Old Sep 09, 2008, 07:06 AM
frank48 is online now
Find More Posts by frank48
Went to mow a meadow
frank48's Avatar
United Kingdom, Dur
Joined Feb 2007
Steve, I'd go along with MadDuc on the prop - try the 10x4.7 on 2 cells - it'll fly nice & floaty....
Cheers,
Frank
frank48 is online now Find More Posts by frank48
Old Sep 09, 2008, 08:02 AM
bz1mcr is online now
Find More Posts by bz1mcr
AKA Don
United States, FL, Naples
Joined Dec 2002
Originally Posted by Cybernaught
... If the wind picks up I'll be building, in the sailboat or on my AG range.
Steve.
AG range??
bz1mcr is online now Find More Posts by bz1mcr
Old Sep 09, 2008, 12:24 PM
jhtitan is offline
Find More Posts by jhtitan
jhtitan's Avatar
Washington MO
Joined Jul 2008
Steve just my 2 cents on the prop size from what I have learned and a lot of this is my motor which isn,t the same one you will be using. I started with a 9x4.7 and it was good for 3 flights at which time it flew away and landed in an unknown location in the grass I switched to an 8x6 which fly's well but always seemed kinda sluggish for me. I then went to an 11x7 which gave me excellent power and short flight times I am very heavy on the throttle most of the time. I have some 10x6 props ordered after much research these appear to be the best all around prop (same thrust, lower Amp draw, higher Pitch speed) for my motor. Heads up RC had some great testing info on my motor. I'm not sure if they carry the motor you are going to use or not I'll include a link and you can check them out. so far the smaller props give me warmer batts on 2s packs ,1300mAh 2s 20c zippy packs, and a much hotter motor at the end of the flight where as the 11x7 seemed that everything came down warm all be it in a much shorter time span. that's what I have discovered at this point. my 42" BB I can drop down to almost 1/4 throttle and just float her around or jam the throttle wide open for nice tight barrell rolls and loops on the 11x7 on the 8x6 i can still slow her way down but only about 1/2 throttle and can still pull loops and barrel rolls shes no where near as fast but, she's a bit too fast with the 11x7 lol at WOT I cant get her trimmed out so have to stay on the sticks a bit to keep her in the air. if I drop the throttle a bit she fly's her self. all and all. she durable, agile, and one hell of a floater.
Heads Up RC
Hope that helps a little. that's just been my findings with my 42"
Keep flyin
Jon
jhtitan is offline Find More Posts by jhtitan
Old Sep 09, 2008, 01:47 PM
ginodouglas is offline
Find More Posts by ginodouglas
Taubate, SP, Brazil
Joined Aug 2007
Ken BB24 KFm3 Instructions
Ken
I put your instructions and photos for the BB24 KFm3 wing together in one PDF file, thanks a lot for them.
The URL to download it is:
http://www.4shared.com/file/62363804...tructions.html
Gino
ginodouglas is offline Find More Posts by ginodouglas
Old Sep 09, 2008, 03:16 PM
laserman is offline
Find More Posts by laserman
In Rc for a LONG TIME FFAA#1
laserman's Avatar
Canada, ON, Ottawa
Joined Jun 2004
Don't know if anyone else knows
but i heard that the Master and the Sensai if KFM were interviewed on RCFLIGHTCAST, that is right our Friend and Sensai Tony65x55 and the Master Dick Kline were on last mondays show Episode 22, site http://www.rcflightcast.com/ and direct link for the pod cast http://media.libsyn.com/media/rcflightcast/RCFC_22.mp3
enjoy
laserman is offline Find More Posts by laserman
Old Sep 09, 2008, 04:36 PM
dz1sfb is offline
Find More Posts by dz1sfb
Ken's CAD Models
dz1sfb's Avatar
Attica, MI
Joined Dec 2006
Originally Posted by ginodouglas
Ken
Gino
Gino,
Thanks, but do you think you could post it here. Seems more direct.
