too. Tony |
My, what a pleasant surprise for today. I am glad I decided to check my mail this morning. Rob... |
Ok so I have a BB question. I finally got a scale so I could weigh my planes and see where I was at. been curious about how much weight I added with the printer decal camo. I thought someone had posted there AUW on a 42" BB at 450g as being a bit heavy. well after weighing mine in mast night it was over 600g
I dropped a bit of weight by removing the decal camo and any extra box tape I thought I could get away without having. that dropped little over 60g or 2.2oz. not sure where the rest of the weight is coming from unless the Popular Dowels I used weight that much more than Spruce would. I am now down to an AUW of just under 540g (sorry got the numbers wrote down at home and forgot to grab them so I am trying to remember) I am curious if the new props I have ordered will weigh in less than the seemingly indestructible ones I have on it now. she flew fairly good before the weight loss. I probably shouldn't with it at all lol but I would still like to see if I can get a few more mins in the air with her. I would like to have to bring her down cause my neck hurts not cause the batts died lol. also is there a ratio of AUW to thrust I should be shooting for? I keep thinking if my plane weighs in at 21oz I should be looking for 21oz of thrust. not sure if I am thinking right on that or not. Its not unheard of for my to be wrong "Sometimes". Thanks again for your help. Jon P.S. Kendall its good to see you posting. I have read a lot of your posts lately and seen many of your fine builds. looking forward to seeing more wonderful builds from you soon. Stay safe over there. Thanks for everything and come home safe. Jon |
Cybernaught, the photo you showed is no Clark Y. It's not even close. It is just a flat bottom airfoil shape. I've attached a drawing of a Clark Y for reference, in case you want to build one.
I did actually build a Clark Y from FFF. I cut FFF ribs from the airfoil template, glued the spar and ribs to the bottom foam, and folded the top over. The wing was for my Slow Stick. I wanted to add ailerons and a "real" wing. The wing worked OK, but was heavier than the equivalent KFM3, faster, and had less lift. The KFM3 is also a lot easier to build. |
| Thread Tools | |
| Video Blu-Baby Primary Trainer | Tony65x55 | Electric Plane Talk | 0 | May 05, 2007 06:05 AM |
| Chosing Trainer...Kit?Plans?RTF? | Seared Ice | Fuel Plane Talk | 49 | Aug 16, 2004 11:50 AM |
| Which SPAD Trainer to build?? Plans? | VBSuperMaxx | SPAD - Simple Plastic Airplane Designs | 12 | May 05, 2004 09:19 PM |
| Sold FS: Fireball 550 Trainer "PLANS" | Rudderman98 | Aircraft - Electric - Airplanes (FS/W) | 4 | Dec 05, 2002 07:38 PM |
