Flaperons are fun to play with and will cause this plane to go from really slow to really, really slow. They shouldn't cause you tip stalls if the flaperon chord is smaller at the tip than at the root. That way, lowering your flaperons increases your effective washout. It doesn't have to be a lot smaller, a 1/4 to 1/2" should do it. If you find the adverse yaw to much to bear, simply add a bottom panel to the wing. Don't sweat, with the flaperons it will still slow the plane down to a crawl but it will roll way nicer. BTW, a little bit (1/4") of negative flaperon will really increase your cruise speed and penetration. Tony |
Maybe even a Blu-Baby!
Ipoh, Perak Malaysia
Joined Jul 2006
By "add a bottom panel" do you mean make the airfoil a flat bottomed section? If not, then what does that mean? Again, thanks for the info. chewy |
Guys,
How do you align the pushrod with the servos, elevator, and holes in the bulkhead and fuselage? I tried poking a hole from the elevator going forward. It kind of worked, although the pushrod has a bend in it. I've dealt only with profile planes before, and of course it's pretty easy on those! |
Joined May 2006
Progress so far...
Wing halves and KFm strips joined at the dihedral angle (hotwired angles) KFm strips grooved for spars (soldering iron). Front and rear carbon spars and 5/32 alum joiners mated. Mono block parts mated to glued to fuse halves. Fuse taped together for pic. Ready to plop in the spars and glue the KFm strips to the wings! Still gotta work out servo and reciever mounting and widen stab slot before gluing fuse sides together. Looking forward to the test flights!! Scott |
| Thread Tools | |
| Video Blu-Baby Primary Trainer | Tony65x55 | Electric Plane Talk | 0 | May 05, 2007 06:05 AM |
| Chosing Trainer...Kit?Plans?RTF? | Seared Ice | Fuel Plane Talk | 49 | Aug 16, 2004 11:50 AM |
| Which SPAD Trainer to build?? Plans? | VBSuperMaxx | SPAD - Simple Plastic Airplane Designs | 12 | May 05, 2004 09:19 PM |
| Sold FS: Fireball 550 Trainer "PLANS" | Rudderman98 | Aircraft - Electric - Airplanes (FS/W) | 4 | Dec 05, 2002 07:38 PM |