Ken
dz1sfb is offline Find More Posts by dz1sfb
Latest blog entry: Mini H Quad Project
Old Sep 09, 2008, 06:01 PM
Cybernaught is offline
Find More Posts by Cybernaught
Onward through the fog.
Cybernaught's Avatar
Bohol Philippines
Joined Aug 2008
Originally Posted by bz1mcr
AG range??
"AG" = AirGun. I have 11 airguns ranging from PCP (PreCharged Penumatic) to pumpers to barrel cockers. Pistol and rifle; plinkers and olympic target. I set up a 25m range along side the house with a concrete wall backstop.
Propellers:
When the batteries get here, I'll try the 10x4.7. Thats the one that came with the original combo. I got a 19+ minute motor run, static, at half throttle, before burning up my Rhino 1050 2s battery, with that prop.
Today is "put all the parts I got yesterday together day", to make my foam cutting bow. 26" of SS leader on 12v pulls just over 2A and cuts nicely. With that working I can cut the wing and control surface angles accurately. My foam stock is 24" wide so it makes a good length.
So many hobbies. So little time. www.tranquilityisland.com
Steve.
Cybernaught is offline Find More Posts by Cybernaught
Old Sep 09, 2008, 06:21 PM
Taubate, SP, Brazil
Joined Aug 2007
Originally Posted by dz1sfb
Gino,
Ken
Ken
I thought we have a very low limit for uploads, like 40KB for photos, for PDF files and this one has 936KB.
Sorry for that
Gino
Old Sep 09, 2008, 08:01 PM
Bohol Philippines
Joined Aug 2008
Heads Up RC
Keep flyin
Jon
Now that's the kind of info that really helps. Thanks Jon.
Just want to say that this forum and THIS thread in particular has some of the friendliest most helpful people in the world of RC participating.
Thank you all,
Steve.
Old Sep 09, 2008, 08:25 PM
dz1sfb is offline
Ken's CAD Models
dz1sfb's Avatar
Attica, MI
Joined Dec 2006
Ken
Sorry for that
Gino
No problem Gino!
Thanks for posting it up here, and for putting it together. This forum is a great place with a great bunch of people.
Ken
Old Sep 09, 2008, 10:12 PM
gramps45 is offline
Find More Posts by gramps45
have a brain buster question. my bb33 have a 24 grm hc motor,12a esc, 800mah batt been running this set up for awhile. did four flights this morning fine. went back this evening. gave half throttle fine, gave full throttle motor cut off. this happens intermittedly. things done to trouble shoot change esc, tried 620,800,1000 mah still happen now and then. put motor in another plane motor run okay. batt conn. are mini deans,esc have 2.0 gold conn,have checkk all solder joints. using dx7 and 6100 rcvr. any suggestions
thanks
gramps
gramps45 is offline Find More Posts by gramps45
Old Sep 09, 2008, 10:30 PM
springer is offline
Find More Posts by springer
treefinder
springer's Avatar
SE MI
Was the esc you switched in also a 12 amp? perhaps the motor is pulling more amps than the esc likes? what brand is the esc? Did it pull full throttle the four flights this am? I have had motors act like that when for some reason the battery connector isn't fully inserted. (this with jst and sometimes they "hang up" about half way in, will run the servos, but motor will start but stop if throttle advanced - I'd be surprised to hear that with the minideans, tho)
springer is offline Find More Posts by springer
Old Sep 09, 2008, 11:43 PM
mxspode is offline
Find More Posts by mxspode
If it flies, I will crash it
mxspode's Avatar
USA, CO, Westminster
Originally Posted by Daddy-O
I still haven't heard from Bill about the Scale and Tile 3 program, so I have been playing around with Sketchup to try to get the parts drawn out. I do have a plan and managed to scale it down to a 33" wingspan. When I do the print preview, I see that it wants to print 20 pages and there are no margins on the pages (it tries to print right to the edge of the paper). Is there a good way to go from Sketchup to paper without wasting so much paper and getting the margins in there?
Daddy-O
You will have to be patient with Bill. He has allot of personal stuff going on right now. He will catch up eventually.
If you would like I could work with you to scale some plans for you to help your project along. It would take a few transfers but it would get things done. Just drop me a PM if I can help. I would be glad to do it to help out a fellow BB enthusiast.
I think I am going to play with Sketchup again. I am sure I can figure it out if I just spend some time on it.
Rob...
mxspode is offline Find More Posts by mxspode
Old Sep 10, 2008, 12:12 AM
mxspode is offline
mxspode's Avatar
Stupid is, is stupid does, LOL
I talked with the project manager for the job I am on today and he offered his warehouse to test fly my Front Yard Flier BB today. Sounds like a great idea huh. So I load up some stuff and off to work I go. At lunch I head of to the office for a check and a little flying. I get the plane out and turn on the TX only to find that I left the flight battery on my work bench 90 miles away. Talk about a big let down. An hour latter a truck showed up and filled up the warehouse. Bummer.
I didn't make any progress on the contest build tonight which is OK since I worked way to long and tired does not make for good BB building. I did manage to knock out a new power supply for my hot-wire cutter (see attached pic for snazzy PS). Tomorrow we make monoblocks and then we make us up a fuselage. I am on my way.
Rob...
Old Sep 10, 2008, 01:13 AM
MadDuc is offline
Find More Posts by MadDuc
MadDuc's Avatar
I have 12 - 8x4, 6 - 8x6, 1 - 10x4.7 on hand now and 2 - 9x3.7 coming. I was figuring on the 8x4 or 8x6 for this one. This is in with my order for 2 b21 combos, 3 13002s batts, 3 prop-savers and some small hardware. I may increase the wingspan to 45", polyhedral and shoot for around 4 to 5 oz per sq-ft. I may build several wings to see which I like best. I'm thinking Clark Y and KFm2 as well as the KFm3. Anyway I have plenty of time because the parts won't get here for about 10 days to 2 weeks.
How do you think the battery motor combo would work on a BB-33? Better than the 42/45? The electronics including battery will be around 170grams, 200 at the most and figuring the same for the plane with linkages would give me an all up weight of around 14oz. (400g)
I'm looking for a floater with good manners and around 20 min flying time on one charge assuming I keep a light thumb on the throttle. I was thinking I can have one batt in the plane and two on the charger. My initial flying will be in calm weather only until I get my thumbs back. If the wind picks up I'll be building, in the sailboat or on my AG range.
Steve.
I don't have experience with larger props on the BP yet since I only have one old 1100-2S ETEC that is not able to start up this motor. All other LiPo's are 3S. I just figured that with 2S you should be able to prop up a bit. But the answers above seem to have helped you out.
To float, build as light as possible!!! The BP's are around 50-55grams I believe, so for a BB33 it might be a bit heavy if you want to float.... but other flyers could probably better comment on this. If I where to build a light BB33 I would use: a 20-25gr. motor with light esc, 5gr servo's, max 800mAh LiPo, micro Rx, etc.
My BB42 was not build very light, but strong, hence the 450gr AUW, although I have seen reports here of BB33's with such an AUW.
Have fun putting everything together.....
Completely agree with your 'So many hobbies. So little time.' comment
MadDuc is offline Find More Posts by MadDuc
Video Blu-Baby Primary Trainer Tony65x55 Electric Plane Talk 0 May 05, 2007 06:05 AM
Chosing Trainer...Kit?Plans?RTF? Seared Ice Fuel Plane Talk 49 Aug 16, 2004 11:50 AM
Which SPAD Trainer to build?? Plans? VBSuperMaxx SPAD - Simple Plastic Airplane Designs 12 May 05, 2004 09:19 PM
Sold FS: Fireball 550 Trainer "PLANS" Rudderman98 Aircraft - Electric - Airplanes (FS/W) 4 Dec 05, 2002 07:38 PM
